    Luke
    Padrão wine
    Não consegui fazer o wine rodar direito, alguem pode me dar uma luz, aqui esta meu config. /root/.wine/config
    WINE REGISTRY Version 2
    ;; All keys relative to \\Machine\\Software\\Wine\\Wine\\Config
    ;; MS-DOS drives configuration
    ;; Each section has the following format:
    ;; [Drive X]
    ;; "Path"="xxx" (Unix path for drive root)
    ;; "Type"="xxx" (supported types are ´floppy´, ´hd´, ´cdrom´ and ´network&acute
    ;; "Label"="xxx" (drive label, at most 11 characters)
    ;; "Serial"="xxx" (serial number, 8 characters hexadecimal number)
    ;; "Filesystem"="xxx" (supported types are ´msdos´/´dos´/´fat´, ´win95´/´vfat´, ´unix&acute
    ;; This is the FS Wine is supposed to emulate on a certain
    ;; directory structure.
    ;; Recommended:
    ;; - "win95" for ext2fs, VFAT and FAT32
    ;; - "msdos" for FAT16 (ugly, upgrading to VFAT driver strongly recommended)
    ;; DON´T use "unix" unless you intend to port programs using Winelib !
    ;; "Device"="/dev/xx" (only if you want to allow raw device access)
    [Drive A]
    "Path" = "/mnt/floppy"
    "Type" = "floppy"
    "Label" = "Floppy"
    "Serial" = "87654321"
    "Device" = "/dev/fd0"
    [Drive C]
    "Path" = "/mnt/HDWIN/"
    "Type" = "hd"
    "Label" = "winxp"
    "Filesystem" = "win95"
    "Device" = "/dev/hda1"
    [Drive D]
    "Path" = "/mnt/CDRW"
    "Type" = "cdrom"
    "Label" = "CDRW"
    ; make sure that device is correct and has proper permissions !
    "Device" = "/dev/cdrom"
    [Drive E]
    "Path" = "/mnt/CDROM"
    "Type" = "cdrom"
    "Label" = "CDROM"
    "Device" = "/dev/cdrom1"
    [Drive F]
    "Path" = "/tmp"
    "Type" = "hd"
    "Label" = "Tmp Drive"
    [Drive G]
    "Path" = "${HOME}"
    "Type" = "network"
    "Label" = "Home"
    [Drive Z]
    "Path" = "/"
    "Type" = "network"
    "Label" = "Root"
    [wine]
    "Windows" = "c:\\windows"
    "System" = "c:\\windows\\system"
    "Temp" = "e:\\"
    "Path" = "c:\\windows;c:\\Arquivos de Programas\\Internet Explorer\\;c:\\windows\\system;e:\\;e:\\test;f:\\"
    "Profile" = "c:\\windows\\Profiles\\Administrator"
    "GraphicsDriver" = "x11drv"
    ; Wine doesn´t pass directory symlinks to Windows programs by default.
    ; Enabling this may crash some programs that do recursive lookups of a whole
    ; subdir tree in case of a symlink pointing back to itself.
    ;"ShowDirSymlinks" = "1"
    "ShellLinker" = "wineshelllink"
    # <wineconf>
    [DllDefaults]
    ; "EXTRA_LD_LIBRARY_PATH" = "${HOME}/wine/cvs/lib"
    "DefaultLoadOrder" = "native, builtin, so"
    [DllOverrides]
    "commdlg" = "native, builtin"
    "comdlg32" = "native, builtin"
    "ver" = "native, builtin"
    "version" = "native, builtin"
    "shell" = "native, builtin"
    "shell32" = "native, builtin"
    "lzexpand" = "native, builtin"
    "lz32" = "native, builtin"
    "comctl32" = "native, builtin"
    "commctrl" = "native, builtin"
    "wsock32" = "builtin"
    "winsock" = "builtin"
    "advapi32" = "native, builtin"
    "crtdll" = "native, builtin"
    "mpr" = "native, builtin"
    "winspool.drv" = "native, builtin"
    "ddraw" = "native, builtin"
    "dinput" = "native, builtin"
    "dsound" = "native, builtin"
    "mmsystem" = "builtin"
    "winmm" = "builtin"
    "msvcrt" = "native, builtin"
    "msvideo" = "native, builtin"
    "msvfw32" = "native, builtin"
    "mcicda.drv" = "native, builtin"
    "mciseq.drv" = "native, builtin"
    "mciwave.drv" = "native, builtin"
    "mciavi.drv" = "native, builtin"
    "mcianim.drv" = "native, builtin"
    "msacm.drv" = "native, builtin"
    "msacm" = "native, builtin"
    "msacm32" = "native, builtin"
    "midimap.drv" = "native, builtin"
    "wnaspi32" = "builtin"
    "icmp" = "builtin"
    [x11drv]
    ; Number of colors to allocate from the system palette
    "AllocSystemColors" = "100"
    ; Use a private color map
    "PrivateColorMap" = "N"
    ; Favor correctness over speed in some graphics operations
    "PerfectGraphics" = "N"
    ; Color depth to use on multi-depth screens
    ;;"ScreenDepth" = "16"
    ; Name of X11 display to use
    ;;"Display" = ":0.0"
    ; Allow the window manager to manage created windows
    "Managed" = "N"
    ; Use a desktop window of 640x480 for Wine
    ;"Desktop" = "640x480"
    ; Use XFree86 DGA extension if present
    "UseDGA" = "Y"
    ; Use XShm extension if present
    "UseXShm" = "Y"
    ; Enable DirectX mouse grab
    "DXGrab" = "N"
    ; Create the desktop window with a double-buffered visual
    ; (useful to play OpenGL games)
    "DesktopDoubleBuffered" = "N"
    ; Code page used for captions in managed mode
    ; 0 means default ANSI code page (CP_ACP == 0)
    "TextCP" = "0"
    ; Use this if you have more than one port for video on your setup
    ; (Wine uses for now the first &acute;input image&acute; it finds).
    ;; "XVideoPort" = "43"
    [fonts]
    ;Read documentation/fonts before adding aliases
    "Resolution" = "96"
    "Default" = "-adobe-times-"
    [serialports]
    "Com1" = "/dev/ttyS0"
    "Com2" = "/dev/ttyS1"
    "Com3" = "/dev/ttyS2"
    "Com4" = "/dev/modem"
    [parallelports]
    "Lpt1" = "/dev/lp0"
    [spooler]
    "LPT1:" = "|lpr"
    ;"LPT2:" = "|gs -sDEVICE=bj200 -sOutputFile=/tmp/fred -q -"
    ;"LPT3:" = "/dev/lp3"
    [ports]
    "read" = "0x779,0x379,0x280-0x2a0"
    "write" = "0x779,0x379,0x280-0x2a0"
    [spy]
    "Exclude" = "WM_SIZE;WM_TIMER;"
    [registry]
    ;These are all booleans. Y/y/T/t/1 are true, N/n/F/f/0 are false.
    ;Defaults are read all, write to Home
    ; Global registries (stored in /etc)
    "LoadGlobalRegistryFiles" = "Y"
    ; Home registries (stored in ~user/.wine/)
    "LoadHomeRegistryFiles" = "Y"
    ; Load Windows registries from the Windows directory
    "LoadWindowsRegistryFiles" = "Y"
    ; TRY to write all changes to home registries
    "WritetoHomeRegistryFiles" = "Y"
    ; Registry periodic save timeout in seconds
    ; "PeriodicSave" = "600"
    ; Save only modified keys
    "SaveOnlyUpdatedKeys" = "Y"
    [Tweak.Layout]
    ;; supported styles are &acute;Win31&acute;(default), &acute;Win95&acute;, &acute;Win98&acute;
    "WineLook" = "Win98"
    [Console]
    ;"Drivers" = "tty"
    ;"XtermProg" = "nxterm"
    ;"InitialRows" = "25"
    ;"InitialColumns" = "80"
    ;"TerminalType" = "nxterm"
    [Clipboard]
    "ClearAllSelections" = "0"
    "PersistentSelection" = "1"
    # </wineconf>
    <IMG SRC="images/forum/icons/icon_smile.gif"> <IMG SRC="images/forum/icons/icon_smile.gif"> <IMG SRC="images/forum/icons/icon_smile.gif">
    Luke
    Padrão wine
    Tentei executar o winzip, e el me retornou:
    [[email protected] /root]# cd /mnt/HDWIN/Arquivos\ de\ programas/WinZip/
    [[email protected] WinZip]# win WINZIP32.EXE
    bash: win: command not found
    [[email protected] WinZip]# wine WINZIP32.EXE
    err:win32:fixup_imports No implementation for KERNEL32.dll.108(DeactivateActCtx) imported from C:\WINDOWS\system\WINSPOOL.DRV, setting to 0xdeadbeef
    err:win32:fixup_imports No implementation for KERNEL32.dll.0(ActivateActCtx) imported from C:\WINDOWS\system\WINSPOOL.DRV, setting to 0xdeadbeef
    err:win32:fixup_imports No implementation for KERNEL32.dll.668(ReleaseActCtx) imported from C:\WINDOWS\system\WINSPOOL.DRV, setting to 0xdeadbeef
    err:win32:fixup_imports No implementation for KERNEL32.dll.64(CreateActCtxW) imported from C:\WINDOWS\system\WINSPOOL.DRV, setting to 0xdeadbeef
    err:win32:fixup_imports No implementation for KERNEL32.dll.116(DelayLoadFailureHook) imported from C:\WINDOWS\system\WINSPOOL.DRV, setting to 0xdeadbeef
    err:win32:fixup_imports No implementation for KERNEL32.dll.131(DnsHostnameToComputerNameW) imported from C:\WINDOWS\system\WINSPOOL.DRV, setting to 0xdeadbeef
    err:win32:fixup_imports No implementation for RPCRT4.dll.441(RpcSmDestroyClientContext) imported from C:\WINDOWS\system\WINSPOOL.DRV, setting to 0xdeadbeef
    err:win32:fixup_imports No implementation for RPCRT4.dll.43(I_RpcExceptionFilter) imported from C:\WINDOWS\system\WINSPOOL.DRV, setting to 0xdeadbeef
    err:win32:fixup_imports No implementation for RPCRT4.dll.384(RpcMgmtIsServerListening) imported from C:\WINDOWS\system\WINSPOOL.DRV, setting to 0xdeadbeef
    err:win32:fixup_imports No implementation for USER32.dll.280(GetGUIThreadInfo) imported from C:\WINDOWS\system\WINSPOOL.DRV, setting to 0xdeadbeef
    tambem não consigo executar o Kazaa, só consegui executar dois programinhas pequenos, o RamBooster, gerenciador de memoria e o SMS, para mandar mensagens para celular. <IMG SRC="images/forum/icons/icon_smile.gif">
    Padrão wine
    Se vc receber esta mensagem tá td ok. <IMG SRC="images/forum/icons/icon_cool.gif">
    DDC
    Padrão wine
    e eu que nem conssegui estalar o Wine no meu pc como faço para realizar isso.
    Padrão wine
    Citação Postado originalmente por DDC
    qual distro vc usa?
