  1. boa noite acompanhando o tópico eu tive uma curiosidade em sabe qual arquivo editar para colocar
    mais que 8 caraquiter na senha e qual linha do aquivo de configuração editar para habilitar parta aparecer
    para troca de pais porque alguns radios só libera se resetar ele e não deixa mais altere depois só se resetar
    revolta tem algum truque para isto ?
    system.cfg
    aaa.1.status=disabled
    wpasupplicant.status=enabled
    wpasupplicant.profile.1.network.1.ssid=XXXXXXXXXXXXXXX
    wpasupplicant.profile.1.network.1.psk=XXXXXXXXXXXXXXXXX
    wpasupplicant.profile.1.network.1.proto.1.name=RSN
    wpasupplicant.profile.1.network.1.pairwise.1.name=CCMP
    wpasupplicant.profile.1.network.1.key_mgmt.1.name=WPA-PSK
    wpasupplicant.profile.1.network.1.eap.1.status=disabled
    wpasupplicant.profile.1.network.1.bssid=
    wpasupplicant.profile.1.name=WPA-PSK
    wpasupplicant.device.1.status=enabled
    wpasupplicant.device.1.profile=WPA-PSK
    wpasupplicant.device.1.driver=madwifi
    wpasupplicant.device.1.devname=ath0
    wireless.status=enabled
    wireless.1.wds.status=enabled
    wireless.1.status=enabled
    wireless.1.ssid=XXXXXXXXXXXXXXX
    wireless.1.security.type=none
    wireless.1.scan_list.status=disabled
    wireless.1.scan_list.channels=
    wireless.1.macclone=disabled
    wireless.1.hide_ssid=disabled
    wireless.1.devname=ath0
    wireless.1.authmode=1
    wireless.1.ap=
    wireless.1.addmtikie=enabled
    vlan.status=disabled
    users.status=enabled
    users.2.status=disabled
    users.1.status=enabled
    users.1.password=XXXXXXXXXXXXXXX
    users.1.name=XXXXXXXXXXXXXXX
    update.check.status=disabled
    telnetd.status=disabled
    system.timezone=GMT
    system.longitude=
    system.latitude=
    system.eirp.status=enabled
    system.date.timestamp=
    system.date.status=disabled
    system.cfg.version=65539
    system.button.reset=enabled
    syslog.status=enabled
    syslog.remote.status=
    sshd.status=enabled
    sshd.port=22
    sshd.auth.passwd=enabled
    snmp.status=enabled
    snmp.location=XXXXXXXX
    snmp.contact=XXXXXXXXXX
    snmp.community=public
    route.status=enabled
    route.1.status=enabled
    route.1.netmask=0
    route.1.ip=0.0.0.0
    route.1.gateway=XXXXXXXXXXXX
    route.1.devname=br0
    route.1.comment=
    resolv.status=disabled
    resolv.nameserver.status=enabled
    resolv.nameserver.2.status=disabled
    resolv.nameserver.2.ip=
    resolv.nameserver.1.status=enabled
    resolv.nameserver.1.ip=XXXXXXXXXXXX
    resolv.host.1.status=enabled
    resolv.host.1.name=Bullet M5
    radio.status=enabled
    radio.countrycode=511
    radio.1.txpower=25
    radio.1.subsystemid=0xe205
    radio.1.status=enabled
    radio.1.reg_obey=disabled
    radio.1.rate.mcs=7
    radio.1.rate.auto=enabled
    radio.1.pollingpri=
    radio.1.pollingnoack=0
    radio.1.polling=enabled
    radio.1.obey=disabled
    radio.1.mode=managed
    radio.1.mcastrate=7
    radio.1.low_txpower_mode=disabled
    radio.1.ieee_mode=11naht40
    radio.1.forbiasauto=0
    radio.1.dfs.status=enabled
    radio.1.devname=ath0
    radio.1.cwm.mode=1
    radio.1.cwm.enable=0
    radio.1.countrycode=511
    radio.1.clksel=1
    radio.1.chanshift=0
    radio.1.chanbw=0
    radio.1.cable.loss=0
    radio.1.antenna.id=
    radio.1.antenna.gain=0
    radio.1.acktimeout=25
    radio.1.ackdistance=600
    radio.1.ack.auto=enabled
    pwdog.status=disabled
    ppp.status=disabled
    ntpclient.status=disabled
    netmode=bridge
    netconf.status=enabled
    netconf.3.up=enabled
    netconf.3.status=enabled
    netconf.3.role=mlan
    netconf.3.netmask=255.255.255.0
    netconf.3.mtu=1500
    netconf.3.ip=XXXXXXXXXXXXXX
    netconf.3.hwaddr.status=disabled
    netconf.3.hwaddr.mac=
    netconf.3.devname=br0
    netconf.3.autoip.status=disabled
    netconf.2.up=enabled
    netconf.2.status=enabled
    netconf.2.role=bridge_port
    netconf.2.promisc=enabled
    netconf.2.netmask=255.255.255.0
    netconf.2.mtu=1500
    netconf.2.ip=0.0.0.0
    netconf.2.hwaddr.status=disabled
    netconf.2.hwaddr.mac=
    netconf.2.devname=ath0
    netconf.2.autoip.status=disabled
    netconf.2.allmulti=enabled
    netconf.1.up=enabled
    netconf.1.status=enabled
    netconf.1.role=bridge_port
    netconf.1.promisc=enabled
    netconf.1.netmask=255.255.255.0
    netconf.1.mtu=1500
    netconf.1.ip=0.0.0.0
    netconf.1.hwaddr.status=disabled
    netconf.1.hwaddr.mac=
    netconf.1.devname=eth0
    netconf.1.autoip.status=disabled
    httpd.status=enabled
    httpd.session.timeout=900
    httpd.port=80
    httpd.https.status=disabled
    gui.language=en_US
    ebtables.sys.status=enabled
    ebtables.sys.eap.status=enabled
    ebtables.sys.eap.1.status=enabled
    ebtables.sys.eap.1.devname=ath0
    ebtables.sys.arpnat.status=disabled
    ebtables.sys.arpnat.1.status=enabled
    ebtables.sys.arpnat.1.devname=ath0
    ebtables.status=enabled
    dyndns.status=disabled
    discovery.status=enabled
    discovery.cdp.status=enabled
    dhcpd.status=disabled
    dhcpc.status=disabled
    dhcpc.1.status=disabled
    dhcpc.1.devname=br0
    bridge.status=enabled
    bridge.1.stp.status=disabled
    bridge.1.status=enabled
    bridge.1.port.2.status=enabled
    bridge.1.port.2.devname=ath0
    bridge.1.port.1.status=enabled
    bridge.1.port.1.devname=eth0
    bridge.1.fd=1
    bridge.1.devname=br0
    aaa.status=disabled
    aaa.1.wpa.psk=XXXXXXXXXXXXXX
    ESTA é a estrutura do aquivo mais onde esta xxxxxxx é que apaguei as minha configura soes de ssid e chave e usuário e senha .
  2. Citação Postado originalmente por adrianofante Ver Post
    Bem pessoal, acredito que quase todo mundo já teve a necessidade de acessar algum equipamento ubiquiti por SSH, principalamente quando o sinal do equipamento está muito baixo, ai não tem jeito de acessar pela web.
    Abaixo reuni os comandos básicos (básicos mesmo) para que seje possível alterar as configurações:
    1º Acesse o equipamento através de algum programa SSH (putty por exemplo) meio óbivio isso né?!! massss....enfim..
    comando cd para acessar uma pasta
    comando ls lista os arquivos ou subpastas da pasta
    alterar uma configuração..ssid, nome do dispositivo, ip, etc....editar o arquivo system.cfg com o comando
    vi /tmp/system.cfg
    va até a linha q quer alterar e digite i depois para sair e salvar aperte ESC depois digite :wq
    para sair sem salvar nada aperte ESC depois digite :q
    e depois de alterado o que for necessário reiniciar o equipamento para aplicar as configurações com o comando abaixo:
    primeiro: save
    depois: /usr/etc/rc.d/rc.softrestart save
    acessar a pasta que contém quem pegou ip por dhcp
    cd /etc/persistent
    depois o comando tail -f leases.1.eth0
    commando para mostrar o sinal.
    ./usr/www/signal.cgi
    Tem que estar na pasta padrão, para entrar na pasta padrão digite cd /
    Scanear redes
    wlanconfig ath0 list scan ou iwlist ath0 scan
    Status da conexão sem fio
    wlanconfig ath0 list sta
    Outros commandos uteis para ath0 (interface sem fio)
    iwlist [interface] scanning [essid NNN] [last]
    [interface] frequency
    [interface] channel
    [interface] bitrate
    [interface] rate
    [interface] encryption
    [interface] keys
    [interface] power
    [interface] txpower
    [interface] retry
    [interface] ap
    [interface] accesspoints
    [interface] peers
    [interface] event
    [interface] auth
    [interface] wpakeys
    [interface] genie
    [interface] modulation
    Bem pessoal isso é o básico, porém já ajuda bastante.
    Qualquer dúvida postem ai, pra não virar bagunça com um monte de posts caso alguém queira inserir mais comandos me envia por MP que edito e dou os devidos créditos.
    T+ espero que ajude!
    Olá amigo adorei o seu POst quero aprender mais se vc poder estar postando mais alguns código via SSH eu agradeceria =D
    se precisar de algo!. =D
    agradeço desde já!
  3. QUANDO EU ENTRO COM O COMANDO vi /tmp/system.cf E
    e vou em countrycode e mudo pra 76 que é brasil e aperto esc ele sai e depois aperto wq não salva da um mensagem q not implement
    não salva de jeito algum alguem poderia ajudar
  4. Citação Postado originalmente por CherosoX Ver Post
    Olá amigo se vc ta colocando só (( wq )) é por isso que esta dando esta mensagem tem que colocar os (( : )) fica assim: (( :wq )) tenta ai.
    Abraço'! =D
  5. muito obrigado me salvou estava esquecendo do : obrigado
  1. Mini Tutorial - Comandos Básicos Ubiquiti - SSH
    Por adrianofante no fórum Redes
    Respostas: 15
    Último Post: 12-03-2015, 15:08
  2. UBIQUITI - Tutorial Comandos SSH
    Por interhome no fórum Redes
    Último Post: 21-05-2013, 14:36
  3. Mikrotik - Tutorial Manual básico
    Por rockeiromaiden no fórum Redes
    Respostas: 5
    Último Post: 18-06-2007, 20:44
  4. Comandos básicos SQL
    Por shinzo no fórum Servidores de Rede
    Último Post: 15-03-2006, 07:51
  5. duvida sobre um comando (basico)
    Último Post: 06-03-2003, 15:14
