    Dec 2000
    Boston
    Padrão Novo dns cloudflare 1.1.1.1
    Alguém já testou o novo dns global da cloudflare 1.1.1.1 ? Estao dizendo que é mais rapido que o google globalmente.
    Dec 2000
    Boston
    Padrão Re: Novo dns cloudflare 1.1.1.1
    $ ping 1.1.1.1
    PING 1.1.1.1 (1.1.1.1): 56 data bytes
    64 bytes from 1.1.1.1: icmp_seq=0 ttl=57 time=22.481 ms
    64 bytes from 1.1.1.1: icmp_seq=1 ttl=57 time=21.251 ms
    64 bytes from 1.1.1.1: icmp_seq=2 ttl=57 time=21.319 ms
    64 bytes from 1.1.1.1: icmp_seq=3 ttl=57 time=20.140 ms
    ^C
    --- 1.1.1.1 ping statistics ---
    4 packets transmitted, 4 packets received, 0.0% packet loss
    round-trip min/avg/max/stddev = 20.140/21.298/22.481/0.828 ms
    $ traceroute -n 1.1.1.1
    traceroute to 1.1.1.1 (1.1.1.1), 64 hops max, 52 byte packets
    1 192.168.1.1 5.099 ms 5.412 ms 4.377 ms
    2 71.248.165.1 5.364 ms 7.658 ms 11.165 ms
    3 100.41.130.248 11.020 ms 20.232 ms
    100.41.130.250 14.684 ms
    4 * * *
    5 * * *
    6 140.222.230.151 23.349 ms
    140.222.230.153 25.786 ms 20.830 ms
    7 157.130.91.86 17.493 ms 19.840 ms 20.925 ms
    8 213.248.77.162 16.726 ms 21.786 ms 19.400 ms
    9 1.1.1.1 18.605 ms 18.012 ms 17.709 ms
    Não testei também, mas efetuei os mesmo teste que você aqui e obtive os seguintes parâmeros.
    redes@speedtest:~$ ping 1.1.1.1
    PING 1.1.1.1 (1.1.1.1) 56(84) bytes of data.
    64 bytes from 1.1.1.1: icmp_seq=1 ttl=59 time=10.3 ms
    64 bytes from 1.1.1.1: icmp_seq=2 ttl=59 time=10.3 ms
    64 bytes from 1.1.1.1: icmp_seq=3 ttl=59 time=10.3 ms
    64 bytes from 1.1.1.1: icmp_seq=4 ttl=59 time=10.1 ms
    ^C
    4 packets transmitted, 4 received, 0% packet loss, time 3004ms
    rtt min/avg/max/mdev = 10.141/10.304/10.380/0.121 ms
    redes@speedtest:~$ traceroute 1.1.1.1
    traceroute to 1.1.1.1 (1.1.1.1), 30 hops max, 60 byte packets
    1 edge-router.266164.mafhen.com.br (45.6.184.1) 0.164 ms 0.159 ms 0.138 ms
    2 r-133.1.186.138.static.nrttelecom.com.br (138.186.1.133) 11.872 ms 11.865 ms 12.080 ms
    3 xe-0-0-1.border01-bru.static.nrttelecom.com.br (177.87.153.130) 13.400 ms 13.393 ms 13.390 ms
    4 as13335.saopaulo.sp.ix.br (187.16.219.111) 18.872 ms 18.870 ms 18.860 ms
    5 1dot1dot1dot1.cloudflare-dns.com (1.1.1.1) 9.883 ms 10.347 ms 10.461 ms
    CloudFare tem CDN espalhado pra tudo quanto é canto.
    O problema é alguns administradores de redes idiotas que usam loopback 1.1.1.1. Hahahahahahahhahaha
    Citação Postado originalmente por avatar52 Ver Post
    Sempre tem né HAHA
    Fiz um teste aki o ping deu baixíssimo menos de 20ms!
    Aqui tá dando entre 8 e 9ms, o mesmo tempo do 8.8.8.8 da Google.
    Pinging 1.1.1.1 with 32 bytes of data:
    Reply from 1.1.1.1: bytes=32 time=9ms TTL=61
    Reply from 1.1.1.1: bytes=32 time=8ms TTL=61
    Ping statistics for 1.1.1.1:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
    Approximate round trip times in milli-seconds:
    Minimum = 8ms, Maximum = 9ms, Average = 8ms
    Moderador Avatar de Bruno
    Nov 2002
    Guarapuava-PR
    já teve provedor falando que não consegue usar o dns da cloud pq será ????? kkkk
    Código :
    Disparando 1.1.1.1 com 1500 bytes de dados:
    Resposta de 1.1.1.1: bytes=1500 tempo=11ms TTL=59
    Resposta de 1.1.1.1: bytes=1500 tempo=10ms TTL=59
    Resposta de 1.1.1.1: bytes=1500 tempo=12ms TTL=59
    Alguém sabe o IPv6 desse DNS da CloudFare?
    Dec 2000
    Boston
    ipv4 1.0.0.1 and 1.1.1.1
    ipv6 2606:4700:4700::1111 and 2606:4700:4700::1001
    Boa parte da rede ATM da OI VELOX usa loopback 1.1.1.1.
