    Padrão Antena 4x4 2 radios na mesma setorial
    Antena 4x4 pra quem quer economizar espaço na torre
    A mesma empresa tem antena 3x3 sector e direcional e 4x4 sector e direcional bom pra quem quer um ponto a ponto com 2 radios na mesma case e antena
    http://www.itelite.net/en/Katalog/3x...2xdual-HV.html
    http://www.itelite.net/#
Nome:	         antena.png
Visualizações:	147
Tamanho: 	808,2 KB
    SECTOR-XL 50018_2xdual H&V
    Key Features:
    • 4x18 dBi Sectorial Gain
    • 2 x Dual Polarizations H&V in One Case
    • Special Outdoor Weatherproof Enclosure
    • Highest Ingress Protection IP 67
    • High Quality Construction
    • Minimized Sidelobes Level
    • Heavy-Duty Mounting Elements
    • Easy Elevation and Tilt Adjustment
    • 5 Years Warranty
    • Designed for All Weather Operation
    Applications:
    • 5 GHz Band Wireless LAN
    • 2 x MIMO standard
    • IIEEE 802.11a/n WLAN Systems
    • Point to Multipoint Applications
    http://www.itelite.net/files/image/rohs.jpghttp://www.itelite.net/files/image/uziemienie.jpghttp://www.itelite.net/files/image/waterproof2.jpghttp://www.itelite.net/files/image/microstip.jpg
    http://www.itelite.net/files/image/kres.gif
    Description:
    Sector antenna working in 5 GHz band, 2 x dual H&V polarization with 4x18 dBi gain, Ideal solution for MIMO applications, Because of reduced sidelobes, antenna keeps clear strong signal even in crowded radio enviroment. It´s resistant to interference from other networks and does not disrub to other. Antenna features no beam squint due to frequency change, it means that decreasing of data throughput or even loss of a link after frequency channel change does not occur. Perfectly designed for operation under severe weather conditions. A proper materials allow operation in the salt water environment without corrosion. Professional mounting system with 0-15 degrees scale guarantees easy and smooth tilt down as well as rock-stable operation.
    The sector antenna can be furnished with an adapter dedicated for:
    • Cambium ePMP1000, PMP450 or Ubnt Rocket M5
    Electrical Properties
    Frequency 5.15 – 6.0 GHz
    Gain 4x18dBi
    Polarization 2xdual H&V
    Beamwidth deg horizontal 90°(-3dB), 120°(-6dB)
    Beamwidth deg vertical
    VSWR <1,8
    Impedance 50 ohm
    Front to back ratio > 35 dB
    Enclosure Properties
    Technology: Microstrip
    Material: UV protected
    Colour: White
    Ingress Protection (EN 60529): IP 67
    Min temperature: -40°C / -40°F
    Max temperature: 80°C / 176°F
    Mechanical Properties
    Input Connector 4xN-type / female
    Wind Load <[email protected]
    Outside Dimensions 580x260x50 mm
    Weight 1.5kg / 3.3lbs
    Specification subject to change without notice.
    Plots:
    Padrão Re: Antena 4x4 2 radios na mesma setorial
    Estes dois rádios seriam para trabalhar com SSID diferentes? Ou seja, cada rádio vai para um 2x2 enquanto o outro vai para outro 2x2?
    Será que conseguiram tanta isolação entre elas?
    Sim 2 ssid cada radio em 2x2 ,da pra ter uma economia em espaço na torre pois no mesmo suporte em vez de 3 antenas 120 vc teria 6 antenas. Quanto a isolação creio que sim essa empresa ta no ramo desde de 2001 e tem grandes experiencias com fabricação de antenas. eles tem antena setoriais triband ou seja funciona em 900 2.4 e 5,8 e tambem dual band 2.4 e 5,8 na mesma setorial. antenas 3x3 para a rb 922 trichanel. antenas ponto a ponto em 3x3 4x4
    Na especificação nao diz que pode ser usada com radios separados. Ela diz que para usar com MIMO, isso é um unico radio com 4 antenas MIMO.
    Tenho duvidas de como se comportam com dois radios en frequencias diferentes. Vai depender da isolação dos radios e nao das antenas pois elas nao isolam para canais adjasentes .
    As antenas nao tem isolação entre elas. Nao tem como isolar (perfeitamente) duas antenas iguais situadas uma do lado da outra.
    http://www.itelite.net/offer.php?n=152&lang=en
    Desconheço radios mimo 4x4 outdoor pelo que deu a entender são duas antenas juntas 2x2 que se pode usar 2 radios em cada conjunto 2x2 assim tendo economia de espaço pelo que estava descrito nas especificaçoes do fabricante
    Mas a citação não diz que é 4x4 Mimo, mas 2 x2 Mimo. Isso passa a ideia de dois rádios. E o isolamento mais importante não é feito pelo rádio mas sim pela construção das antenas.
    Logicamente que com canais muito próximos não vai conseguir isolação. Mas se afastar os canais, quem sabe...
    Pelo que entendi é para usar 3 painéis desses para fechar os 360º e ainda colocar mais clientes, pois seriam dois rádios para cada painel.
    Mas ainda está um pouco obscuro.
    Tem tanta coisa nova surgindo que não duvido nada.
    Mandei uma consulta ao respeito para o fabricante.
    O fabricante confirmou que a antena foi pensada para usar DOIS radios (H e V cada) em diferentes frequencias!!
    Legal ja imaginava que fosse isso, isso e muito bom para economia na torre pois e como se fosse 6 antenas em 3 suportes.
    Exato!!! essa a vantagem porem vai depender do preço
