Página 10 de 10 PrimeiroPrimeiro ... 5678910
  1. Citação Postado originalmente por freitascs Ver Post
    Olá, amigo aqui eu sempre usei both-addresses-and-ports o link no servidor chega facio aos 9Megas no caso são 3 links dois links de 4Megas e meio e um link dedicado de 1Mega.
    veja essa configuraçao onde eta diferente da suaConfiguracao sem dedicado.txt
  2. Citação Postado originalmente por Brutus Ver Post
    Amigao o que isso faz?
    # /system script--------------------------------------
    /system script add name=Link0Dow policy=\ ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive source="\ /ip firewall filter set [find comment=\"Link0\"] disabled=yes;\r\ \n/ip firewall nat set [find comment=\"Link0\"] disabled=yes;\r\ \n/ip firewall mangle set [find comment=\"Link0\"] disabled=yes;\r\ \n/ip route set [find comment=\"Link0\"] disabled=yes;"
    /system script add name=Link1Dow policy=\ ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive source="\ /ip firewall filter set [find comment=\"Link1\"] disabled=yes;\r\ \n/ip firewall nat set [find comment=\"Link1\"] disabled=yes;\r\ \n/ip firewall mangle set [find comment=\"Link1\"] disabled=yes;\r\ \n/ip route set [find comment=\"Link1\"] disabled=yes;"
    /system script add name=Link2Dow policy=\ ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive source="\ /ip firewall filter set [find comment=\"Link2\"] disabled=yes;\r\ \n/ip firewall nat set [find comment=\"Link2\"] disabled=yes;\r\ \n/ip firewall mangle set [find comment=\"Link2\"] disabled=yes;\r\ \n/ip route set [find comment=\"Link2\"] disabled=yes;"
    /system script add name=Link0Up policy=\ ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive source="\ /ip firewall filter set [find comment=\"Link0\"] disabled=no;\r\ \n/ip firewall nat set [find comment=\"Link0\"] disabled=no;\r\ \n/ip firewall mangle set [find comment=\"Link0\"] disabled=no;\r\ \n/ip route set [find comment=\"Link0\"] disabled=no;"
    /system script add name=Link1Up policy=\ ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive source="\ /ip firewall filter set [find comment=\"Link1\"] disabled=no;\r\ \n/ip firewall nat set [find comment=\"Link1\"] disabled=no;\r\ \n/ip firewall mangle set [find comment=\"Link1\"] disabled=no;\r\ \n/ip route set [find comment=\"Link1\"] disabled=no;"
    /system script add name=Link2Up policy=\ ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive source="\ /ip firewall filter set [find comment=\"Link2\"] disabled=no;\r\ \n/ip firewall nat set [find comment=\"Link2\"] disabled=no;\r\ \n/ip firewall mangle set [find comment=\"Link2\"] disabled=no;\r\ \n/ip route set [find comment=\"Link2\"] disabled=no;"
  3. Citação Postado originalmente por Brutus Ver Post
    Anexo 31384
    Como explicar isso, realmente balanceia a carga mas ate chegar aos 4 megas sendo cada link tem 3 megas?????
    Quem conseguir resolver vai ganhar um doce
    Amigo da uma olhada abaixo como está o meu, funcionando perfeitamente.
    /ip firewall mangle
    add action=accept chain=prerouting comment="HTTPS FORA DO LOADBALACED" \
    disabled=no dst-port=443 in-interface=ponte protocol=tcp
    add action=accept chain=prerouting comment="FORA DO LOADBALACED" disabled=no \
    dst-address-list=loopback in-interface=ponte
    add action=change-ttl chain=forward comment="Filtro Tracert / Traceroute" \
    disabled=no new-ttl=set:30 passthrough=yes protocol=icmp
    add action=mark-connection chain=prerouting connection-state=new disabled=no \
    in-interface="1 link" new-connection-mark=ether1_conn passthrough=yes
    in-interface=adsl_ether2 new-connection-mark=adsl_ether2_conn passthrough=\
    yes
    in-interface=adsl_ether3 new-connection-mark=adsl_ether3_conn passthrough=\
    yes
    add action=mark-routing chain=output connection-mark=ether1_conn disabled=no \
    new-routing-mark=to_ether1 passthrough=yes
    add action=mark-routing chain=output connection-mark=adsl_ether2_conn disabled=\
    no new-routing-mark=to_adsl_ether2 passthrough=yes
    add action=mark-routing chain=output connection-mark=adsl_ether3_conn disabled=\
    no new-routing-mark=to_adsl_ether3 passthrough=yes
    add action=accept chain=prerouting disabled=no dst-address=172.168.2.0/24 \
    in-interface=ponte
    dst-address-type=!local in-interface=ponte new-connection-mark=ether1_conn \
    passthrough=yes per-connection-classifier=both-addresses:6/0
    passthrough=yes per-connection-classifier=both-addresses:6/1
    passthrough=yes per-connection-classifier=both-addresses:6/2
    dst-address-type=!local in-interface=ponte new-connection-mark=\
    adsl_ether2_conn passthrough=yes per-connection-classifier=\
    both-addresses:6/3
    both-addresses:6/4
    adsl_ether3_conn passthrough=yes per-connection-classifier=\
    both-addresses:6/5
    add action=mark-routing chain=prerouting connection-mark=ether1_conn disabled=\
    no in-interface=ponte new-routing-mark=to_ether1 passthrough=yes
    add action=mark-routing chain=prerouting connection-mark=adsl_ether2_conn \
    disabled=no in-interface=ponte new-routing-mark=to_adsl_ether2 passthrough=\
    yes
    add action=mark-routing chain=prerouting connection-mark=adsl_ether3_conn \
    disabled=no in-interface=ponte new-routing-mark=to_adsl_ether3 passthrough=\
    yes
  1. Respostas: 15
    Último Post: 19-07-2012, 22:22
  2. Respostas: 11
    Último Post: 02-01-2012, 13:01
  3. Políticas de rotas com PCC e 4 links roteados
    Por sostenes no fórum Redes
    Respostas: 31
    Último Post: 10-11-2011, 10:49
  4. Políticas de rotas com dois links DSL
    Por huskie no fórum Redes
    Respostas: 17
    Último Post: 25-06-2010, 22:48
  5. Muita perca de pacote com FORWARD no firewall
    Por blaizer no fórum Servidores de Rede
    Último Post: 07-01-2006, 09:18
