    Padrão problema load balance com hotmail e yahoo
    pessoal tenho rb 450g com 4 linhas, estou usando both-addresses soque tem hora nao consigo entrar no email do hotmail e do yahoo e tem horas q entrar normal, alguem ja teve mesmo problema como foi resolveu ??
    Padrão Re: problema load balance com hotmail e yahoo
    Olha colega,tbm com o mesmo problema no hotmail,ainda nao consegui resolver!!!
    Apr 2011
    Qual a Ballance que vocês usam, eu uso o PCC e ainda não tive esse problema "pelo menos nas vezes que entro" e nenhum cliente chegou a reclamar nada sobre isso...
    /ip firewall mangle
    add action=accept chain=prerouting comment=EXCESSOES disabled=no \
    dst-address-list=loopback in-interface=saida
    add action=accept chain=prerouting comment="" disabled=no dst-address-list=\
    SafeSite in-interface=saida
    add action=accept chain=prerouting comment="" disabled=no dst-port=443 \
    in-interface=saida protocol=tcp
    add action=mark-connection chain=input comment="MARCAR ENTRADAS" disabled=no \
    in-interface=pppoe-wan1 new-connection-mark=ISP1_conn passthrough=yes
    add action=mark-connection chain=input comment="" disabled=no in-interface=\
    pppoe-wan2 new-connection-mark=ISP2_conn passthrough=yes
    pppoe-wan3 new-connection-mark=ISP3_conn passthrough=yes
    pppoe-wan4 new-connection-mark=ISP4_conn passthrough=yes
    add action=mark-routing chain=output comment="MARCAR SAIDAS (LB to SAIDA)" \
    connection-mark=ISP1_conn disabled=no new-routing-mark=to_ISP1 \
    passthrough=yes
    add action=mark-routing chain=output comment="" connection-mark=ISP2_conn \
    disabled=no new-routing-mark=to_ISP2 passthrough=yes
    add action=mark-routing chain=output comment="" connection-mark=ISP3_conn \
    disabled=no new-routing-mark=to_ISP3 passthrough=yes
    add action=mark-routing chain=output comment="" connection-mark=ISP4_conn \
    disabled=no new-routing-mark=to_ISP4 passthrough=yes
    add action=mark-connection chain=prerouting comment=\
    "MARCAR ROUND-ROBIN (8 canais) (ESSE OU O DE BAIXO)" connection-state=\
    new disabled=no dst-address-type=!local in-interface=saida \
    new-connection-mark=ISP2_conn passthrough=yes per-connection-classifier=\
    both-addresses:4/0
    add action=mark-connection chain=prerouting comment="" connection-state=new \
    new-connection-mark=ISP3_conn passthrough=yes per-connection-classifier=\
    both-addresses:4/1
    new-connection-mark=ISP4_conn passthrough=yes per-connection-classifier=\
    both-addresses:4/2
    new-connection-mark=ISP1_conn passthrough=yes per-connection-classifier=\
    both-addresses:4/3
    add action=mark-routing chain=prerouting comment=\
    "MARCAR ROTA SAIDA( RETORNO PACOTE)" connection-mark=ISP1_conn disabled=\
    no in-interface=saida new-routing-mark=to_ISP1 passthrough=yes
    add action=mark-routing chain=prerouting comment="" connection-mark=\
    ISP2_conn disabled=no in-interface=saida new-routing-mark=to_ISP2 \
    passthrough=yes
    ISP3_conn disabled=no in-interface=saida new-routing-mark=to_ISP3 \
    passthrough=yes
    ISP4_conn disabled=no in-interface=saida new-routing-mark=to_ISP4 \
    passthrough=yes
    add action=change-mss chain=forward comment="Mudar MMS - MSN" disabled=no \
    new-mss=1380 out-interface=saida protocol=tcp tcp-flags=syn
    /ip route
    add comment="" disabled=no distance=4 dst-address=0.0.0.0/0 gateway=\
    pppoe-wan1 routing-mark=to_ISP1 scope=30 target-scope=10
    add comment="" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=\
    pppoe-wan2 routing-mark=to_ISP2 scope=30 target-scope=10
    add comment="" disabled=no distance=3 dst-address=0.0.0.0/0 gateway=\
    pppoe-wan3 routing-mark=to_ISP3 scope=30 target-scope=10
    add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
    pppoe-wan4 routing-mark=to_ISP4 scope=30 target-scope=10
    add check-gateway=ping comment="" disabled=no distance=1 dst-address=\
    0.0.0.0/0 gateway=pppoe-wan3 scope=30 target-scope=10
    add check-gateway=ping comment="" disabled=no distance=2 dst-address=\
    0.0.0.0/0 gateway=pppoe-wan2 scope=30 target-scope=10
    add check-gateway=ping comment="" disabled=no distance=3 dst-address=\
    0.0.0.0/0 gateway=pppoe-wan1 scope=30 target-scope=10
    add check-gateway=ping comment="" disabled=no distance=4 dst-address=\
    0.0.0.0/0 gateway=pppoe-wan4 scope=30 target-scope=10
    Citação Postado originalmente por robertopc95 Ver Post
    Você tem que cria uma regra para pode passa por fora qualquer coisa me add
    que conversamos.
    Sds. Anderson souza silva
    Graduando em Redes de Computadores pela Unijorge/Salvador - BA
    Contato: 71 8624 9467 / e-mail: [email protected] / Skype: anderson.souza.sillva
    Me Add no msn q te ajudo a resolver
    [email protected]
    Cara uso o PCC aqui e também sem problemas, adicionei os endereços do yahoo e hotmail no address list para que eles não fossem balanceados, mais vi que o yahoo tava lento, funcionando mais lento, então adicionei uma rota estática para ele e ta tudo 100%
    Rapaz eu usava o PCC, mais fui obrigado a montar um BrazilFW para balancear, além dele somar os links não tenho problema com nenhum site, é show, um dica mude para o Brazilfw não vai se arrepender!!!
    sera q BrazilFW funciona em una rb ??
    Não só funciona em um pc mesmo, mais o bacana dele é que não precisa de mais de duas placas de rede, usa apenas swit!!!
    Bom aqui sempre usei load PCC 4 links e nunca tive problema nenhum sistema 100% estavel.
    mais um amigo daqui do fórum estava com esse problema ele resolveu e me disse que estava dando problema com hotmail por falta das regras change MSS das conexões PPPoE que não eram criadas no FIREWALL MANGLE depois disso ele falo que voltou a abrir normal
    Citação Postado originalmente por freitascs Ver Post
    como ficaria essa regra ???
    Usei isso no meu ballance aqui, ele ballanceia 5 link em bridge, achei aqui nos forum mesmo
    /ip firewall mangle
    add action=change-mss chain=forward comment="" disabled=no new-mss=1380 protocol=tcp tcp-flags=syn
    coloquei ela no topo acima te todas e o yahoo tem que jogar ele por fora do balance
    Citação Postado originalmente por SpeedNetWifi Ver Post
    Sobre as liberações de porta ? estou tendo problemas com o winbox, já vi por aqui a turma pedindo o dmz
