  1. não ..
    ainda não funcionou! <IMG SRC="images/forum/icons/icon27.gif">
    a msg de erro quando carrego o starx é essa:
    XFree86 Version 4.0.3 / X Window System
    (protocol Version 11, revision 0, vendor release 6400)
    Release Date: 16 March 2001
    If the server is older than 6-12 months, or if your card is
    newer than the above date, look for a newer version before
    reporting problems. (See http://www.XFree86.Org/FAQ)
    Operating System: Linux 2.2.17-8smp i686 [ELF]
    Module Loader present
    (==) Log file: "/var/log/XFree86.0.log", Time: Mon Dec 16 12:35:09 2002
    (==) Using config file: "/etc/X11/XF86Config-4"
    Markers: (--) probed, (**) from config file, (==) default setting,
    (++) from command line, (!!) notice, (II) informational,
    (WW) warning, (EE) error, (??) unknown.
    (==) ServerLayout "XFree86 Configured"
    (**) |-->Screen "Screen0" (0)
    (**) | |-->Monitor "My Monitor"
    (**) | |-->Device "Voodoo3 (generic)"
    (**) |-->Input Device "Mouse0"
    (**) |-->Input Device "Keyboard0"
    (**) Option "XkbLayout" "us"
    (**) XKB: layout: "us"
    (**) FontPath set to "unix/:7100"
    (==) RgbPath set to "/usr/X11R6/lib/X11/rgb"
    (==) ModulePath set to "/usr/X11R6/lib/modules"
    (--) using VT number 7
    (II) Open APM successful
    (II) Module ABI versions:
    XFree86 ANSI C Emulation: 0.1
    XFree86 Video Driver: 0.3
    XFree86 XInput driver : 0.1
    XFree86 Server Extension : 0.1
    XFree86 Font Renderer : 0.2
    (II) Loader running on linux
    (II) LoadModule: "bitmap"
    (II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
    (II) Module bitmap: vendor="The XFree86 Project"
    compiled for 4.0.3, module version = 1.0.0
    Module class: XFree86 Font Renderer
    ABI class: XFree86 Font Renderer, version 0.2
    (II) Loading font Bitmap
    (II) LoadModule: "pcidata"
    (II) Loading /usr/X11R6/lib/modules/libpcidata.a
    (II) Module pcidata: vendor="The XFree86 Project"
    compiled for 4.0.3, module version = 0.1.0
    ABI class: XFree86 Video Driver, version 0.3
    (II) PCI: Probing config type using method 1
    (II) PCI: Config type is 1
    (II) PCI: stages = 0x03, oldVal1 = 0x00000000, mode1Res1 = 0x80000000
    (II) PCI: PCI scan (all values are in hex)
    (II) PCI: 00:00:0: chip 1106,0691 card 1043,80e8 rev c4 class 06,00,00 hdr 00
    (II) PCI: 00:01:0: chip 1106,8598 card 0000,0000 rev 00 class 06,04,00 hdr 01
    (II) PCI: 00:04:0: chip 1106,0686 card 1043,80e8 rev 22 class 06,01,00 hdr 80
    (II) PCI: 00:04:1: chip 1106,0571 card 0000,0000 rev 10 class 01,01,8a hdr 00
    (II) PCI: 00:04:2: chip 1106,3038 card 0925,1234 rev 10 class 0c,03,00 hdr 00
    (II) PCI: 00:04:3: chip 1106,3038 card 0925,1234 rev 10 class 0c,03,00 hdr 00
    (II) PCI: 00:04:4: chip 1106,3057 card 0000,0000 rev 30 class 06,00,00 hdr 00
    (II) PCI: 00:08:0: chip 10ec,8139 card 10ec,8139 rev 10 class 02,00,00 hdr 00
    (II) PCI: 00:09:0: chip 10ec,8139 card 10ec,8139 rev 10 class 02,00,00 hdr 00
    (II) PCI: 01:00:0: chip 121a,0005 card 121a,0037 rev 01 class 03,00,00 hdr 00
    (II) PCI: End of PCI scan
    (II) LoadModule: "scanpci"
    (II) Loading /usr/X11R6/lib/modules/libscanpci.a
    (II) Module scanpci: vendor="The XFree86 Project"
    (II) UnloadModule: "scanpci"
    (II) Unloading /usr/X11R6/lib/modules/libscanpci.a
    (II) Host-to-PCI bridge:
    (II) PCI-to-ISA bridge:
    (II) PCI-to-PCI bridge:
    (II) Bus 0: bridge is at (0:0:0), (-1,0,0), BCTRL: 0x00 (VGA_EN is cleared)
    (II) Bus 0 I/O range:
    [0] -1 0x00000000 - 0x0000ffff (0x10000) IX[B]
    (II) Bus 0 non-prefetchable memory range:
    [0] -1 0x00000000 - 0xffffffff (0x0) MX[B]
    (II) Bus 0 prefetchable memory range:
    (II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x08 (VGA_EN is set)
    (II) Bus 1 I/O range:
    [0] -1 0x0000d000 - 0x0000dfff (0x1000) IX[B]
    (II) Bus 1 non-prefetchable memory range:
    [0] -1 0xf6000000 - 0xf9efffff (0x3f00000) MX[B]
    (II) Bus 1 prefetchable memory range:
    [0] -1 0xf9f00000 - 0xfbffffff (0x2100000) MX[B]
    (II) Bus -1: bridge is at (0:4:0), (0,-1,0), BCTRL: 0x00 (VGA_EN is cleared)
    (II) Bus -1 I/O range:
    (II) Bus -1 non-prefetchable memory range:
    (II) Bus -1 prefetchable memory range:
    (II) Bus -1: bridge is at (0:0:0), (-1,-1,0), BCTRL: 0x00 (VGA_EN is cleared)
    (--) PCI:*(1:0:0) 3Dfx Interactive Voodoo3 rev 1, Mem @ 0xf6000000/25, 0xfa000000/25, I/O @ 0xd800/8
    (II) Addressable bus resource ranges are
    [1] -1 0x00000000 - 0x0000ffff (0x10000) IX[B]
    (II) OS-reported resource ranges:
    [0] -1 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
    [1] -1 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
    [2] -1 0x000f0000 - 0x000fffff (0x10000) MX[B]
    [3] -1 0x000c0000 - 0x000effff (0x30000) MX[B]
    [4] -1 0x00000000 - 0x0009ffff (0xa0000) MX[B]
    [5] -1 0x00000000 - 0x000001ff (0x200) IX[B]E
    (II) Active PCI resource ranges:
    [0] -1 0xf5000000 - 0xf50000ff (0x100) MX[B]
    [1] -1 0xf5800000 - 0xf58000ff (0x100) MX[B]
    [2] -1 0xfc000000 - 0xfdffffff (0x2000000) MX[B]
    [3] -1 0xf9ff0000 - 0xf9ffffff (0x10000) MX[B](B)
    [4] -1 0xfa000000 - 0xfbffffff (0x2000000) MX[B](B)
    [5] -1 0xf6000000 - 0xf7ffffff (0x2000000) MX[B](B)
    [6] -1 0x0000a400 - 0x0000a4ff (0x100) IX[B]
    [7] -1 0x0000a800 - 0x0000a8ff (0x100) IX[B]
    [8] -1 0x0000b000 - 0x0000b01f (0x20) IX[B]
    [9] -1 0x0000b400 - 0x0000b41f (0x20) IX[B]
    [10] -1 0x0000b800 - 0x0000b80f (0x10) IX[B]
    [11] -1 0x0000d800 - 0x0000d8ff (0x100) IX[B](B)
    (II) Active PCI resource ranges after removing overlaps:
    (II) OS-reported resource ranges after removing overlaps with PCI:
    (II) All system resource ranges:
    [5] -1 0xf5000000 - 0xf50000ff (0x100) MX[B]
    [6] -1 0xf5800000 - 0xf58000ff (0x100) MX[B]
    [7] -1 0xfc000000 - 0xfdffffff (0x2000000) MX[B]
    [8] -1 0xf9ff0000 - 0xf9ffffff (0x10000) MX[B](B)
    [9] -1 0xfa000000 - 0xfbffffff (0x2000000) MX[B](B)
    [10] -1 0xf6000000 - 0xf7ffffff (0x2000000) MX[B](B)
    [11] -1 0x00000000 - 0x000001ff (0x200) IX[B]E
    [12] -1 0x0000a400 - 0x0000a4ff (0x100) IX[B]
    [13] -1 0x0000a800 - 0x0000a8ff (0x100) IX[B]
    [14] -1 0x0000b000 - 0x0000b01f (0x20) IX[B]
    [15] -1 0x0000b400 - 0x0000b41f (0x20) IX[B]
    [16] -1 0x0000b800 - 0x0000b80f (0x10) IX[B]
    [17] -1 0x0000d800 - 0x0000d8ff (0x100) IX[B](B)
    (II) LoadModule: "dbe"
    (II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a
    (II) Module dbe: vendor="The XFree86 Project"
    Module class: XFree86 Server Extension
    ABI class: XFree86 Server Extension, version 0.1
    (II) Loading extension DOUBLE-BUFFER
    (II) LoadModule: "GLcore"
    (II) Loading /usr/X11R6/lib/modules/extensions/libGLcore.a
    (II) Module GLcore: vendor="The XFree86 Project"
    (II) LoadModule: "dri"
    (II) Loading /usr/X11R6/lib/modules/extensions/libdri.a
    (II) Module dri: vendor="The XFree86 Project"
    (II) Loading extension XFree86-DRI
    (II) Loading sub module "drm"
    (II) LoadModule: "drm"
    (II) Loading /usr/X11R6/lib/modules/linux/libdrm.a
    (II) Module drm: vendor="The XFree86 Project"
    (II) LoadModule: "glx"
    (II) Loading /usr/X11R6/lib/modules/extensions/libglx.a
    (II) Module glx: vendor="The XFree86 Project"
    (II) Loading extension GLX
    (II) Loading sub module "GLcore"
    (II) Reloading /usr/X11R6/lib/modules/extensions/libGLcore.a
    (II) LoadModule: "extmod"
    (II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
    (II) Module extmod: vendor="The XFree86 Project"
    (II) Loading extension SHAPE
    (II) Loading extension MIT-SUNDRY-NONSTANDARD
    (II) Loading extension BIG-REQUESTS
    (II) Loading extension SYNC
    (II) Loading extension MIT-SCREEN-SAVER
    (II) Loading extension XC-MISC
    (II) Loading extension XFree86-VidModeExtension
    (II) Loading extension XFree86-Misc
    (II) Loading extension XFree86-DGA
    (II) Loading extension DPMS
    (II) Loading extension FontCache
    (II) Loading extension TOG-CUP
    (II) Loading extension Extended-Visual-Information
    (II) Loading extension XVideo
    (II) LoadModule: "v4l"
    (II) Loading /usr/X11R6/lib/modules/drivers/linux/v4l_drv.o
    (II) Module v4l: vendor="The XFree86 Project"
    compiled for 4.0.3, module version = 0.0.1
    (II) LoadModule: "tdfx"
    (II) Loading /usr/X11R6/lib/modules/drivers/tdfx_drv.o
    (II) Module tdfx: vendor="The XFree86 Project"
    Module class: XFree86 Video Driver
    (II) LoadModule: "mouse"
    (II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
    (II) Module mouse: vendor="The XFree86 Project"
    Module class: XFree86 XInput Driver
    ABI class: XFree86 XInput driver, version 0.1
    (II) v4l driver for Video4Linux
    (II) TDFX: Driver for 3dfx Banshee/Voodoo3 chipsets: 3dfx Banshee,
    3dfx Voodoo3, 3dfx Voodoo5
    (II) Primary Device is: PCI 01:00:0
    (--) Assigning device section with no busID to primary device
    (--) Chipset 3dfx Voodoo3 found
    (II) resource ranges after xf86ClaimFixedResources() call:
    (II) resource ranges after probing:
    [11] 0 0x000a0000 - 0x000affff (0x10000) MS[B]
    [12] 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
    [13] 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
    [14] -1 0x00000000 - 0x000001ff (0x200) IX[B]E
    [15] -1 0x0000a400 - 0x0000a4ff (0x100) IX[B]
    [16] -1 0x0000a800 - 0x0000a8ff (0x100) IX[B]
    [17] -1 0x0000b000 - 0x0000b01f (0x20) IX[B]
    [18] -1 0x0000b400 - 0x0000b41f (0x20) IX[B]
    [19] -1 0x0000b800 - 0x0000b80f (0x10) IX[B]
    [20] -1 0x0000d800 - 0x0000d8ff (0x100) IX[B](B)
    [21] 0 0x000003b0 - 0x000003bb (0xc) IS[B]
    [22] 0 0x000003c0 - 0x000003df (0x20) IS[B]
    (II) Setting vga for screen 0.
    (II) Loading sub module "vgahw"
    (II) LoadModule: "vgahw"
    (II) Loading /usr/X11R6/lib/modules/libvgahw.a
    (II) Module vgahw: vendor="The XFree86 Project"
    (II) Loading sub module "int10"
    (II) LoadModule: "int10"
    (II) Loading /usr/X11R6/lib/modules/linux/libint10.a
    (II) Module int10: vendor="The XFree86 Project"
    (II) TDFX(0): Softbooting the board (through the int10 interface).
    (II) TDFX(0): Primary V_BIOS segment is: 0xc000
    (II) TDFX(0): Softbooting the board succeeded.
    (**) TDFX(0): Depth 24, (--) framebuffer bpp 32
    (==) TDFX(0): RGB weight 888
    (==) TDFX(0): Default visual is TrueColor
    (--) TDFX(0): Chipset: "3dfx Voodoo3"
    (--) TDFX(0): Linear framebuffer at 0xFA000000
    (--) TDFX(0): MMIO registers at addr 0xF6000000
    (--) TDFX(0): PIO registers at addr 0xD800
    (--) TDFX(0): VideoRAM: 16384 kByte Mapping 32768 kByte
    (==) TDFX(0): Using gamma correction (1.0, 1.0, 1.0)
    (II) TDFX(0): My Monitor: Using hsync value of 31.50 kHz
    (II) TDFX(0): My Monitor: Using hsync value of 35.15 kHz
    (II) TDFX(0): My Monitor: Using hsync value of 35.50 kHz
    (II) TDFX(0): My Monitor: Using vrefresh range of 50.00-70.00 Hz
    (II) TDFX(0): Clock range: 12.00 to 300.00 MHz
    (WW) TDFX(0): Default mode "640x350" deleted (hsync out of range)
    (WW) TDFX(0): Default mode "640x400" deleted (hsync out of range)
    (WW) TDFX(0): Default mode "720x400" deleted (hsync out of range)
    (WW) TDFX(0): Default mode "640x480" deleted (hsync out of range)
    (WW) TDFX(0): Default mode "800x600" deleted (hsync out of range)
    (WW) TDFX(0): Default mode "1024x768" deleted (bad mode clock/interlace/doublescan)
    (WW) TDFX(0): Default mode "1024x768" deleted (hsync out of range)
    (WW) TDFX(0): Default mode "1152x864" deleted (hsync out of range)
    (WW) TDFX(0): Default mode "1280x960" deleted (hsync out of range)
    (WW) TDFX(0): Default mode "1280x1024" deleted (hsync out of range)
    (WW) TDFX(0): Default mode "1400x1050" deleted (hsync out of range)
    (WW) TDFX(0): Default mode "1400x1050" deleted (unknown reason)
    (WW) TDFX(0): Default mode "1600x1200" deleted (hsync out of range)
    (WW) TDFX(0): Default mode "1792x1344" deleted (hsync out of range)
    (WW) TDFX(0): Default mode "1856x1392" deleted (hsync out of range)
    (WW) TDFX(0): Default mode "1920x1440" deleted (hsync out of range)
    (--) TDFX(0): Virtual size is 800x600 (pitch 800)
    (**) TDFX(0): Default mode "800x600": 36.0 MHz, 35.2 kHz, 56.2 Hz
    (==) TDFX(0): DPI set to (75, 75)
    (II) Loading sub module "fb"
    (II) LoadModule: "fb"
    (II) Loading /usr/X11R6/lib/modules/libfb.a
    (II) Module fb: vendor="The XFree86 Project"
    ABI class: XFree86 ANSI C Emulation, version 0.1
    (II) Loading sub module "xaa"
    (II) LoadModule: "xaa"
    (II) Loading /usr/X11R6/lib/modules/libxaa.a
    (II) Module xaa: vendor="The XFree86 Project"
    (II) Loading sub module "ramdac"
    (II) LoadModule: "ramdac"
    (II) Loading /usr/X11R6/lib/modules/libramdac.a
    (II) Module ramdac: vendor="The XFree86 Project"
    (II) Loading sub module "ddc"
    (II) LoadModule: "ddc"
    (II) Loading /usr/X11R6/lib/modules/libddc.a
    (II) Module ddc: vendor="The XFree86 Project"
    (II) Loading sub module "vbe"
    (II) LoadModule: "vbe"
    (II) Loading /usr/X11R6/lib/modules/libvbe.a
    (II) Module vbe: vendor="The XFree86 Project"
    (II) Reloading /usr/X11R6/lib/modules/linux/libint10.a
    (II) TDFX(0): initializing int10
    (II) TDFX(0): VESA BIOS detected
    (II) TDFX(0): VESA VBE Version 3.0
    (II) TDFX(0): VESA VBE Total Mem: 16384 kB
    (II) TDFX(0): VESA VBE OEM: 3dfx Interactive, Inc.
    (II) TDFX(0): VESA VBE OEM Software Rev: 1.0
    (II) TDFX(0): VESA VBE OEM Vendor: Elpin Systems, Inc.
    (II) TDFX(0): VESA VBE OEM Product: 3dfx Avenger
    (II) TDFX(0): VESA VBE OEM Product Rev: Version 1.00
    (II) Reloading /usr/X11R6/lib/modules/libddc.a
    (II) TDFX(0): VESA VBE DDC supported
    (II) TDFX(0): VESA VBE DDC Level 2
    (II) TDFX(0): VESA VBE DDC transfer in appr. 8 sec.
    (II) TDFX(0): VESA VBE DDC read failed
    (--) Depth 24 pixmap format is 32 bpp
    (II) do I need RAC? No, I don&acute;t.
    (II) resource ranges after preInit:
    [0] 0 0xfa000000 - 0xfbffffff (0x2000000) MX[B]
    [1] 0 0xf6000000 - 0xf7ffffff (0x2000000) MX[B]
    [2] -1 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
    [3] -1 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
    [4] -1 0x000f0000 - 0x000fffff (0x10000) MX[B]
    [5] -1 0x000c0000 - 0x000effff (0x30000) MX[B]
    [6] -1 0x00000000 - 0x0009ffff (0xa0000) MX[B]
    [7] -1 0xf5000000 - 0xf50000ff (0x100) MX[B]
    [8] -1 0xf5800000 - 0xf58000ff (0x100) MX[B]
    [9] -1 0xfc000000 - 0xfdffffff (0x2000000) MX[B]
    [10] -1 0xf9ff0000 - 0xf9ffffff (0x10000) MX[B](B)
    [11] -1 0xfa000000 - 0xfbffffff (0x2000000) MX[B](B)
    [12] -1 0xf6000000 - 0xf7ffffff (0x2000000) MX[B](B)
    [13] 0 0x000a0000 - 0x000affff (0x10000) MS[B](OprD)
    [14] 0 0x000b0000 - 0x000b7fff (0x8000) MS[B](OprD)
    [15] 0 0x000b8000 - 0x000bffff (0x8000) MS[B](OprD)
    [16] 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]
    [17] -1 0x00000000 - 0x000001ff (0x200) IX[B]E
    [18] -1 0x0000a400 - 0x0000a4ff (0x100) IX[B]
    [19] -1 0x0000a800 - 0x0000a8ff (0x100) IX[B]
    [20] -1 0x0000b000 - 0x0000b01f (0x20) IX[B]
    [21] -1 0x0000b400 - 0x0000b41f (0x20) IX[B]
    [22] -1 0x0000b800 - 0x0000b80f (0x10) IX[B]
    [23] -1 0x0000d800 - 0x0000d8ff (0x100) IX[B](B)
    [24] 0 0x000003b0 - 0x000003bb (0xc) IS[B](OprU)
    [25] 0 0x000003c0 - 0x000003df (0x20) IS[B](OprU)
    (==) TDFX(0): Write-combining range (0xfa000000,0x2000000)
    (II) TDFX(0): Textures Memory 9.36 MB
    (EE) TDFX(0): DRI requires Voodoo3 or later, disabling DRI.
    (II) TDFX(0): Using XFree86 Acceleration Architecture (XAA)
    Screen to screen bit blits
    Solid filled rectangles
    8x8 mono pattern filled rectangles
    Indirect CPU to Screen color expansion
    Solid Lines
    Dashed Lines
    Offscreen Pixmaps
    Driver provided NonTEGlyphRenderer replacement
    Setting up tile and stipple cache:
    6 128x128 slots
    (==) TDFX(0): Backing store disabled
    (==) TDFX(0): Silken mouse enabled
    (**) Option "dpms"
    (**) TDFX(0): DPMS enabled
    (II) TDFX(0): direct rendering disabled
    (II) Initializing built-in extension MIT-SHM
    (II) Initializing built-in extension XInputExtension
    (II) Initializing built-in extension XTEST
    (II) Initializing built-in extension XKEYBOARD
    (II) Initializing built-in extension LBX
    (II) Initializing built-in extension XC-APPGROUP
    (II) Initializing built-in extension SECURITY
    (II) Initializing built-in extension XINERAMA
    (II) Initializing built-in extension XFree86-Bigfont
    (II) Initializing built-in extension RENDER
    (**) Option "Protocol" "PS/2"
    (**) Mouse0: Protocol: "PS/2"
    (**) Option "CorePointer"
    (**) Mouse0: Core Pointer
    (**) Option "Device" "/dev/psaux"
    (==) Mouse0: Buttons: 3
    (**) Option "Emulate3Buttons" "no"
    (**) Option "ZAxisMapping" "4 5"
    (**) Mouse0: ZAxisMapping: buttons 4 and 5
    (II) Keyboard "Keyboard0" handled by legacy driver
    (II) XINPUT: Adding extended input device "Mouse0" (type: MOUSE)
    Could not init font path element unix/:7100, removing from list!
    Fatal server error:
    could not open default font &acute;fixed&acute;
    When reporting a problem related to a server crash, please send
    the full server output, not just the last messages.
    This can be found in the log file "/var/log/XFree86.0.log".
    Please report problems to xfree86@xfree86.org.
    []os
    MAJOR
    <IMG SRC="images/forum/icons/icon_mad.gif"> <IMG SRC="images/forum/icons/icon_mad.gif">
  2. vixivc ta com as fontes instaladas???????
    ele num ta encontrado o diretorio delas!!
  3. ta tudo instalado 1c3. <IMG SRC="images/forum/icons/icon_confused.gif">
    q chato isso enh??!
    <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon_mad.gif">
  4. e que directorio fica essas fontes????
    ai eu verifico. <IMG SRC="images/forum/icons/icon_cool.gif">
    []os
    MAJOR
  5. eh oq tiver definido no XF86Config na variavel FontPath
    pra prokurar ele da um
    locate NOME_DIRETORIO
  1. Continua o problema com rota
    Por redoctober no fórum Servidores de Rede
    Respostas: 13
    Último Post: 08-11-2002, 13:04
  2. Problema com os log do Apache
    Por Good_speed no fórum Servidores de Rede
    Último Post: 28-10-2002, 08:51
  3. Problemas com Perl
    Por adcorp no fórum Servidores de Rede
    Último Post: 17-08-2002, 11:52
  4. Problema com o ssh pelo windows !!!
    Por embbr no fórum Servidores de Rede
    Último Post: 01-07-2002, 18:10
  5. problemas com o IMP
    Por marlonfuchs no fórum Servidores de Rede
    Último Post: 27-06-2002, 08:13
