Boa ..., instalei o WSL2, debian e mate. Abriu a tela grafica do XRDP para login e senha. Funcionou, porém muito vazio. Depois instalei o kde e desinstalei o mate. Tudo nessa ordem. Continuou abrindo a tela grafica do XRDP para login e senha, mas depois disso volta para linha de comando. Digito...
startx e... (Tem o print do arquivo de log abaixo também)
X.Org X Server 1.20.4
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.9.0-8-amd64 x86_64 Debian
Current Operating System: Linux DESKTOP-RN4J8B2 4.19.104-microsoft-standard #1 SMP Wed Feb 19 06:37:35 UTC 2020 x86_64
Kernel command line: initrd=\initrd.img panic=-1 pty.legacy_count=0 nr_cpus=8
Build Date: 05 March 2019 08:11:12PM
xorg-server 2:1.20.4-1 (https://www.debian.org/support)
Current version of pixman: 0.36.0
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.1.log", Time: Tue Jun 2 00:20:54 2020
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(EE)
Fatal server error:
(EE) no screens found(EE)
(EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
(EE) Please also check the log file at "/var/log/Xorg.1.log" for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file.
xinit: giving up
xinit: unable to connect to X server: Connection refused
xinit: server error
root@DESKTOP-RN4J8B2:/home/garrido#
O arquivo de log em /var/log/Xorg.1.log
[ 10400.920]
[ 10400.920] Build Operating System: Linux 4.9.0-8-amd64 x86_64 Debian
[ 10400.920] Current Operating System: Linux DESKTOP-RN4J8B2 4.19.104-microsoft-standard #1 SMP Wed Feb 19 06:37:35 UTC 2020 x86_64
[ 10400.921] Kernel command line: initrd=\initrd.img panic=-1 pty.legacy_count=0 nr_cpus=8
[ 10400.921] Build Date: 05 March 2019 08:11:12PM
[ 10400.921] xorg-server 2:1.20.4-1 (https://www.debian.org/support)
[ 10400.921] Current version of pixman: 0.36.0
[ 10400.921] Before reporting problems, check http://wiki.x.org
[ 10400.921] Markers: (--) probed, (**) from config file, (==) default setting,
[ 10400.921] (==) Log file: "/var/log/Xorg.1.log", Time: Tue Jun 2 00:21:28 2020
[ 10400.922] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 10400.922] (==) No Layout section. Using the first Screen section.
[ 10400.922] (==) No screen section available. Using defaults.
[ 10400.922] (**) |-->Screen "Default Screen Section" (0)
[ 10400.922] (**) | |-->Monitor "<default monitor>"
[ 10400.922] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 10400.922] (==) Automatically adding devices
[ 10400.922] (==) Automatically enabling devices
[ 10400.922] (==) Automatically adding GPU devices
[ 10400.922] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 10400.923] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 10400.923] Entry deleted from font path.
[ 10400.923] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/75dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 10400.923] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 10400.923] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 10400.923] (II) Loader magic: 0x562dac54de20
[ 10400.923] (II) Module ABI versions:
[ 10400.923] X.Org ANSI C Emulation: 0.4
[ 10400.923] X.Org Video Driver: 24.0
[ 10400.923] X.Org XInput driver : 24.1
[ 10400.923] X.Org Server Extension : 10.0
[ 10400.944] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No s$[ 10400.944] (--) using VT number 2
[ 10400.944] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 10400.944] (II) no primary bus or device found
[ 10400.944] (II) LoadModule: "glx"
[ 10400.945] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 10400.946] (II) Module glx: vendor="X.Org Foundation"
[ 10400.946] compiled for 1.20.4, module version = 1.0.0
[ 10400.946] ABI class: X.Org Server Extension, version 10.0
[ 10400.946] (==) Matched modesetting as autoconfigured driver 0
[ 10400.946] (==) Matched fbdev as autoconfigured driver 1
[ 10400.946] (==) Matched vesa as autoconfigured driver 2
[ 10400.946] (==) Assigned the driver to the xf86ConfigLayout
[ 10400.946] (II) LoadModule: "modesetting"
[ 10400.947] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 10400.947] (II) Module modesetting: vendor="X.Org Foundation"
[ 10400.947] compiled for 1.20.4, module version = 1.20.4
[ 10400.947] Module class: X.Org Video Driver
[ 10400.947] ABI class: X.Org Video Driver, version 24.0
[ 10400.947] (II) LoadModule: "fbdev"
[ 10400.947] (WW) Warning, couldn't open module fbdev
[ 10400.947] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 10400.947] (II) LoadModule: "vesa"
[ 10400.947] (WW) Warning, couldn't open module vesa
[ 10400.947] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 10400.947] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 10400.948] (WW) Falling back to old probe method for modesetting
[ 10400.948] (EE) open /dev/dri/card0: No such file or directory
[ 10400.948] (EE) No devices detected.
[ 10400.948] (EE)
Fatal server error:
[ 10400.948] (EE) no screens found(EE)
[ 10400.948] (EE)
for help.
[ 10400.948] (EE) Please also check the log file at "/var/log/Xorg.1.log" for additional information.
[ 10400.948] (EE)
[ 10400.948] (EE) Server terminated with error (1). Closing log file.
Agradeço quem poder me ajudar.
