  1. amigo dar um export em suas regras e posta aqui.
  2. Citação Postado originalmente por wld.net1 Ver Post
    Opa, tinha perdido acesso, consegui acessar novamente, e fiz algumas alterações.
    Porem continua o mesmo problema.
    Segue as regras.
    Código :
    /ip route
    add comment=MARCADOS distance=4 gateway=192.168.30.1 routing-mark=LINK-DEDICADO
    add comment=MARCADOS distance=5 gateway=192.168.30.1 routing-mark=LINK-DEDICADO
    add comment=MARCADOS distance=6 gateway=192.168.30.1 routing-mark=LINK-DEDICADO
    add comment=MARCADOS distance=4 gateway=192.168.31.1 routing-mark=LINK25MB
    add comment=MARCADOS distance=5 gateway=192.168.31.1 routing-mark=LINK25MB
    add comment=MARCADOS distance=6 gateway=192.168.31.1 routing-mark=LINK25MB
    add comment=MARCADOS distance=4 gateway=192.168.32.1 routing-mark=LINK35MB
    add comment=MARCADOS distance=5 gateway=192.168.32.1 routing-mark=LINK35MB
    add comment=MARCADOS distance=6 gateway=192.168.32.1 routing-mark=LINK35MB
    add comment=Regra01 distance=1 gateway=192.168.30.1 scope=10
    add comment=Regra01 distance=2 gateway=192.168.31.1 scope=10
    add comment=Regra01 distance=3 gateway=192.168.32.1 scope=10
    add comment="TESTE 1 LINK-DEDICADO" distance=1 dst-address=192.99.xxx.yy/32 gateway=179.184.xx.xx scope=10
    add comment="TESTE 2 LINK-DEDICADO" distance=1 dst-address=192.99.xxx.yx/32 gateway=179.184.xx.xx scope=10
    add comment="TESTE 1 LINK25" distance=1 dst-address=200.160.2.3/32 gateway=192.168.254.1 scope=10
    add comment="TESTE 2 LINK25" distance=1 dst-address=208.67.222.220/32 gateway=192.168.254.1 scope=10
    add comment="TESTE 1 LINK35" distance=1 dst-address=200.160.2.4/32 gateway=192.168.25.1 scope=10
    add comment="TESTE 2 LINK35" distance=1 dst-address=208.67.220.222/32 gateway=192.168.25.1 scope=10
    add check-gateway=ping comment=PING distance=1 dst-address=192.168.30.1/32 gateway=192.99.xxx.yy scope=10
    add check-gateway=ping comment=PING distance=2 dst-address=192.168.30.1/32 gateway=192.99.xxx.yx scope=10
    add check-gateway=ping comment=PING distance=1 dst-address=192.168.31.1/32 gateway=208.67.222.220 scope=10
    add check-gateway=ping comment=PING distance=2 dst-address=192.168.31.1/32 gateway=200.160.2.3 scope=10
    add check-gateway=ping comment=PING distance=1 dst-address=192.168.32.1/32 gateway=208.67.220.222 scope=10
    add check-gateway=ping comment=PING distance=2 dst-address=192.168.32.1/32 gateway=200.160.2.4 scope=10
    Segue um print também.
Nome:	         regras-mk.png
Visualizações:	104
Tamanho: 	60,6 KB
    Já revisei e refiz as regras, não achei aonde estou errando!
    Valeu.
  3. Me ajuda com meu PCC ?
    tenho
    Link1 - 15M - ip: 172.15.1.1/30
    Link2 - 15M - ip: 172.15.2.1/30
    Link3 - 10M bridge
    Link4 - 15M - ip: 172.15.4.1/30
    saida - ip: 172.16.0.1/24
    se possivel add no skype: marcelopillon@hotmail.com
    com 2 links eu consegui , agora com 4 link estou apanhando um pouco
  4. Boa Noite ,
    Tenho uma RB433 um link da astro net de 10 megas é um da oi velox de 5 megas qual balance eu posso usar conecto somente com 3 maquinas minhas da minha casa nos links . Recebo um link via Wlan ( com uma repetidora da Dlink conectada na RB ) é o outro pelo cabo de rede com o cable modem da operadora tb conectado na RB, tem como eu fazer um balance ?? pois o link de 5 megas esta ficando parado =/ com esse balance ficara bom séra? pois configurei alguns de outros sites é fica perdendo pacote os sites não carregam direito não consigo um dowload bom , nem mesmo com gerenciador , sou novato ainda estou lendo sempre sobre PCC , se alguem puder me dar umas dicas aumentar meus dowloads . Obrigado
  5. Ola a todos poderiam me informar como ficaria a parte de rotas mais 1 link ou 2 .
    Tentei segui o raciocino mais sem sucesso, si fica ativado dois links, para o terceiro ativar tenho q desativa o segundo.... e se desativar o primeiro não ativa o terceiro. Alguém poderia me dar um exemplo de como ficaria a parte de rotas e a parte failover com mais um link ou dois.
    Última edição por sidneisnp; 16-05-2015 às 10:47. Razão: Esclarecer melhor a duvida.
  1. Load balance pcc com links ip dinamico , como fazer?
    Por julinribeiro no fórum Redes
    Respostas: 21
    Último Post: 25-10-2017, 08:41
  2. Respostas: 78
    Último Post: 06-05-2017, 08:23
  3. Respostas: 35
    Último Post: 01-07-2016, 12:22
  4. Mini Balance PCC com Failover automático
    Por AndrioPJ no fórum Redes
    Respostas: 119
    Último Post: 29-06-2015, 11:00
  5. Load Balance pcc com Lentidão!
    Por maninho03 no fórum Redes
    Respostas: 26
    Último Post: 24-07-2012, 08:46
