    Padrão Freeradius e AD + Routerboard Hotspot
    Estou implementando um Freeradius validando os usuario num ACtive diretory MS 2008 R2.
    Configurei o Freeradius e testei pelo radtest. funcionou blz.
    tela de saida
    radtest -t mschap [email protected] SENHA localhost 0 teste123
    Sending Access-Request of id 111 to 127.0.0.1 port 1812
    User-Name = "[email protected]"
    NAS-IP-Address = 10.25.153.51
    NAS-Port = 0
    Message-Authenticator = 0x00000000000000000000000000000000
    MS-CHAP-Challenge = 0x1529e5b05742be4f
    MS-CHAP-Response = 0x0001000000000000000000000000000000000000000000000000f872e7dc44ff2075065bd7849ef3cd5ca32d6fe4f919e7da
    rad_recv: Access-Accept packet from host 127.0.0.1 port 1812, id=111, length=20
    Agora quando mando pelo Hotspot da routerboard sai esse mensagem no Log
    rad_recv: Access-Request packet from host 10.25.152.252 port 42438, id=17, length=238
    NAS-Port-Type = Ethernet
    Calling-Station-Id = "00:E0:4E:21:CF:5A"
    Called-Station-Id = "hotspot1"
    NAS-Port-Id = "ether5"
    MS-CHAP-Domain = "XXXXXXXXXXXXXX"
    NAS-Port = 2153775110
    Acct-Session-Id = "80600006"
    Framed-IP-Address = 10.5.50.254
    Mikrotik-Host-IP = 10.5.50.254
    User-Password = "SENHA"
    Service-Type = Login-User
    WISPr-Logoff-URL = "http://10.5.50.1/logout"
    NAS-Identifier = "RouterOS"
    Mikrotik-Realm = "XXXXXXXXXXXXXX"
    NAS-IP-Address = 10.25.152.252
    # Executing section authorize from file /etc/freeradius/sites-enabled/default
    +- entering group authorize {...}
    ++[preprocess] returns ok
    [auth_log] expand: /var/log/freeradius/radacct/%{Client-IP-Address}/auth-detail-%Y%m%d -> /var/log/freeradius/radacct/10.25.152.252/auth-detail-20140222
    [auth_log] /var/log/freeradius/radacct/%{Client-IP-Address}/auth-detail-%Y%m%d expands to /var/log/freeradius/radacct/10.25.152.252/auth-detail-20140222
    [auth_log] expand: %t -> Sat Feb 22 05:58:17 2014
    ++[auth_log] returns ok
    ++[chap] returns noop
    ++[mschap] returns noop
    ++[digest] returns noop
    [suffix] Looking up realm "XXXXXXXXXXXXXX" for User-Name = "[email protected]"
    [suffix] Found realm "XXXXXXXXXXXXXX"
    [suffix] Adding Stripped-User-Name = "radius"
    [suffix] Adding Realm = "XXXXXXXXXXXXXX"
    [suffix] Authentication realm is LOCAL.
    ++[suffix] returns ok
    [eap] No EAP-Message, not doing EAP
    ++[eap] returns noop
    ++[files] returns noop
    ++[expiration] returns noop
    ++[logintime] returns noop
    [pap] WARNING! No "known good" password found for the user. Authentication may fail because of this.
    ++[pap] returns noop
    ERROR: No authenticate method (Auth-Type) found for the request: Rejecting the user
    Failed to authenticate the user.
    Using Post-Auth-Type Reject
    # Executing group from file /etc/freeradius/sites-enabled/default
    +- entering group REJECT {...}
    [attr_filter.access_reject] expand: %{User-Name} -> [email protected]
    attr_filter: Matched entry DEFAULT at line 11
    ++[attr_filter.access_reject] returns updated
    Delaying reject of request 5 for 1 seconds
    Going to the next request
    Waking up in 0.9 seconds.
    Waiting to send Access-Reject to client CCR1016 port 42438 - ID: 17
    Waking up in 0.6 seconds.
    Waking up in 0.3 seconds.
    Sending delayed reject for request 5
    Sending Access-Reject of id 17 to 10.25.152.252 port 42438
    Waking up in 4.9 seconds.
    Cleaning up request 5 ID 17 with timestamp +493
    Ready to process request
    Alquem poderia me dar uma ajuda, ou luz
    Alex Rock Avatar de alexrock
    Jan 2006
    S. J. do Rio Preto-SP
    Padrão Re: Freeradius e AD + Routerboard Hotspot
    Parece que o err é esse: ERROR: No authenticate method (Auth-Type) found for the request: Rejecting the user
    Ativa no Hotspot o PAP, pois somente funciona com o AD usando o PAP (sem criptografia).
    Posta o resultado pra gente.
    Mesma coisa.. coloquei no hotspot da Routerboard PAP , mas continua dando o mesmo erro
    Jan 2006
    Só uma pergunta: porque Mikrotik > Freeradius > AD se vc pode Mikrotik > AD?
    http://zanjiryan.blogspot.com.br/201...-mikrotik.html
    Não tinha pensado nisso ... Valeu demais pela ajuda.
    JA fiz agora ta funcionando blz
    Jan 2006
    As vezes a solução é simples...a gente que complica...heheeh.
    Alex coloquei o Radius no AD, mas to com um problema, o Hotspot envia a autenticação em CHAP, ai o ad não autentica se você não marcar a opção "salvar senha em formato reversível". nao tem como o hotspot Enviar em MSCHAP? tenho um pequeno problema se tiver que refazer as senha, sao apenas umas 15 mil pra recadastrar.... isso e "impossivel". se tiver alguma ideia , fico agradecido
