  1. bom dia senhores, alguem poderia me ajudar, fiz esse balance numa rb, porem dentro da rb tem net mas nao navega de maneira alguma.
    MikroTik RouterOS 6.34.3 (c) 1999-2015 http://www.mikrotik.com/
    /ip pool
    add name="P00L _DHCP" ranges=192.168.66.2
    add name=dhcp_pool1 ranges=0.0.0.2-255.255.255.254
    add name=dhcp_pool2 ranges=192.168.66.2
    /ip address
    add address=192.168.66.1/30 interface="wi-fi zone" network=192.168.66.0
    add address=192.168.1.2/24 interface="link 50mb modem roteado" network=192.168.1.0
    /ip dhcp-server
    add address-pool="P00L _DHCP" disabled=no interface="wi-fi zone" name=dhcp1
    /ip dhcp-server network
    add address=192.168.1.0/30 dns-server=192.168.1.1,208.67.222.222 gateway=192.168.1.1
    add address=192.168.66.0/30 gateway=192.168.66.1
    /ip dns
    set allow-remote-requests=yes cache-size=10240KiB max-udp-packet-size=512 servers=208.67.222.222,189.38.95.95
    /ip firewall filter
    add action=drop chain=output comment="XXX NAO ACETAR CONEX\D5ES INVALIDAS XXX" connection-state=invalid
    /ip firewall mangle
    add action=mark-connection chain=prerouting comment="XXX MARCA\C7\D5ES DE CONEXA\C7\D5ES XXX" in-interface="wi-fi zone" new-connection-mark=LINK1_CONN \
    per-connection-classifier=both-addresses-and-ports:3/0
    add action=mark-connection chain=prerouting in-interface="wi-fi zone" new-connection-mark=LINK2_CONN per-connection-classifier=both-addresses-and-ports:3/1
    add action=mark-connection chain=prerouting in-interface="wi-fi zone" new-connection-mark=LINK3_CONN per-connection-classifier=both-addresses-and-ports:3/2
    add action=mark-connection chain=prerouting comment="XXX ENTRADA E SAIDA CLIENTES PELO MESMO LINK XXX" in-interface="wi-fi zone" new-connection-mark=LINK1_OUT
    add action=mark-connection chain=prerouting in-interface="wi-fi zone" new-connection-mark=LINK2_OUT
    add action=mark-connection chain=prerouting in-interface="wi-fi zone" new-connection-mark=LINK3_OUT
    add action=mark-routing chain=prerouting comment="XXX MARCA\C7\D5ES ROTAS XXX" connection-mark=LINK1_CONN in-interface="wi-fi zone" new-routing-mark=LINK1_ROUT
    add action=mark-routing chain=prerouting connection-mark=LINK2_CONN in-interface="wi-fi zone" new-routing-mark=LINK2_ROUT
    add action=mark-routing chain=prerouting connection-mark=LINK3_CONN in-interface="wi-fi zone" new-routing-mark=LINK3_ROUT
    /ip firewall nat
    add action=masquerade chain=srcnat comment=NAT out-interface="!wi-fi zone"
    /ip route
    add distance=1 gateway=192.168.1.1 routing-mark=LINK1_ROUT
    add distance=1 gateway=pppoe-out15mb routing-mark=LINK2_ROUT
    add distance=1 gateway=pppoe-out10mb routing-mark=LINK3_ROUT
    add check-gateway=ping distance=1 gateway=192.168.1.1
    add check-gateway=ping distance=2 gateway=pppoe-out15mb
    add check-gateway=ping distance=3 gateway=pppoe-out10mb
    /ip service
    set telnet disabled=yes
    set ftp disabled=yes
    set ssh disabled=yes
    set api disabled=yes
    set api-ssl disabled=yes
    [admin@BALANCE NOVO] /ip>
  2. Pessoal, eu to com dois links roteados, um de 10 mega e outro de 3 mega, eu fiz
    3 marcações para o link de 10 e 1 marcação para o link de 3 mega, para o balance eu usei uma regra que eu peguei hoje no site da mikrotik, o meu problema é que só ta usando a carga do link 1 e o link 2 só entra em ação se eu irar o cabo do link 1
    abaixo esta minha configuração do balance PCC:
    /interface ethernet
    set [ find default-name=ether1 ] name=ISP1
    set [ find default-name=ether2 ] name=ISP2
    set [ find default-name=ether3 ] name=LAN
    /ip pool
    add name=dhcp_pool1 ranges=192.168.20.2-192.168.20.254
    /ip dhcp-server
    add address-pool=dhcp_pool1 disabled=no interface=LAN name=dhcp1
    /ip address
    add address=192.168.20.1/24 interface=LAN network=192.168.20.0
    add address=172.0.0.2/24 interface=ISP1 network=172.0.0.0
    add address=10.0.0.2/24 interface=ISP2 network=10.0.0.0
    add address=192.168.20.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.20.1
    /ip firewall mangle
    add chain=prerouting comment="****** FORA DO BALANCE ******" dst-port=443 in-interface=LAN protocol=tcp
    add chain=prerouting comment="****** ACEITAR TRAFEGO DA REDE INTERNA ******" dst-address=172.0.0.0/24 in-interface=LAN
    add chain=prerouting dst-address=10.0.0.0/24 in-interface=LAN
    add action=mark-connection chain=prerouting comment="****** MARCA\C7\C3O LINK1 E LINK2 ******" connection-mark=no-mark in-interface=ISP1 new-connection-mark=ISP1_conn
    add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=ISP2 new-connection-mark=ISP2_conn
    add action=mark-connection chain=prerouting comment="****** DIVISAO DE CARGAS LINK 10MEGA ******" connection-mark=no-mark dst-address-type=!local in-interface=LAN new-connection-mark=ISP1_conn \
    per-connection-classifier=both-addresses:4/0
    add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-type=!local in-interface=LAN new-connection-mark=ISP1_conn per-connection-classifier=both-addresses:4/1
    add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-type=!local in-interface=LAN new-connection-mark=ISP1_conn per-connection-classifier=both-addresses:4/2
    add action=mark-connection chain=prerouting comment="****** DIVISAO DE CARGAS LINK 3MEGA ******" connection-mark=no-mark dst-address-type=!local in-interface=LAN new-connection-mark=ISP2_conn \
    per-connection-classifier=both-addresses:4/3
    add action=mark-routing chain=prerouting comment="******MARCA\C7\C3O DE ROTAS DE ENTRADA ******" connection-mark=ISP1_conn in-interface=LAN new-routing-mark=to_ISP1
    add action=mark-routing chain=prerouting connection-mark=ISP2_conn in-interface=LAN new-routing-mark=to_ISP2
    add action=mark-routing chain=output comment="******MARCA\C7\C3O DE ROTAS DE SA\CDDA ******" connection-mark=ISP1_conn new-routing-mark=to_ISP1
    add action=mark-routing chain=output connection-mark=ISP2_conn new-routing-mark=to_ISP2
    /ip firewall nat
    add action=masquerade chain=srcnat out-interface=ISP1
    add action=masquerade chain=srcnat out-interface=ISP2
    /ip route
    add check-gateway=ping distance=1 gateway=172.0.0.1 routing-mark=to_ISP1
    add check-gateway=ping distance=1 gateway=10.0.0.1 routing-mark=to_ISP2
    add check-gateway=ping distance=2 gateway=10.0.0.1
    o que tem de errado que nao ta acontecendo a divisao dos links ?
  3. Citação Postado originalmente por telthebest Ver Post
    /ip pool
    /ip address
    /ip dhcp-server
    /ip dns
    /ip firewall filter
    /ip firewall mangle
    /ip firewall nat
    /ip route
    /ip service
    ja conseguiu por pra navegar ?
  4. Citação Postado originalmente por telthebest Ver Post
    /ip pool
    /ip address
    /ip dhcp-server
    /ip dns
    /ip firewall filter
    /ip firewall mangle
    /ip firewall nat
    /ip route
    /ip service
    desculpa por nao ter respondido antes, é que eu só fui entrar hoje no under linux
    enquanto ao seu balance eu nao vou poder te ajudar, pois eu também to aprendendo a fazer balanceamento, mas enquanto a navegação, tente fazer isso pra ver se navega:
    vai em ip address e apague o ip que ta na interface que vai distribuir o dhcp na sua rede
    e depois em new terminal, acrecente essa regra:
    só que voce precisa editar a regra abaixo, onde esta "LAN", voce coloca o nome que ta na interface que vai distribuir o dhcp
    /ip address
    add address=192.168.66.1/24 interface=LAN network=192.168.20.0
    em ip pool voce apaga os pool que voce tem e depois vai em new terminal e jogue essa regra:
    /ip pool
    add name=dhcp_pool1 ranges=192.168.66.2-192.168.66.254
    em ip dhcp-server voce apaga os servidor que voce tem criado e joga essa regra em new terminal:
    lembrando de editar antes de jogar em new terminal. onde ta "LAN", voce cola o nome da interface que vai distribuir o seu dhcp
    /ip dhcp-server
    em ip dhcp-server network voce apaga o que voce tem aí e depois joga essa regra em new terminal:
    add address=192.168.66.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.66.1
    depois vai em ip firewall nat e apague os nat que tiver na sua rb, depois vai em new terminal e joga essa regra:
    lembrando de editar a regra antes de jogar em new terminal, onde ta "ISP1", voce cola o nome da interface onde esta conectado o seu modem 1 e onde ta "ISP2" você cola o nome da interface onde esta conectado o seu modem 2, se for modem em bridge voce tem que coloca o nome que ta no discador pppoe cliente da sua rb
    exemplo "pppoe-out1" para o modem 1 e "pppoe-out2" para modem 2, cada regra com o seu devido nome do pppoe cliente
    /ip firewall nat
    agora por ultimo pra finalizar
    troque os ips, onde ta "192.168.1.1", voce coloca o ip do seu modem 1 e onde ta "192.168.2.1", voce coloca o ip do seu modem 2
    /ip route
    add comment=rota_modem1 distance=1 gateway=192.168.1.1
    add comment=rota_modem2 distance=1 gateway=192.168.2.1
    lembrando que se seu modem tiver em bridge e voce tiver marcado a opçao de default router no pppoe cliente da sua rb, entao esse ultimo passo voce nao precisa fazer.
    comenta aí se isso resolveu o seu problema pra que possamos ajudar em algo mais
  5. boa tarde pessoal sou novo no forum estou com balance aqui que beguei um becap com um amigo porem o mesmo nao esta funcionando tao bem gostaria de comfigurar um do zero para 4 links velox de 15mb e com modens em bridge se alguem poder da uma força eu agradeço muito
  1. Load balance pcc com links ip dinamico , como fazer?
    Por julinribeiro no fórum Redes
    Respostas: 21
    Último Post: 25-10-2017, 08:41
  2. Mini Balance PCC com Failover automático
    Por AndrioPJ no fórum Tutoriais
    Respostas: 149
    Último Post: 11-08-2017, 08:31
  3. Respostas: 35
    Último Post: 01-07-2016, 12:22
  4. Mini Balance PCC com Failover automático
    Por AndrioPJ no fórum Redes
    Respostas: 119
    Último Post: 29-06-2015, 11:00
  5. Load Balance pcc com Lentidão!
    Por maninho03 no fórum Redes
    Respostas: 26
    Último Post: 24-07-2012, 08:46
