  1. acronimo valeu cara! brigado mesmo me ajudou muito.
  2. Citação Postado originalmente por Acronimo Ver Post
    Amigo siga estes passos aqui demoramos pra fazer ele mas agora esta tudo redondo (pcc enxuto)
    ;;;;;;;;;;Pcc com 2 links
    ;;;;;;;;;;Primeiro renomei as interfaces
    EthClientes = saida pro servidor
    EthLink1 = modem 1 em bridg
    EthLink2 = modem 2 em bridg
    ;;;;;;;;;;segundo Fazer 2 PPPOE com os nomes abaixo
    Discador1
    Discador2
    OBS: quando vc fizer os discadores você deixa marcado SÓ a OPÇÂO "ADD DEFAUT ROUTE"
    ;;;;;;;;;Treceiro fazer o nat dos discadores
    /ip firewall nat
    add action=masquerade chain=srcnat comment="MASCARAMENTO PCC" disabled=no out-interface=\
    Discador1
    add action=masquerade chain=srcnat comment="" disabled=no out-interface=Discador2
    ;;;;;;;;;;Adicionar um IP no Adress
    192.168.10.1
    /ip address
    add address=192.168.10.1/24 broadcast=192.168.10.255 comment="IP PCC" disabled=no \
    interface=EthClientes network=192.168.10.0
    ;;;;;;;;;;;DNS
    200.165.132.155
    200.149.55.142
    não esquece de colocar o DNS e marca o "allow remote requests...
    ;;;;;;;;;;;Mangle
    /ip firewall mangle
    add action=accept chain=prerouting comment="Sem Balance" disabled=no dst-address-list=\
    sem_balance in-interface=EthClientes
    add action=mark-connection chain=input comment="" connection-state=new disabled=no \
    in-interface=Discador1 new-connection-mark=conn_na passthrough=yes
    in-interface=Discador2 new-connection-mark=conn_nb passthrough=yes
    add action=mark-connection chain=prerouting comment="" disabled=no dst-address-type=\
    !local in-interface=EthClientes new-connection-mark=conn_ma0 passthrough=yes \
    per-connection-classifier=both-addresses:6/0
    !local in-interface=EthClientes new-connection-mark=conn_mb1 passthrough=yes \
    per-connection-classifier=both-addresses:6/1
    add action=mark-routing chain=prerouting comment="" connection-mark=conn_ma0 disabled=no \
    in-interface=EthClientes new-routing-mark=to_nra passthrough=no
    add action=mark-routing chain=prerouting comment="" connection-mark=conn_mb1 disabled=no \
    in-interface=EthClientes new-routing-mark=to_nrb passthrough=no
    ;;;;;;;;;;;;;;Route
    /ip route
    add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=Discador1
    add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=Discador1 \
    routing-mark=to_nra
    add comment="" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=Discador2
    add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=Discador2 \
    routing-mark=to_nrb
    Cara rolou aki blz valeuuu funfa ,, me ajudou ,, mas tava fazendo uns teste aki e reparei que nao rola dividindo fiz downlouds de varios lugares diferentes e ele da preferência pra um , mas se desligo um o outro assume normal so o msn que cai mas volta ,, gostaria de saber se preciso add mais alguma regra pra fazer ele dividir igual o trafego
  3. No caso de 4 adsl, o procedimento é o mesmo que para 2? Se não for qual seria?
  4. Ola amigos fiz o teste aqui aparentemente funcionou agora gostaria de saber como funciona esse tipo de balancemaneto "teoricamente"
  5. Citação Postado originalmente por winetcompany Ver Post
    voce conseguiu dividir a carga igualmente?
  1. Respostas: 35
    Último Post: 01-07-2016, 12:22
  2. RB 750 com 2 link + cache é possivel?
    Por availto no fórum Redes
    Último Post: 04-05-2012, 00:23
  3. Balanceamento RB-750 MK4.10
    Por nailton no fórum Redes
    Respostas: 9
    Último Post: 10-12-2010, 20:48
  4. Configurar squid com link adsl - Ajuda ai galera...
    Por BrasileiroNet no fórum Servidores de Rede
    Respostas: 10
    Último Post: 12-07-2010, 10:42
  5. Respostas: 4
    Último Post: 11-06-2008, 10:03
