  1. Então a distribuição é a que está no titulo Slackware - V14,
    Código HTML:
    <br>
    Versão do Squid é a 3.3.3 - http://www.squid-cache.org/Versions/v3/3.3/squid-3.3.3-20130418-r12525.tar.gz
    Código HTML:
    <br>
    access.log
    Código HTML:
    <br>
    acess.log
    Código HTML:
    <br>
    no
    arquivo "cache.log", segue as informações abaixo....
    Código HTML:
    <br>
    Squid Cache (Version 3.3.3): Terminated abnormally.CPU Usage: 0.007 seconds = 0.004 user + 0.003 sysMaximum Resident Size: 18336 KBPage faults with physical i/o: 02013/05/04 23:41:39 kid1| Starting Squid Cache version 3.3.3 for x86_64-unknown-linux-gnu...2013/05/04 23:41:39 kid1| Process ID 60922013/05/04 23:41:39 kid1| Process Roles: worker2013/05/04 23:41:39 kid1| With 1024 file descriptors available2013/05/04 23:41:39 kid1| Initializing IP Cache...2013/05/04 23:41:39 kid1| DNS Socket created at [::], FD 72013/05/04 23:41:39 kid1| DNS Socket created at 0.0.0.0, FD 82013/05/04 23:41:39 kid1| Adding domain homestation from /etc/resolv.conf2013/05/04 23:41:39 kid1| Adding nameserver 192.168.1.1 from /etc/resolv.conf2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_ACCESS_DENIED': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_CACHE_ACCESS_DENIED': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_CACHE_MGR_ACCESS_DENIED': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_FORWARDING_DENIED': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_NO_RELAY': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_CANNOT_FORWARD': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_READ_TIMEOUT': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_LIFETIME_EXP': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_READ_ERROR': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_WRITE_ERROR': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_CONNECT_FAIL': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_SECURE_CONNECT_FAIL': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_SOCKET_FAILURE': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_DNS_FAIL': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_URN_RESOLVE': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_ONLY_IF_CACHED_MISS': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_TOO_BIG': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_INVALID_RESP': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_UNSUP_HTTPVERSION': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_INVALID_REQ': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_UNSUP_REQ': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_INVALID_URL': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_ZERO_SIZE_OBJECT': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_PRECONDITION_FAILED': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_CONFLICT_HOST': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_FTP_DISABLED': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_FTP_UNAVAILABLE': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_FTP_FAILURE': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_FTP_PUT_ERROR': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_FTP_NOT_FOUND': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_FTP_FORBIDDEN': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_FTP_PUT_CREATED': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_FTP_PUT_MODIFIED': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_ESI': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_ICAP_FAILURE': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_GATEWAY_FAILURE': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_DIR_LISTING': (2) No such file or directory2013/05/04 23:41:39 kid1| '/usr/local/squid/share/errors/portuguese/ERR_SHUTTING_DOWN': (2) No such file or directory2013/05/04 23:41:39 kid1| Logfile: opening log /var/log/squid/access.log2013/05/04 23:41:39 kid1| WARNING: log parameters now start with a module name. Use 'stdio:/var/log/squid/access.log'FATAL: Cannot open '/var/log/squid/access.log' because the parent directory does not exist. Please create the directory.Squid Cache (Version 3.3.3): Terminated abnormally.CPU Usage: 0.007 seconds = 0.003 user + 0.004 sysMaximum Resident Size: 18336 KBPage faults with physical i/o: 0
  2. `pROBLEMA SOLUCIONADO..!!!!
  3. Já que o problema foi solucionado, coloque a aqui como você resolveu. Sua dúvida pode ser a de muitos outros membros.
    Ab, Duca.
  4. O problema foi solucionado apenas na configuração no arquivo squid.conf que /usr/local/squid/etc/squid.conf no arquivo tinha uma configuração que apontava exatamente aonde o erro constava que era '/usr/local/squid/share/errors/portuguese/', essa pasta foi criada por mim, mas no próprio erro dizia que não contia esses arquivos então fez um teste criei um arquivo vazio com touch ERR_ACCESS_DENIED, vi que o primeiro erro desapareceu, procurei então uma pasta pt-br e contia todos esses arquivo no squid.conf, existia uma váriavel que apontava para /usr/local/squid/share/errors/portuguese/ troquei e coloquei apenas pt-br, e funcionou,
    Obrigado a todos de qualquer forma pela a atenção e mais uma coisa vou continuar com slackware e não tenho preferência de trocar por uma outra... Obrigado a todos...
  1. Slackware + squid = contrl de banda
    Por odairhenr no fórum Sistemas Operacionais
    Respostas: 5
    Último Post: 13-10-2007, 07:14
  2. Squid No Slackware não carrega
    Por slake no fórum Servidores de Rede
    Último Post: 22-04-2006, 13:14
  3. squid do slackware 9.1
    Por bouncer no fórum Servidores de Rede
    Último Post: 04-01-2005, 10:45
  4. squid no slackware 10
    Por quecosuix no fórum Servidores de Rede
    Último Post: 30-07-2004, 14:09
  5. squid+iptables+proxy transparente+speedy home no Slackware 9
    Por peregrino no fórum Servidores de Rede
    Último Post: 22-01-2004, 11:37
