Página 3 de 11 PrimeiroPrimeiro 12345678 ... ÚltimoÚltimo
    [QUOTE = raumaster; 842109] Hi Erdem! How are you?
    Thank you for your answer. I've already come in contact with you guys from MTO about a year ago or so, but due to the high price we have to pay for imported stuff when they arrive in Brazil because of our taxes and the devaluation of our currency in relation to the dollar currency, I can't afford it for something that there is no current proof that really works. I've decided to create this topic here hoping someone already uses your product in Brazil or knows the theory behind these lightning prevention systems and if it really works. [/ QUOTE]
    Olá senhor, obrigado, espero que você esteja bem também.
    Antes de tudo, deixe-me apresentar o EvoDis System em nosso Catálogo de informações https://www.mto.com.tr/mto-info-en , que inclui relatórios de testes de laboratório e de campo, algumas referências e outros documentos.
    Deixe-me entender a hesitação que o impede de tomar uma decisão; você acha o sistema EvoDis caro ou a solução não é confiável?
    Além disso, informe-me, se não for confidencial, quanto dinheiro você perdeu devido a raios no ano passado?
    Saudações,
    Erdem
  2. #14
    Padrão Re: Sistema de prevenção contra raios.
    Yes, the downtime cost and the cost of equipment is of a major concern. The amount of money we've spent on eletronics is not the problem, the problem is really the downtime and the furious clients calling us because "the Internet" is not working...
    What is holding us back on the decision of buying your system is the price of the product after all the taxes are paid when it arrives at our door and the fact that there is no regulation in my country approving these kinds of lightning protectio or lighrning avoidance systems. Our main tower is located near by houses where dozens of people live and if demages are made by lightning strikes and someone decides that our tower is the "culprit" and call an inspector or someone from the government to check if everthing is okay and within all regulations you get the picture... I've read somehere that your system is not approved in american countries and many other countries, so this holds back my decision as well, not only the price.
    You guys from MTO have told me once that I should eliminate all lightning rods from the tower but this makes me uncomfotable since this is what all regulations ask to have in any tower or high rise construction. What if a lightning strike "decides" to hit our tower directly even if your product is installed correctly? You guys can give us 100% garantee that no lightning will ever hit our tower? And if it hits our tower, wouldn't it be more destructive if the lightning rod were there to conduct all the energy to earth?
  3. #15
    Nesse tópico o Rubem já mencionou esse objeto que vc falou que creio ser um dissipador de estática https://under-linux.org/showthread.php?t=186567 no Próprio tópico um user menciona que vc pode conseguir esse dissipador de estática em aeroporto pois são usados em aviões procure no gogle
    por static dischargers tower
    Última edição por wala; 01-10-2019 às 23:04.
  4. #16
    Procure aqueles descarregadores de estatica de aviões quem sabe faz o mesmo efeito.
  5. #17
    O meu maior problema aqui são os rádios expostos na torre, não tem muito o que fazer. O que tá no interior de Alvenaria tá tudo protegido por DPS, todas linhas, sinal e AC e não tenho muito problema, só DPS de sinal que protegem, mas não guentam o tranco, curto-circuitam, perde o sinal das LANs e aí só trocando DPS e rádio, alguns rádios de salvam... To postando nesse instante em que uma tempestade se forma, a primeira da primavera desse ano! Já to aqui apreensivo!
    Se sofre atoa tambem coloca aqueles fiber_poe da ubnt com um cabo o mais curto que vc consegui entre o fiberpoe e o radio e desce uma fibra ele tem que levar energia separado mais tem aquelas fibra da empresa fibracem que tem ja contdutores de cobre ai vc pode levar energia para o fiber poe no mesmo cabo da fibra, esse fiberpoe tem proteção contra descarga ja ajuda muito e o trajeto que a fibra vai fazer no lugar do cabo utp ja tem muitas chance de não queimar os seus rádios.
  6. #18
    Aí queima a bagaça la em cima da torre junto com os rádios... pode minimizar, mas por ter que levar a energia num cabo a parte e ter mais uma bagaça eletronica em cima da torre, dá no mesmo! Fora o custo! Esse Fiberpoe alimenta quantos rádios? Pq tenho 11 rádios numa torre...
    Vou dar uma olhada.
    Vou olhar.
