  1. Blz, posta o resultado aqui sim.... vai ser util pra muita gente...
    Detalhe, aqui utilizo ela com cerca de 900 clientes, e trafego abaixo de 150 MB...
    Vi relatos que a CCR trava/reboota/cai interface acima de 200 MB... esse não era o meu caso...
    Quando chegar a 200 MB eu posto aqui, se ela se manteve firme ou se deu pau...
    Abraco
  2. Aqui usamos BGP e chegamos n os 245mb sem problemas, cpu 4%
  3. Olha a resposta do pessoal da mikrotik, ainda não resolvi o problema, não fiz a atualização. Apenas desativei o snmp pra ver, e faz 4 dias e não anconteceu mais, estou acompanhado.
    Junior
    Hello, Please, (re-)download and (re-)install the latest build: http://www.mikrotik.com/download/sha...s-tile-6.5.npk http://www.mikrotik.com/download/sha...mipsbe-6.5.npk http://www.mikrotik.com/download/sha...mipsle-6.5.npk http://www.mikrotik.com/download/sha...owerpc-6.5.npk http://www.mikrotik.com/download/sha...os-x86-6.5.npk http://www.mikrotik.com/download/sha..._files_6.5.zip Changelog is here: http://www.mikrotik.com/download/sha...os_devnote.txt Report back with new supout.rif file if problem persist and new description if behavior changes If problem persist try to disable /snmp Regards, Janis Megis 10/04/2013 16:31 - Junior Bohn wrote:
    Warning: This message has had one or more attachments removed Warning: (msg-120951-25.html). Warning: Please read the "mailgwmikrotikcom-Attachment-Warning.txt"
    attachment(s)
    for more information. I have a CCR1036-12G-4S with RouterOS 6.4 with the following problem: Back in half it shows that this log is attached, and drop all connections pppoe, this ccr've attached the following devices: 2 sxt-g-5hng, 1 groove A-5HN, 1 hp ML350 server, and one gigabit switch TPLINK in all devices records this fall, also attached the log server and HP print screen of the log of the sxt. What could be the cause of this problem, if hardware please let me know, because that ccr is still under warranty. We have made various types of configuration and the problem remains. We run in this ccr: BGP, pppoe server. Thank you for your attention: Junior Bohn
  4. Bom pessoal, depois de atualizar para o routerOS 6.5 acho que resolveu o problema, depois de 7 dias não caiu mais, não precisou resetar nem nada, apenas fazer o upgrade.
    Obrigado a todos.
    Junior
    100% movido a linux
  5. Finalmente resolvemos.
    usavamos PPTP , desabilitamos e rock solid agora ros6.4
  1. Respostas: 21
    Último Post: 27-06-2015, 16:23
  2. Problema Com Link Down Link Up
    Por Wilksonsinesio no fórum Redes
    Último Post: 28-05-2015, 20:05
  3. Link Down e Link Up
    Por tecnet no fórum Redes
    Último Post: 08-01-2013, 19:16
  4. Respostas: 3
    Último Post: 10-06-2011, 19:06
  5. r8169: eth0: PHY reset until link up?
    Por aluisiogouveia no fórum Servidores de Rede
    Último Post: 19-12-2005, 13:05
