  1. estranho que não aparece os logs só quando seto o proxy no browser na máquina cliente (estação).
    será que tem algo no squid que tem que fazer?
    Abraço
  2. Posta o seu squid.conf aqui.
    Não tem muito o que fazer no squid.conf, é só configurar a porta para trabalhar em modo transparente, com o "intercept" e configurar sua ACL.
  3. segue o conf
    # Recommended minimum configuration:
    # Squid normally listens to port 3128
    http_port 3128
    http_port 3129 intercept
    acl bloqueados url_regex -i "/usr/local/etc/squid/bloqueados"
    http_access deny bloqueados
    acl palavrasproibidas dstdom_regex "/usr/local/etc/squid/palavrasproibidas"
    http_access deny palavrasproibidas
    acl block_geral dstdomain .nba.com .facebook.com
    http_access deny block_geral
    acl localnet src 10.0.0.0/8 # RFC1918 possible internal network
    acl localnet src 192.168.0.0/16 # RFC1918 possible internal network
    acl SSL_ports port 443
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl Safe_ports port 443 # https
    acl CONNECT method CONNECT
    http_access deny !Safe_ports
    http_access allow localhost manager
    http_access deny manager
    http_access allow localnet
    http_access deny all
    cache_mem 512 MB
    cache_swap_low 90
    cache_swap_high 95
    maximum_object_size 30000 KB
    maximum_object_size_in_memory 40 KB
    access_log /var/log/squid/access.log squid
    cache_log /var/log/squid/cache.log
    cache_store_log /var/log/squid/store.log
    #pid_filename /var/log/squid/squid.pid
    memory_pools off
    #diskd_program /usr/local/squid/diskd
    #unlinkd_program /usr/local/libexec/squid/unlinkd
    quick_abort_max 16 KB
    quick_abort_pct 95
    quick_abort_min 16 KB
    request_header_max_size 20 KB
    reply_header_max_size 20 KB
    request_body_max_size 0 KB
    cache_mgr josevaldirg@gmail.com
    cache_effective_user squid
    cache_effective_group squid
    httpd_suppress_version_string on
    visible_hostname unbound.ccbsumare.local
    cache_dir ufs /var/squid/cache 45000 16 256
    coredump_dir /var/squid/cache
    refresh_pattern -i (/cgi-bin/|\?) 0 0% 0
    refresh_pattern . 0 20% 4320
    # ---- Cache do Windows Update ----
    refresh_pattern au.download.windowsupdate.com/.*\.(cab|exe|msi) 10080 100% 43200 reload-into-ims
    refresh_pattern download.microsoft.com/.*\.(cab|exe|msi) 10080 100% 43200 reload-into-ims
    refresh_pattern msgruser.dlservice.microsoft.com/.*\.(cab|exe|msi) 10080 100% 43200 reload-into-ims
    refresh_pattern windowsupdate.com/.*\.(cab|exe|msi) 10080 100% 43200 reload-into-ims
    refresh_pattern www.microsoft.com/.*\.(cab|exe|msi) 10080 100% 43200 reload-into-ims
    dns_timeout 10 seconds
    dns_nameservers 192.168.0.5 10.1.1.2 8.8.8.8 # DNS Server
    vary_ignore_expire on
    request_header_access From deny all
    request_header_access Server deny all
    request_header_access Link deny all
    request_header_access Via deny all
    request_header_access X-Forwarded-For deny all
    #Paginas de Errors
    error_directory /usr/local/etc/squid/errors/pt-br/
    #FIM
  4. Uma dúvida se usar as confs do thundercache sera que da certo.
    Eu tenho as configurações na RB só estão desabilitadas pois não uso mais k Thunder.
  5. Aparentemente ta tudo certo. Só reiterando que você tem que tirar a porta 443 da regra dstnat no Mikrotik, senão paginas HTTPS não vão abrir.
    Qual a versão do seu Squid?
    Eu testei as versões 3.4.x em Debian e Ubuntu e não consegui fazer funcionar, só funcionou a 3.1.2 que vem no repositório stable do Debian 7.8. Infelizmente meu conhecimento é muito superficial também, mas na versão 3.1.2, as configurações que você tem agora funcionariam (exceto que tem que tirar a porta 443).
  1. Sarg não mostra ip dos clientes
    Por jaelcio no fórum Redes
    Respostas: 22
    Último Post: 14-08-2014, 14:28
  2. Respostas: 3
    Último Post: 24-01-2011, 17:38
  3. Como fazer para Squid não mudar IP do cliente
    Por e-eduardo no fórum Servidores de Rede
    Respostas: 8
    Último Post: 18-02-2009, 08:07
  4. Clientes DHCP não recebem Ip do AP-PC MK
    Por Josue Guedes no fórum Redes
    Último Post: 26-02-2008, 22:07
  5. WET11 - IP do cliente nao funciona dinamico
    Por santocyber no fórum Redes
    Respostas: 11
    Último Post: 30-08-2004, 07:20
