    Question Configuracao Cisco 2801
    Boa noite,
    Estou encontrando uma grande dificuldade em configura dois link embratel no cisco 2801, segue a configuracao abaixo que fiz,
    onde e q estou errando?, alguem poderia me ajudar?
    Agradeço,
    service timestamps debug datetime msec
    service timestamps log datetime msec
    service password-encryption
    hostname ERS
    boot-start-marker
    boot-end-marker
    enable secret 5 $1$blQm$LudWIFbANJ/
    no aaa new-model
    ip cef
    ip name-server 8.8.8.8
    ip name-server 8.8.4.4
    voice-card 0
    interface FastEthernet0/0
    ip address 189.xxx.xxx.62 255.255.255.240
    no ip redirects
    no ip mroute-cache
    duplex auto
    speed auto
    no cdp enable
    interface FastEthernet0/1
    no ip address
    no ip redirects
    no ip mroute-cache
    speed 100
    full-duplex
    interface Serial0/3/0
    ip address 200.xxx.xxx.2 255.255.255.252
    encapsulation ppp
    interface Serial0/3/1
    no ip address
    shutdown
    ip route 0.0.0.0 0.0.0.0 200.xxx.xxx.1
    no ip mroute-cache
    duplex auto
    speed auto
    no cdp enable
    no ip http server
    no ip http secure-server
    snmp-server community mac RO
    control-plane
    line con 0
    password 7 114836352341
    login
    line aux 0
    line vty 0 4
    password 7 015029346F30F
    login
    scheduler allocate 20000 1000
    end
    #########################LOG SERIAL##########################
    Serial0/3/0 is up, line protocol is up
    Hardware is GT96K Serial
    Internet address is 200.xxx.xxx.2/30
    MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
    reliability 255/255, txload 1/255, rxload 1/255
    Encapsulation PPP, LCP Open
    Listen: IPCP, CDPCP, loopback not set
    Keepalive set (10 sec)
    Last input 06:58:01, output 00:00:02, output hang never
    Last clearing of "show interface" counters 06:58:28
    Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
    Queueing strategy: weighted fair
    Output queue: 0/1000/64/0 (size/max total/threshold/drops)
    Conversations 0/1/256 (active/max active/max total)
    Reserved Conversations 0/0 (allocated/max allocated)
    Available Bandwidth 1158 kilobits/sec
    5 minute input rate 0 bits/sec, 0 packets/sec
    5 minute output rate 0 bits/sec, 0 packets/sec
    4961 packets input, 79408 bytes, 0 no buffer
    Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
    0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
    4961 packets output, 79374 bytes, 0 underruns
    0 output errors, 0 collisions, 1 interface resets
    0 output buffer failures, 0 output buffers swapped out
    0 carrier transitions
    DCD=up DSR=up DTR=up RTS=up CTS=up
    Padrão Re: Configuracao Cisco 2801
    explica ai quais sao as interfaces.. onde sao os links.. etc
    tem um shutdown lai na 0/3/0 !!
    tem q fazer um "no shutdown"
    Estes link´s são balanceados pela operadora? caso sim qual tipo de balanceamento esta sendo usado, que tipo de protocolo também, todas estas informações são repassadas pela operadora e tem que ser configuradas no router, a primeira coisa que você esta precisando é ter todas estas informações para depois configurar corretamente.
    Sds,
    Você vai deixar os dois links em load balance ou o segundo como contingência? Vai precisar adicionar mais uma rota default para o o outro link. Posta toda config.
    Alexandre,
    Os dois link estao instalados na serial 0/3/0 e ja fiz o no shutdown.
    Tronoloni, quero usar os dois link totalizando 4 mb.
    rwidal,
    nao recebei nenhuma desta informacoes, vou ligar amanha para saber sobre estas informacoes.
    como a operadora entrega os linkś, modens separados fibra optica fastethernet precisa usaras 2 interfaces sabendo o tipo de interfaces usadas e onde elas estão conectadas e os protocolos usados, ajudaremos mais
    Citação Postado originalmente por flaviorn Ver Post
    Operadora, Embratel, sao dois modens ligado a serial 0/3/0, protocolo e ppp.
    por conicidencia eu tenh oum cisco deste pra vender se alguem estiver interessado estou torrando ele, faço qualquer negocio, o meu ta com 4 serias.
    nao pode ligar os dois modens na mesma serial, e um em cada, e cada modem tem que ter um ip, pra porta que ele vai estar ligado, depois que vc tiver feito isso e pingando os dois ips das duas portas de fora ai vc ativa o balanceamento, isso tem que ser feito em conjunto com a operadora.
    acho que o melhor seria vc arumar alguem pra configurar pra vc, o cisco nao pode ficar mal configurado que uma hora ele vai começar a te dar problemas e vc nunca vai achar o problema.
    Ja estou com todos os dados, alguem poderia me ajudar a configura?
    balanciamento: multlink
    protocolo: ppp
    modem: 2 ligado na serial 0/3/0 e 0/3/1
    Grato,
    ja ta configurado os ips? qual vai ser o tipo de balanceamento, ja ta pronto na operadora? passa as informaçoes ai! ja configura os ips nas portas, e faz testes, vc vai receber dois ips por porta por link, um fica no seu roteador outro no da operadora, configura o ip da porta do seu roteador e vc se vc consegue pingar o ip da porta do roteador da operadora.
    me cadastra ai no msn ulissescampos at hot
    precisa de ajuda ainda?
    Citação Postado originalmente por DanielVieceli775 Ver Post
    Sim, ainda estou tendo dificuldade.
    Grato,
    então me fala bem certinho o que precisa e passa ips se for necessario, dai monto o arquivo vc copia e cola em seu router. abraço
    Bom dia Senhores,
    Pelo que sei a Embratel ativa por padrão todos os links com balanceamento PPP Multilink.
    A configuração e bem simples.
    VOce deverá configurar um interface multilink que será a interface que estará o ip de enlace:
    OBS: o numero da interface da multilink a embratel te passará
    CISCO#conf t
    CISCO#(config) interface multilink + numero da multilik
    CISCO#(config-if) ip address x.x.x.x x.x.x.x
    CISCO#(config-if) no shut
    CISCO#(config-if) exit
    CISCO#(config) ip route 0.0.0.0 0.0.0.0 multilink + numero da multilik # ROTA PADRAO
    CONFIGURAÇÃO DE INTERFACES SERIAIS
    CISCO#conf t
    CISCO#(config) interface serial x/x/x
    CISCO#(config-if)encapsulation ppp
    CISCO#(config-if)ppp multilink
    CISCO#(config-if)ppp multilink group + numero da multilik
    CISCO#
    (config-if) clock rate xxxxxxx ##( conferir clock rate com a embratel)
    Faça esta configuração nas duas seriais onde estão os links WAN da embratel.
    ATT
    Tiago Eduardo Zacarias
    LPIC-1
    Viva o Linux !!
