    Padrão kernel 2.4.20
    nao sei mais o q eh, tipo, eu ja entrei no doc.../changes e olhei td q ele fala la e suas versoes, e ta td ok ja
    mais mesmo assim nao vai!
    [[email protected] linux-2.4.20]# make menuconfig
    rm -f include/asm
    ( cd include ; ln -sf asm-i386 asm)
    make -C scripts/lxdialog all
    make[1]: Entrando no diretório `/usr/src/linux-2.4.20/scripts/lxdialog´
    /usr/bin/ld: cannot find -lncurses
    collect2: ld returned 1 exit status
    >> Unable to find the Ncurses libraries.
    >> You must have Ncurses installed in order
    >> to use ´make menuconfig´
    make[1]: ** [ncurses] Erro 1
    make[1]: Saindo do diretório `/usr/src/linux-2.4.20/scripts/lxdialog´
    make: ** [menuconfig] Erro 2
    [[email protected] linux-2.4.20]# make xconfig
    rm -f include/asm
    make -C scripts kconfig.tk
    make[1]: Entrando no diretório `/usr/src/linux-2.4.20/scripts´
    gcc -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -c -o tkparse.o tkparse.c
    gcc -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -c -o tkcond.o tkcond.c
    gcc -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -c -o tkgen.o tkgen.c
    gcc -o tkparse tkparse.o tkcond.o tkgen.o
    cat header.tk >> ./kconfig.tk
    ./tkparse < ../arch/i386/config.in >> kconfig.tk
    echo "set defaults \"arch/i386/defconfig\"" >> kconfig.tk
    echo "set ARCH \"i386\"" >> kconfig.tk
    cat tail.tk >> kconfig.tk
    chmod 755 kconfig.tk
    make[1]: Saindo do diretório `/usr/src/linux-2.4.20/scripts&acute;
    wish -f scripts/kconfig.tk
    make: wish: Comando não encontrado
    make: ** [xconfig] Erro 127
    [[email protected] linux-2.4.20]# <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif">
    Celio
    Tipo, tente instalar o pacote do ncurses, se já tiver instalado remova e pegue dinovo do CD. Estranho <IMG SRC="images/forum/icons/icon_wink.gif">
    consegui chama o menuconfig!
    tipo, tem a ncurses e ncurses4
    eu nao tinha essa ncurses4 pq nem fala dela no doc../changes do kernel
    mais agora q instalei ela deu certo
    ia tenta reinstala a ncurses mais tinha uma lista de dependecias d dezesnas d bagui
    Mr_Mind
    instala a aplicaçao wish
    Moderador Avatar de Bruno
    Nov 2002
    Guarapuava-PR
    instala o wish
    q q eh wish?
