  1. / system logging
    add topics=info prefix="" action=memory disabled=no
    add topics=error prefix="" action=memory disabled=no
    add topics=warning prefix="" action=memory disabled=no
    add topics=critical prefix="" action=echo disabled=no
    add topics=web-proxy prefix="Proxy" action=remote disabled=no
    / system logging action
    set memory name="memory" target=memory memory-lines=100 \
    memory-stop-on-full=no
    set disk name="disk" target=disk disk-lines=100 disk-stop-on-full=no
    set echo name="echo" target=echo remember=yes
    set remote name="remote" target=remote remote=192.168.25.13:514
    / system upgrade mirror
    set enabled=no primary-server=0.0.0.0 secondary-server=0.0.0.0 \
    check-interval=1d user=""
    / system clock dst
    set dst-delta=+00:00 dst-start="jan/01/1970 00:00:00" dst-end="jan/01/1970 \
    00:00:00"
    / system watchdog
    set reboot-on-failure=no watch-address=none watchdog-timer=yes \
    no-ping-delay=5m automatic-supout=yes auto-send-supout=no
    / system console
    add port=serial0 term="" disabled=no
    set FIXME term="linux" disabled=no
    / system console screen
    set line-count=25
    / system identity
    set name="MikroTik"
    / system note
    set show-at-login=yes note=""
    / system lcd
    set enabled=no type=24x4 port=parallel contrast=0
    / system lcd page
    set time display-time=5s disabled=yes
    set resources display-time=5s disabled=yes
    set uptime display-time=5s disabled=yes
    set packets display-time=5s disabled=yes
    set bits display-time=5s disabled=yes
    set version display-time=5s disabled=yes
    set eth-Velox display-time=5s disabled=yes
    set eth-LAN display-time=5s disabled=yes
    set Velox display-time=5s disabled=yes
    / system ntp server
    set enabled=no broadcast=no multicast=no manycast=yes
    / system ntp client
    set enabled=no mode=unicast primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0
    / system routerboard bios
    set
    / system health
    set state-after-reboot=enabled
    / port
    set serial0 name="serial0" baud-rate=9600 data-bits=8 parity=none \
    stop-bits=1 flow-control=hardware
    / ppp profile
    set default name="default" session-timeout=30m idle-timeout=30m \
    use-compression=default use-vj-compression=default \
    use-encryption=default only-one=default change-tcp-mss=yes comment=""
    set default-encryption name="default-encryption" session-timeout=30m \
    idle-timeout=30m use-compression=default use-vj-compression=default \
    use-encryption=yes only-one=default change-tcp-mss=yes comment=""
    / ppp aaa
    set use-radius=no accounting=yes interim-update=0s
    / queue type
    set default name="default" kind=pfifo pfifo-limit=50
    set ethernet-default name="ethernet-default" kind=pfifo pfifo-limit=50
    set wireless-default name="wireless-default" kind=sfq sfq-perturb=5 \
    sfq-allot=1514
    set synchronous-default name="synchronous-default" kind=red red-limit=60 \
    red-min-threshold=10 red-max-threshold=50 red-burst=20 \
    red-avg-packet=1000
    set hotspot-default name="hotspot-default" kind=sfq sfq-perturb=5 \
    sfq-allot=1514
    add name="default-small" kind=pfifo pfifo-limit=10
    / queue simple
    add name="Carol" target-addresses=192.168.25.30/32 dst-address=0.0.0.0/0 \
    interface=all parent=none direction=both priority=8 \
    queue=default-small/default-small limit-at=0/0 max-limit=2000000/0 \
    total-queue=default-small time=0s-1d,sun,mon,tue,wed,thu,fri,sat \
    disabled=no
    / user
    add name="admin" group=full address=0.0.0.0/0 comment="system default user" \
    disabled=no
    / user group
    add name="read" policy=local,telnet,ssh,reboot,read,test,winbox,password,web,\
    !ftp,!write,!policy
    add name="write" policy=local,telnet,ssh,reboot,read,write,test,winbox,passwo\
    rd,web,!ftp,!policy
    add name="full" policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,win\
    box,password,web
    / user aaa
    set use-radius=no accounting=yes interim-update=0s default-group=read
    / radius incoming
    set accept=no port=1700
    / driver
    / snmp
    set enabled=no contact="" location=""
    / snmp community
    set public name="public" address=0.0.0.0/0 read-access=yes
    / tool bandwidth-server
    set enabled=yes authenticate=yes allocate-udp-ports-from=2000 \
    max-sessions=10
    / tool mac-server ping
    set enabled=yes
    / tool e-mail
    set server=0.0.0.0 from="<>"
    / tool sniffer
    set interface=all only-headers=no memory-limit=10 file-name="" file-limit=10 \
    streaming-enabled=no streaming-server=0.0.0.0 filter-stream=yes \
    filter-protocol=ip-only filter-address1=0.0.0.0/0:0-65535 \
    filter-address2=0.0.0.0/0:0-65535
    / tool graphing
    set store-every=5min
    / routing ospf
    set router-id=0.0.0.0 distribute-default=never redistribute-connected=no \
    redistribute-static=no redistribute-rip=no redistribute-bgp=no \
    metric-default=1 metric-connected=20 metric-static=20 metric-rip=20 \
    metric-bgp=20
    / routing ospf area
    set backbone area-id=0.0.0.0 type=default \
    translator-role=translate-candidate authentication=none \
    prefix-list-import="" prefix-list-export="" disabled=no
    / routing bgp
    set enabled=yes as=65530 router-id=0.0.0.0 redistribute-static=no \
    redistribute-connected=no redistribute-rip=no redistribute-ospf=no
    / routing rip
    set redistribute-static=no redistribute-connected=no redistribute-ospf=no \
    redistribute-bgp=no metric-static=1 metric-connected=1 metric-ospf=1 \
    metric-bgp=1 update-timer=30s timeout-timer=3m garbage-timer=2m
    Já aumentamos o tempo de espera do outlook nas máquinas, e nada;...
  2. vc consegue consectar no servidor via telnet?
    telnet servidor.com.br 110
    user seulogin@dominio.com.br
    pass suasenha
    se isso funcionar o problema está no outlook
  3. Segui esse link da locaweb:
    http://wiki.locaweb.com.br/pt-br/Tes...imento_via_POP
    Mas não consegui autenticar, tanto no mikrotik quanto no gvt
    Porém, não pode ser problema no outlook..
    Como eu disse tenho um link gvt... Quanto eu passo as máquinas para o gvt (sem o mikrotik) os emails funcionam que é uma beleza...
  4. Se sem passar pelo mikrotik funciona o problema está nas regras do firewall/nat. Somente o email não funciona? Se vc tentar utlizar outra porta, por exemplo ftp, não funciona também?
  5. Cara, as vezes funciona... 1 em um milhão de tentativas rs...
    Será que depois de uma certa quantidade de email ele bloqueia?
    Parece que o maior problema é quando chega anexo...
    Mas eu não entendo também porque o pop para..
    Será que é alguma config de internet
    Na navegação eu não sinto oscilação...
  1. Problemas com email do Zimbra Colaboration Switch
    Por LeoJfa no fórum Servidores de Rede
    Último Post: 06-08-2008, 15:43
  2. Varios Problemas com email - Postfix
    Por nilsonjr no fórum Servidores de Rede
    Último Post: 24-07-2006, 15:56
  3. problemas com email
    Por SnifferSp no fórum Servidores de Rede
    Último Post: 10-01-2006, 09:45
  4. Problemas com email
    Por mjusto no fórum Servidores de Rede
    Último Post: 25-11-2005, 10:33
  5. Problemas com EMAIL
    Último Post: 05-03-2003, 13:45
