  1. as regras que uso sao as estao abaixo... atenção ao nome da Interface e a lista de ips (ip firewall address-list)
    /ip firewall filter
    add action=drop chain=forward comment="DROP WAREZ" disabled=no in-interface=REDE p2p=warez
    add action=drop chain=input comment="DROPA PACOTES INVALIDOS" connection-state=invalid disabled=no
    add action=drop chain=forward connection-state=invalid disabled=no
    add action=accept chain=input comment="ACEITA ACESSO EXTERNO WINBOX" disabled=no dst-port=8219 protocol=tcp
    add action=add-src-to-address-list address-list=spammer address-list-timeout=1h chain=forward comment="AntiSPAM o AntiWORM" connection-limit=20,32 disabled=no dst-port=25,465 in-interface=REDE protocol=tcp
    add action=drop chain=forward disabled=no dst-port=25,465 in-interface=REDE protocol=tcp src-address-list=spammer
    add action=jump chain=forward comment="*****************VIRUS *******************" jump to the virus chain" disabled=no in-interface=REDE jump-target=virus
    add action=drop chain=virus disabled=no dst-port=0,67-68,135-139,445,1024-1030,1080,1214,1364,1373,1377 protocol=tcp
    add action=drop chain=virus disabled=no dst-port=1433-1434,2049,2283,2535,3133,3410,4444,10000,12345-12346,20034,27374,65506 protocol=tcp
    add action=drop chain=virus disabled=no dst-port=0,25,69,111,135-139,445,1349,2049,3133,4444,10666 protocol=udp
    add action=accept chain=input comment="ACEITA PACOTES ESTABLISHED REDE INTERNA" connection-state=established disabled=no
    add action=accept chain=forward connection-state=established disabled=no
    add action=accept chain=input comment="ACEITA PACOTES RELATED REDE INTERNA" connection-state=related disabled=no
    add action=accept chain=forward connection-state=related disabled=no
    add action=accept chain=forward comment="ACEITA REDE INTERNA" disabled=no in-interface=REDE src-address-list=RedeInterna
    add action=accept chain=input disabled=no in-interface=REDE src-address-list=RedeInterna
    Aqui vem o Pulo de Gato
    add action=drop chain=forward comment="DROPA TODO RESTANTE" disabled=no
    add action=drop chain=input disabled=no
  2. eu tambem não se tivesse alguma pessoa com experiencia em firewall que fala se de uma forma simples que pudessemos entender seria otimo ,por isso prefiro comprar e pagar pelo serviço ja que não tem ninguem para ensinar pelo menos tenho uma solução pronta .
    alguem conhece algum firewall ai maquina ,ate tenho uma na mão mas os caras querem r$ 1000.00 por mes ai e osso,quero um firewall que relmente seja bom e não custe o provedor.
  3. Citação Postado originalmente por naldo864 Ver Post
    parceiro
    firewall serve para libera ou bloquear determinado trafego.
    cada caso é um caso
    e precisa ser bem analisado para saber o que deixa passar ou o que bloqueia.
    no meu caso, deixei quase tudo que vem dos clientes (bloqueio de virus, warez), liberei algumas portas externas e bloquei todo o restante.
    para controle de invasao, o apropriado seria um IDS
    Sistema de deteccao de intrusos.
    geralmente é caro... e as versoes open sao dificieis de colocar em pratica
    Última edição por AndrioPJ; 11-10-2011 às 22:52.
  4. Citação Postado originalmente por naldo864 Ver Post
    problema e configurar isto direito
    Naldo se precisar posso te dar uma mao e te ajudar ai se vc querer me add no msn suporte@criciumanet.com.br e conversamos melhor podemos verificar as principais portas de virus atualmente e fazer os filtros tenho alguma q aplico aqui ja e so aplicar ai,
  5. obrigado dematoos vou guardar sua oferta de ajuda para depos de 15 de novembro qua vai ser a epoca que vou fazer muitas mudanças aqui no provedor .
    vou fazer os treinamentos de roteamento da mikrotik ai vou implantar na rede ,emconjunto quero implantar o firewall tambem para ano que vem eu crescer a rede com segurança e profissionalismo .agradeço a todos pela ajuda .
  1. Kazaa + firewall
    Por serrato no fórum Servidores de Rede
    Último Post: 10-01-2005, 20:21
  2. Não consigo configurar firewall
    Por buosinet no fórum Servidores de Rede
    Respostas: 5
    Último Post: 29-11-2004, 19:09
  3. Squid + Firewall
    Respostas: 10
    Último Post: 02-12-2002, 18:54
  4. firewall x webmail ou firewall x php?
    Por eclaudin no fórum Segurança
    Último Post: 23-08-2002, 04:14
  5. Não consigo configurar firewall
    Último Post: 28-03-2002, 21:44
