  1. /interface ethernet
    set 0 arp=enabled auto-negotiation=yes cable-settings=default comment="" \
    disable-running-check=yes disabled=no full-duplex=yes l2mtu=1600 \
    mac-address=00:1C:25:4A:F9:0B mtu=1500 name=Clientes speed=100Mbps
    set 1 arp=enabled auto-negotiation=yes cable-settings=default comment="" \
    disable-running-check=yes disabled=no full-duplex=yes mac-address=\
    00:01:038:21:B8 mtu=1500 name=Pinheiros speed=100Mbps
    set 2 arp=enabled auto-negotiation=yes cable-settings=default comment="" \
    00:0D:88:C5:B0:B4 mtu=1500 name=Back_UP speed=100Mbps
    set 3 arp=enabled auto-negotiation=yes cable-settings=default comment="" \
    00:0D:88:C5:B0:B5 mtu=1500 name=Mk-Auth speed=100Mbps
    set 4 arp=enabled auto-negotiation=yes cable-settings=default comment="" \
    00:0D:88:C5:B0:B6 mtu=1500 name="Interface Vlan" speed=100Mbps
    set 5 arp=enabled auto-negotiation=yes cable-settings=default comment="" \
    00:0D:88:C5:B0:B7 mtu=1500 name=Link speed=100Mbps
    /interface bridge
    add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes \
    comment="" disabled=no forward-delay=15s l2mtu=65535 max-message-age=20s \
    mtu=1500 name="BridgeVlan4_Casa Branca" priority=0x8000 protocol-mode=\
    none transmit-hold-count=6
    comment="" disabled=no forward-delay=15s l2mtu=1600 max-message-age=20s \
    mtu=1500 name=Bridge_SAIDA priority=0x8000 protocol-mode=none \
    mtu=1500 name=BridgeVlan2_X-Lan priority=0x8000 protocol-mode=none \
    mtu=1500 name=BridgeVlan3_Vaquejada priority=0x8000 protocol-mode=none \
    mtu=1500 name=BridgeVlan5_Olimpica priority=0x8000 protocol-mode=none \
    mtu=1500 name=BridgeVlan6_Trajano priority=0x8000 protocol-mode=none \
    mtu=1500 name=BridgeVlan7_Lanhouse priority=0x8000 protocol-mode=none \
    mtu=1500 name="BridgeVlan8_Pedra Verde" priority=0x8000 protocol-mode=\
    /interface vlan
    add arp=enabled comment="" disabled=no interface="Interface Vlan" mtu=1500 \
    name="Vlan1_Acesso Switch" use-service-tag=no vlan-id=1
    name=Vlan2_X-Lan use-service-tag=no vlan-id=2
    name=Vlan3_Vaquejada use-service-tag=no vlan-id=3
    name=Vlan5_Olimpica use-service-tag=no vlan-id=5
    name="Vlan4_Casa Branca" use-service-tag=no vlan-id=4
    name=Vlan6_Trajano use-service-tag=no vlan-id=6
    name=Vlan7_LanHouse use-service-tag=no vlan-id=7
    name="Vlan8_Pedra Verde" use-service-tag=no vlan-id=8
  2. /ip firewall filter
    add action=passthrough chain=unused-hs-chain comment=\
    "place hotspot rules here" disabled=yes
    add action=accept chain=input comment="=== ACEITAR CONEXOES DE PROXY =========\
    ========================= SISTEMA===" disabled=no \
    dst-port=3128 protocol=tcp
    add action=drop chain=forward comment="=== BLOQUEIO DO P2P ===================\
    ===========================SISTEMA===" disabled=no \
    p2p=all-p2p src-address-list=!p2p-sem-bloqueio
    add action=drop chain=forward comment="=== BLOQUEIO DE IP REVERSO ============\
    ========================== SISTEMA===" content=\
    .ctame700 disabled=no
    add action=accept chain=input comment="=== PERMITIR CONEXOES ESTABELECIDAS ===\
    ========================= SISTEMA===" \
    connection-state=established disabled=no
    add action=accept chain=forward comment="" connection-state=established \
    disabled=no
    add action=accept chain=icmp comment="" disabled=no icmp-options=3:0 \
    protocol=icmp
    add action=accept chain=icmp comment="" disabled=no icmp-options=3:1 \
    protocol=icmp
    add action=accept chain=input comment="=== PERMITIR UDP ======================\
    =========================== SISTEMA===" disabled=no \
    protocol=udp
    add action=drop chain=input comment="" disabled=no dst-port=23 protocol=tcp
    add action=accept chain=forward comment="" disabled=no protocol=udp
    add action=add-src-to-address-list address-list="port scanners" \
    address-list-timeout=0s chain=input comment="" disabled=no protocol=tcp \
    psd=21,3s,3,1
    add action=accept chain=input comment="" disabled=no protocol=tcp tcp-flags=\
    fin,!syn,!rst,!psh,!ack,!urg
    add action=drop chain=forward comment="" disabled=no dst-address=\
    200.210.104.201
    add action=accept chain=input comment="=== PERMITIR ACESSO DOS ROTEADORES A RE\
    DE DOS CLIENTES======== SISTEMA===" disabled=no \
    src-address=10.0.0.0/8
    add action=accept chain=input comment="" disabled=no src-address=192.0.0.0/8
    add action=accept chain=input comment="=== PERMITIR ICMP =====================\
    protocol=icmp
    add action=drop chain=forward comment="=== BLOQUEAR CONEXOES INVALIDAS =======\
    connection-state=invalid disabled=no protocol=tcp
    add action=drop chain=forward comment="" connection-state=invalid disabled=no
    add action=accept chain=icmp comment="" disabled=no icmp-options=0:0 \
    protocol=icmp
    add action=accept chain=forward comment="=== PERMITIR CONEXOES RELACIONADAS ==\
    =========================== SISTEMA===" \
    connection-state=related disabled=no
    add action=drop chain=forward comment="" disabled=no src-address=0.0.0.0/8
    add action=drop chain=forward comment="" disabled=no dst-address=0.0.0.0/8
    add action=drop chain=forward comment="" disabled=no src-address=127.0.0.0/8
    add action=drop chain=forward comment="" disabled=no dst-address=127.0.0.0/8
    add action=drop chain=forward comment="" disabled=no src-address=224.0.0.0/3
    add action=drop chain=forward comment="" disabled=no dst-address=224.0.0.0/3
    add action=jump chain=forward comment="" disabled=no jump-target=tcp \
    protocol=tcp
    add action=jump chain=forward comment="" disabled=no jump-target=icmp \
    protocol=icmp
    add action=drop chain=tcp comment="=== BLOQUEAR TFTP =========================\
    dst-port=69 protocol=tcp
    add action=drop chain=tcp comment="=== BLOQUEAR PORTMAPER ====================\
    ==================== SISTEMA===" disabled=no dst-port=\
    111 protocol=tcp
    add action=drop chain=tcp comment="" disabled=no dst-port=135 protocol=tcp
    add action=drop chain=tcp comment="=== BLOQUEAR NBT ==========================\
    dst-port=137-139 protocol=tcp
    add action=drop chain=tcp comment="=== BLOQUEAR CIFS =========================\
    dst-port=445 protocol=tcp
    add action=drop chain=tcp comment="=== BLOQUEAR NFS ==========================\
    dst-port=2049 protocol=tcp
    add action=drop chain=tcp comment="=== BLOQUEAR NETBUS =======================\
    dst-port=12345-12346 protocol=tcp
    add action=drop chain=tcp comment="" disabled=no dst-port=20034 protocol=tcp
    add action=drop chain=tcp comment="=== BLOQUEAR BACKORIFFICE =================\
    dst-port=3133 protocol=tcp
    add action=accept chain=icmp comment="=== PERMITIR BUSCAS ====================\
    icmp-options=4:0 protocol=icmp
    add action=accept chain=icmp comment="=== PERMITIR TEMPO RESTANTE ============\
    icmp-options=8:0 protocol=icmp
    add action=accept chain=icmp comment="=== PERMITIR TEMPO EXCEDENTE ===========\
    icmp-options=11:0 protocol=icmp
    add action=accept chain=icmp comment="=== PERMITIR PARAMETROS BAIXOS =========\
    icmp-options=12:0 protocol=icmp
    add action=drop chain=icmp comment="=== BLOQUEAR TODOS OS OUTROS SERVICOS=====\
    add action=accept chain="forward protocol=tcp dst-port=135-139 action=drop" \
    add action=accept chain="forward protocol=udp dst-port=135-139 action=drop" \
    add action=accept chain="forward protocol=tcp dst-port=445-449 action=drop" \
    add action=accept chain="forward protocol=udp dst-port=445-449 action=drop" \
    add action=add-src-to-address-list address-list=blocked-addr \
    address-list-timeout=1d chain=sanity-check comment="=== BLOQUEIO SCANER DE\
    \_PORTA =================================== SISTEMA===" \
    disabled=no protocol=tcp psd=20,3s,3,1
    address-list-timeout=1d chain=sanity-check comment="" disabled=no \
    protocol=tcp tcp-flags=fin,psh,urg,!syn,!rst,!ack
    protocol=tcp tcp-flags=!fin,!syn,!rst,!psh,!ack,!urg
    add action=accept chain=sanity-check comment="=== ACEITAR CONEXOES ESTABELECID\
    AS ============================= SISTEMA===" \
    add action=accept chain=sanity-check comment="=== ACEITAR CONEXOES RELACIONADA\
    S ============================== SISTEMA===" \
    add action=jump chain=forward comment="" disabled=no jump-target=restrict-tcp \
    protocol=tcp
    add action=reject chain=restrict-tcp comment="" connection-mark=auth \
    disabled=no reject-with=icmp-network-unreachable
    add action=jump chain=restrict-tcp comment="=== MONITORAMENTO DE ANTI-SPAM ===\
    connection-mark=smtp disabled=no jump-target=smtp-first-drop
    add action=add-src-to-address-list address-list=approved-smtp \
    address-list-timeout=0s chain=smtp-first-drop comment="" disabled=no \
    src-address-list=first-smtp
    add action=return chain=smtp-first-drop comment="" disabled=no \
    src-address-list=approved-smtp
    add action=add-src-to-address-list address-list=first-smtp \
    add action=reject chain=smtp-first-drop comment="" disabled=no reject-with=\
    add action=jump chain=forward comment="=== TESTE DE INTEGRIDADE ==============\
    jump-target=sanity-check
    add action=jump chain=input comment="" disabled=no jump-target=sanity-check
    add action=accept chain=dhcp comment="" disabled=no dst-address=\
    255.255.255.255 src-address=0.0.0.0
    add action=accept chain=dhcp comment="" disabled=no dst-address-type=local \
    src-address=0.0.0.0
    src-address-list=local-addr
    add action=accept chain=local-services comment="=== DIRECIONAR PARA O DNS ====\
    connection-mark=dns disabled=no
    add action=accept chain=public-services comment="=== LIBERAR PPTP ============\
    ===================================== SISTEMA===" \
    connection-mark=gre disabled=no
  3. add action=drop chain=virus comment="=== BLOQUEIO DE VIRUS ===================\
    dst-port=135-139 protocol=tcp
    add action=drop chain=virus comment="" disabled=no dst-port=135-139 protocol=\
    udp
    add action=drop chain=virus comment="" disabled=no dst-port=445 protocol=tcp
    add action=drop chain=virus comment="" disabled=no dst-port=445 protocol=udp
    add action=drop chain=virus comment="" disabled=no dst-port=593 protocol=tcp
    add action=drop chain=virus comment="" disabled=no dst-port=1024-1030 \
    protocol=tcp
    add action=drop chain=virus comment="" disabled=no dst-port=1080 protocol=tcp
    add action=drop chain=virus comment="" disabled=no dst-port=1214 protocol=tcp
    add action=drop chain=virus comment="" disabled=no dst-port=1363 protocol=tcp
    add action=drop chain=virus comment="" disabled=no dst-port=1364 protocol=tcp
    add action=drop chain=virus comment="" disabled=no dst-port=1368 protocol=tcp
    add action=drop chain=virus comment="" disabled=no dst-port=1373 protocol=tcp
    add action=drop chain=virus comment="" disabled=no dst-port=1377 protocol=tcp
    add action=drop chain=virus comment="" disabled=no dst-port=1433-1434 \
    protocol=tcp
    add action=drop chain=virus comment="" disabled=no dst-port=2283 protocol=tcp
    add action=drop chain=virus comment="" disabled=no dst-port=2535 protocol=tcp
    add action=drop chain=virus comment="" disabled=no dst-port=2745 protocol=tcp
    add action=drop chain=virus comment="" disabled=no dst-port=3410 protocol=tcp
    add action=drop chain=virus comment="" disabled=no dst-port=4444 protocol=tcp
    add action=drop chain=virus comment="" disabled=no dst-port=4444 protocol=udp
    add action=drop chain=virus comment="" disabled=no dst-port=5554 protocol=tcp
    add action=drop chain=virus comment="" disabled=no dst-port=8866 protocol=tcp
    add action=drop chain=virus comment="" disabled=no dst-port=9898 protocol=tcp
    add action=drop chain=virus comment="" disabled=no dst-port=10000 protocol=\
    tcp
    add action=drop chain=virus comment="" disabled=no dst-port=10080 protocol=\
    tcp
    add action=drop chain=virus comment="" disabled=no dst-port=12345 protocol=\
    tcp
    add action=drop chain=virus comment="" disabled=no dst-port=17300 protocol=\
    tcp
    add action=drop chain=virus comment="" disabled=no dst-port=27374 protocol=\
    tcp
    add action=drop chain=virus comment="" disabled=no dst-port=65506 protocol=\
    tcp
    add action=accept chain=forward comment="=== PERMITIR PING ===================\
    ============================= SISTEMA===" disabled=no \
    protocol=icmp
    add action=accept chain=input comment="=== DIRECIONAR WINBOX PARA O SERVIDOR =\
    dst-port=8291 protocol=tcp
    add action=accept chain=input comment="" disabled=no dst-port=8292 protocol=\
    tcp
    add action=add-src-to-address-list address-list="drop winbox" \
    address-list-timeout=12h chain=input comment="=== BRUTE FORCE PARA O SERVI\
    DOR ================================= SISTEMA===" \
    connection-limit=2,32 connection-state=established disabled=no dst-port=\
    8291 protocol=tcp
    address-list-timeout=12h chain=input comment="" connection-limit=2,32 \
    connection-state=established disabled=no dst-port=8292 protocol=tcp
    connection-state=established disabled=no dst-port=80 protocol=tcp
    add action=drop chain=input comment="" disabled=no src-address-list=\
    "drop winbox"
    add action=drop chain=input comment="=== BLOQUEAR PERMISOES ==================\
    add action=drop chain=tcp comment="=== BLOQUEAR DHCP==========================\
    dst-port=67-68 protocol=tcp
    add action=drop chain=public-services comment="=== BLOQUEAR OUTROS SERVICOS PU\
    BLICOS ========================= SISTEMA===" \
    disabled=no
    add action=drop chain=local-services comment="=== BLOQUEAR OUTROS SERVICOS LOC\
    AIS ============================ SISTEMA===" disabled=\
    no
    /ip firewall mangle
    add action=jump chain=prerouting comment="PG CORTE" disabled=no jump-target=\
    hotspot
    add action=mark-connection chain=output comment="=== CONTROLE DO CACHE =======\
    =====================================SISTEMA===" \
    content="X-Cache: HIT" disabled=no new-connection-mark=conn_squid-up \
    passthrough=yes protocol=tcp src-port=3128
    add action=mark-packet chain=output comment="" connection-mark=conn_squid-up \
    disabled=no new-packet-mark=pacotes_squid-up passthrough=yes
    add action=mark-connection chain=prerouting comment="" disabled=no dst-port=\
    3128 new-connection-mark=conn_squid-down passthrough=yes protocol=tcp
    add action=mark-packet chain=prerouting comment="" connection-mark=\
    conn_squid-down disabled=no new-packet-mark=pacotes_squid-down \
    passthrough=yes
    add action=mark-connection chain=prerouting comment="\r\
    \n=== CONTROLE DE P2P ===============================================WWW.M\
    ICROCENTERWEB.COM.BR ===\r\
    \n" disabled=no new-connection-mark=conexao-p2p p2p=all-p2p passthrough=\
    yes
    conexao-p2p disabled=no new-packet-mark=pacotes-p2p passthrough=yes
    add action=mark-routing chain=prerouting comment="" disabled=no \
    new-routing-mark=p2p p2p=all-p2p passthrough=no src-address=0.0.0.0/0
    add action=mark-packet chain=prerouting comment="=== MELHORIAS DO MSN ========\
    disabled=no dst-port=1863 new-packet-mark=msn_in passthrough=yes \
    protocol=tcp
    add action=mark-packet chain=prerouting comment="" disabled=no \
    new-packet-mark=msn_out passthrough=yes protocol=tcp src-port=1863
    add action=change-mss chain=forward comment="" disabled=no new-mss=1360 \
    protocol=tcp tcp-flags=syn
    add action=mark-packet chain=forward comment="=== MARCANCO OS PACOTES SEM LIMI\
    TE DE CONEXAO ==================SISTEMA===" disabled=\
    no dst-port=21 new-packet-mark=semlimite passthrough=yes protocol=tcp \
    add action=mark-packet chain=forward comment="" disabled=no dst-port=22 \
    new-packet-mark=semlimite passthrough=yes protocol=tcp src-address=\
    10.0.0.0/8
    add action=mark-packet chain=forward comment="" disabled=no dst-port=23 \
    10.0.0.0/8
    add action=mark-packet chain=forward comment="" disabled=no dst-port=25 \
    10.0.0.0/8
    add action=mark-packet chain=forward comment="" disabled=no dst-port=53 \
    10.0.0.0/8
    add action=mark-packet chain=forward comment="" disabled=no dst-port=110 \
    10.0.0.0/8
    add action=mark-packet chain=forward comment="" disabled=no dst-port=80 \
    10.0.0.0/8
    add action=mark-packet chain=forward comment="" disabled=no dst-port=443 \
    10.0.0.0/8
    add action=mark-packet chain=forward comment="" disabled=no dst-port=8080 \
    10.0.0.0/8
    add action=mark-packet chain=forward comment="" disabled=no dst-port=\
    6891-6901 new-packet-mark=semlimite passthrough=yes protocol=tcp \
    /ip firewall nat
    add action=masquerade chain=srcnat comment="NAT FULL" disabled=no
    add action=dst-nat chain=dstnat comment="PG CORTE" disabled=no protocol=tcp \
    src-address-list=pgcorte to-addresses=192.10.1.2 to-ports=85
    add action=dst-nat chain=hotspot comment="PG CORTE" disabled=no packet-mark=\
    bloqueado protocol=tcp to-addresses=192.10.1.2 to-ports=85
    add action=dst-nat chain=dstnat comment="DIRECIONAMENTO MK-AUTH" disabled=no \
    dst-port=8293 protocol=tcp to-addresses=192.10.1.2 to-ports=80
    add action=dst-nat chain=dstnat comment="AVISO REPARO" disabled=no protocol=\
    tcp src-address=10.0.0.0/8 src-port=80 to-addresses=192.10.1.2 to-ports=\
    89
    /ip firewall service-port
    set ftp disabled=no ports=21
    set tftp disabled=no ports=69
    set irc disabled=no ports=6667
    set h323 disabled=no
    set sip disabled=no ports=5060,5061
    set pptp disabled=no
  4. Citação Postado originalmente por alexandrecorrea Ver Post
    voce nao postou as configuracoes.. pode anexa-las ao topico
    Sistema2.txt
    Hoje consegui Alexandre eu tava tentando de todas as formas e nao ia sempre dava erro no envio eu dei uma mechida no load e agora foi.
  5. Opa alexandre esqueci de uma coisa antes quando minha rede nao tinha a separação por vlan eu fiz assim separei todas as rbs e ponto a ponto com uma classe de ip de 192.1.1.0/24 e todas as nanos e rbs que queria acessar coloco no hotspot ip bindings em bypassed, pois minha rede era 192.168.10.0/24 e agora com as vlans estao assim
    vlan1 10.0.0.0/24
    vlan2 10.0.1.0/24
    vlan3 10.0.2.0/24
    vlan4 10.0.3.0/24
    E todos os ponto a ponto e rbs nao fiz nenhuma alteração continua 192.1.1.0/24. Acho que assim ta mais explicado..
  1. Acesso RB a frente de outra RB
    Por chiquinho10 no fórum Redes
    Último Post: 13-09-2015, 15:37
  2. Respostas: 4
    Último Post: 07-08-2014, 13:51
  3. Respostas: 7
    Último Post: 07-12-2011, 15:47
  4. Respostas: 0
    Último Post: 07-01-2010, 09:24
  5. Acessar uma VPN dentro de outra VPN. Como ?
    Por thiagomz no fórum Servidores de Rede
    Último Post: 31-03-2004, 08:35
