    Futuremax
    E esse é meu config:
    WINE REGISTRY Version 2
    ;; All keys relative to \\Machine\\Software\\Wine\\Wine\\Config
    ;; If you think it is necessary to show others your complete config for a
    ;; bug report, filter out empty lines and comments with
    ;; grep -v "^;" ~/.wine/config | grep ´.´
    ;; MS-DOS drives configuration
    ;; Each section has the following format:
    ;; [Drive X]
    ;; "Path"="xxx" (Unix path for drive root)
    ;; "Type"="xxx" (supported types are ´floppy´, ´hd´, ´cdrom´ and ´network&acute
    ;; "Label"="xxx" (drive label, at most 11 characters)
    ;; "Serial"="xxx" (serial number, 8 characters hexadecimal number)
    ;; "Filesystem"="xxx" (supported types are ´msdos´/´dos´/´fat´, ´win95´/´vfat´, ´unix&acute
    ;; This is the FS Wine is supposed to emulate on a certain
    ;; directory structure.
    ;; Recommended:
    ;; - "win95" for ext2fs, VFAT and FAT32
    ;; - "msdos" for FAT16 (ugly, upgrading to VFAT driver strongly recommended)
    ;; DON´T use "unix" unless you intend to port programs using Winelib !
    ;; "Device"="/dev/xx" (only if you want to allow raw device access)
    [Drive A]
    "Path" = "/mnt/floppy"
    "Type" = "floppy"
    "Label" = "a:"
    "Filesystem" = "win95"
    "Serial" = "87654321"
    "Device" = "/dev/fd0"
    [Drive C]
    "Path" = "/home/wine/c"
    "Type" = "hd"
    "Label" = "c:"
    [Drive D]
    "Path" = "/mnt/cdrom"
    "Type" = "cdrom"
    "Label" = "d:"
    ; make sure that device is correct and has proper permissions !
    "Device" = "/dev/cdrom"
    [Drive E]
    "Path" = "/tmp"
    "Type" = "hd"
    "Label" = "Tmp Drive"
    [Drive F]
    "Path" = "${HOME}"
    "Type" = "network"
    "Label" = "Home"
    [wine]
    ;"Windows" = "c:\\windows"
    "Windows" = "/home/wine/c/windows"
    ;"System" = "c:\\windows\\system"
    "System" = "/home/wine/c/windows/system"
    ;"Temp" = "e:\\"
    "Temp" = "/tmp"
    ;"Path" = "c:\\windows;c:\\windows\\system;e:\\;e:\\test;f:\\"
    "Path" = "/home/wine/c/windows;home/wine/c/windows/command"
    ;"Profile" = "c:\\windows\\Profiles\\Administrator"
    "GraphicsDriver" = "x11drv"
    ;"ShowDirSymlinks" = "1"
    ;"ShowDotFiles" = "1"
    "ShellLinker" = "wineshelllink"
    # <wineconf>
    [Version]
    ; Windows version to imitate (win95,win98,winme,nt351,nt40,win2k,winxp,win20,win30,win31)
    "Windows" = "win98"
    ; DOS version to imitate
    "DOS" = "6.22"
    ; Be careful here, wrong DllOverrides settings have the potential
    ; to pretty much kill your setup.
    [DllOverrides]
    ; some dlls you may want to change
    "oleaut32" = "builtin, native"
    "ole32" = "builtin, native"
    "commdlg" = "builtin, native"
    "comdlg32" = "builtin, native"
    "shell" = "builtin, native"
    "shell32" = "builtin, native"
    "shfolder" = "builtin, native"
    "shlwapi" = "builtin, native"
    "shdocvw" = "builtin, native"
    "advapi32" = "builtin, native"
    "msvcrt" = "native, builtin"
    "mciavi.drv" = "native, builtin"
    "mcianim.drv" = "native, builtin"
    ; you can specify applications too
    ; this one will apply for all notepad.exe
    ;"*notepad.exe" = "native, builtin"
    ; this one will apply only for a particular file
    ;"C:\\windows\\regedit.exe" = "native, builtin"
    ; default for all other dlls
    "*" = "native ,builtin"
    [x11drv]
    ; Number of colors to allocate from the system palette
    "AllocSystemColors" = "100"
    ; Use a private color map
    "PrivateColorMap" = "N"
    ; Favor correctness over speed in some graphics operations
    "PerfectGraphics" = "N"
    ; Color depth to use on multi-depth screens
    ;;"ScreenDepth" = "16"
    ; Name of X11 display to use
    ;;"Display" = ":0.0"
    ; Allow the window manager to manage created windows
    "Managed" = "Y"
    ; Use a desktop window of 640x480 for Wine
    ;"Desktop" = "640x480"
    ; Use XFree86 DGA extension if present
    ; (make sure /dev/mem is accessible by you !)
    "UseDGA" = "Y"
    ; Use XShm extension if present
    "UseXShm" = "Y"
    ; Use XVidMode extension if present
    "UseXVidMode" = "Y"
    ; Use the take focus protocol
    "UseTakeFocus" = "Y"
    ; Enable DirectX mouse grab
    "DXGrab" = "N"
    ; Create the desktop window with a double-buffered visual
    ; (useful to play OpenGL games)
    "DesktopDoubleBuffered" = "N"
    ; Code page used for captions in managed mode
    ; 0 means default ANSI code page (CP_ACP == 0)
    "TextCP" = "0"
    ; Use this if you have more than one port for video on your setup
    ; (Wine uses for now the first &acute;input image&acute; it finds).
    ;; "XVideoPort" = "43"
    ; Run in synchronous mode (useful for debugging X11 problems)
    ;;"Synchronous" = "Y"
    ; Use the Render extension to render client side fonts (default "Y&quot<IMG SRC="images/forum/icons/icon_wink.gif">
    ;;"ClientSideWithRender" = "Y"
    ; Fallback on X core requests to render client side fonts (default "Y&quot<IMG SRC="images/forum/icons/icon_wink.gif">
    ;;"ClientSideWithCore" = "Y"
    ; Set both of the previous two to "N" in order to force X11 server side fonts
    ; Anti-alias fonts if using the Render extension (default "Y&quot<IMG SRC="images/forum/icons/icon_wink.gif">
    ;;"ClientSideAntiAliasWithRender" = "Y"
    ; Anti-alias fonts if using core requests fallback (default "Y&quot<IMG SRC="images/forum/icons/icon_wink.gif">
    ;;"ClientSideAntiAliasWithCore" = "Y"
    [fonts]
    ;Read the Fonts topic in the Wine User Guide before adding aliases
    ;See a couple of examples for russian users below
    "Resolution" = "96"
    "Default" = "-adobe-helvetica-"
    "DefaultFixed" = "fixed"
    "DefaultSerif" = "-adobe-times-"
    "DefaultSansSerif" = "-adobe-helvetica-"
    ;; default TrueType fonts with russian koi8-r encoding
    ;"Default" = "-monotype-arial-*-*-*--*-*-*-*-*-*-koi8-r"
    ;"DefaultFixed" = "-monotype-courier new-*-*-*--*-*-*-*-*-*-koi8-r"
    ;"DefaultSerif" = "-monotype-times new roman-*-*-*--*-*-*-*-*-*-koi8-r"
    ;"DefaultSansSerif" = "-monotype-arial-*-*-*--*-*-*-*-*-*-koi8-r"
    ;; default cyrillic bitmap X fonts
    ;"Default" = "-cronyx-helvetica-"
    ;"DefaultFixed" = "fixed"
    ;"DefaultSerif" = "-cronyx-times-"
    ;"DefaultSansSerif" = "-cronyx-helvetica-"
    ; the TrueType font dirs you want to make accessible to wine
    [FontDirs]
    ;"dir1" = "/usr/X11R6/lib/X11/fonts/TrueType"
    ;"dir2" = "/usr/share/fonts/truetype"
    ;"dir3" = "/usr/X11R6/lib/X11/fonts/TT"
    ;"dir4" = "/usr/share/fonts/TT"
    [serialports]
    "Com1" = "/dev/ttyS0"
    "Com2" = "/dev/ttyS1"
    "Com3" = "/dev/ttyS2"
    "Com4" = "/dev/modem"
    [parallelports]
    "Lpt1" = "/dev/lp0"
    [ppdev]
    ;; key: io-base of the emulated port
    ;; value : parport-device{,timeout}
    ;; timeout for auto closing an open device ( not yet implemented)
    ;"378" = "/dev/parport0"
    ;"278" = "/dev/parport1"
    ;"3bc" = "/dev/parport2"
    [spooler]
    "FILE:" = "tmp.ps"
    "LPT1:" = "|lpr"
    "LPT2:" = "|gs -sDEVICE=bj200 -sOutputFile=/tmp/fred -q -"
    "LPT3:" = "/dev/lp3"
    [ports]
    ;"read" = "0x779,0x379,0x280-0x2a0"
    ;"write" = "0x779,0x379,0x280-0x2a0"
    [Debug]
    ;"RelayExclude" = "RtlEnterCriticalSection;RtlLeaveCriticalSection"
    ;"RelayInclude" = "user32.CreateWindowA"
    ;"SnoopExclude" = "RtlEnterCriticalSection;RtlLeaveCriticalSection"
    ;"SpyExclude" = "WM_SIZE;WM_TIMER;"
    [registry]
    ;These are all booleans. Y/y/T/t/1 are true, N/n/F/f/0 are false.
    ;Defaults are read all, write to Home
    ; Where to find the global registries
    ;"GlobalRegistryDir" = "/etc";
    ; Global registries (stored in /etc)
    "LoadGlobalRegistryFiles" = "Y"
    ; Home registries (stored in ~user/.wine/)
    "LoadHomeRegistryFiles" = "Y"
    ; Load Windows registries from the Windows directory
    "LoadWindowsRegistryFiles" = "Y"
    ; TRY to write all changes to home registries
    "WritetoHomeRegistryFiles" = "Y"
    ; Registry periodic save timeout in seconds
    ; "PeriodicSave" = "600"
    ; Save only modified keys
    "SaveOnlyUpdatedKeys" = "Y"
    [Tweak.Layout]
    ;; supported styles are &acute;Win31&acute;(default), &acute;Win95&acute;, &acute;Win98&acute;
    ;; this has *nothing* to do with the windows version Wine returns:
    ;; set the "Windows" value in the [Version] section if you want that.
    "WineLook" = "Win95"
    [Console]
    ;"Drivers" = "tty"
    ;"XtermProg" = "nxterm"
    ;"InitialRows" = "25"
    ;"InitialColumns" = "80"
    ;"TerminalType" = "nxterm"
    [Clipboard]
    "ClearAllSelections" = "0"
    "PersistentSelection" = "1"
    ; List of all directories directly contain .AFM files
    [afmdirs]
    "1" = "/usr/share/ghostscript/fonts"
    "2" = "/usr/share/a2ps/afm"
    "3" = "/usr/share/enscript"
    "4" = "/usr/X11R6/lib/X11/fonts/Type1"
    [WinMM]
    #"Drivers" = "winearts.drv"
    #"Drivers" = "winejack.drv"
    "Drivers" = "wineoss.drv"
    "WaveMapper" = "msacm.drv"
    "MidiMapper" = "midimap.drv"
    [dsound]
    ;; HEL only: Number of waveOut fragments ahead to mix in new buffers.
    ;"HELmargin" = "5"
    ;; HEL only: Number of waveOut fragments ahead to queue to driver.
    ;"HELqueue" = "5"
    ;; Max number of fragments to prebuffer
    ;"SndQueueMax" = "28"
    ;; Min number of fragments to prebuffer
    ;"SndQueueMin" = "12"
    [Network]
    ;; Use the DNS (Unix) host name always as NetBIOS "ComputerName" (boolean, default "Y&quot<IMG SRC="images/forum/icons/icon_wink.gif">.
    ;; Set to N if you need a persistent NetBIOS ComputerName that possibly differs
    ;; from the Unix host name. You&acute;ll need to set ComputerName in
    ;; HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\ComputerName\ComputerName, too.
    ;"UseDnsComputerName" = "N"
    ;; sample AppDefaults entries
    ;[AppDefaults\\iexplore.exe\\DllOverrides]
    ;"shlwapi" = "native"
    ;"rpcrt4" = "native"
    ;"ole32" = "native"
    ;"shdocvw" = "native"
    ;"wininet" = "native"
    ;"shfolder" = "native"
    ;"shell32" = "native"
    ;"shell" = "native"
    ;"comctl32" = "native"
    ;[AppDefaults\\setup.exe\\x11drv]
    ;"Desktop" = "800x600"
    ;[AppDefaults\\sol.exe\\Version]
    ;"Windows" = "nt40"
    ;; Some games (Quake 2, UT) refuse to accept emulated dsound devices.
    ;; You can add an AppDefault entry like this for such cases.
    ;[AppDefaults\\pickygame.exe\\dsound]
    ;"EmulDriver" = "N"
    # </wineconf>
  2. #17
    AndrewAmorimdaSilva
    Ah tá ai o problema!!!!!
    No começo......descomente:
    ;; [Drive X]
    ;; "Type"="xxx" (supported types are &acute;floppy&acute;, &acute;hd&acute;, &acute;cdrom&acute; and &acute;network&acute
    ;; "Filesystem"="xxx" (supporte&acute;msdos&acute;/&acute;dos&acute;/&acute;fat&acute;, &acute;win95&acute;/&acute;vfat&acute;, &acute;unix&acute
    Deixe assim!!!!
    [Drive X]
    "Path"="/"
    "Type"="hd"
    "Label"="Linux"
    "Serial"="123456789"
    "Filesystem"="win95"
    Teste agora!!!! <IMG SRC="images/forum/icons/icon_wink.gif"> <IMG SRC="images/forum/icons/icon_wink.gif">
  3. #18
    Futuremax
    Fix your wine config to use DOS drive syntax in [wine] &acute;Path=&acute; statement! (no &acute;/&acute; allowed)
    Perhaps you have not properly edited or created your Wine configuration file.
    This is (supposed to be) &acute;/root/.wine/config&acute;
    Resolvemos um falta esse....
    <IMG SRC="images/forum/icons/icon_eek.gif">
  4. tira a / do final do path
    alias tira naum... troca
    para seu path correto
    [ Esta mensagem foi editada por: 1c3_m4n em 12-02-2003 10:28 ]
  5. #20
    Futuremax
    FUNFOU!!!!!!!
    HAHAHAHAHAHAHAHAHAHAHAHA!!!!!!!!!
    Era só tirar o comentário da linha do path e comentar a que foi adicionada.....
    VALEW A AJUDA GALERA!!!!!!!!!!!!!!!
    EEEEEEEEEEEEEEEEEEEEEEEEEEEEEE....
    HUEHAUHUAHAUHAUEHUEHUHAUHUUU
    <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif"> <IMG SRC="images/forum/icons/icon_biggrin.gif">
  1. uebimiau-erro de novo
    Último Post: 18-02-2005, 16:29
  2. PosFix de novo???
    Por c4f0f0 no fórum Servidores de Rede
    Respostas: 9
    Último Post: 24-10-2003, 10:59
  3. Precisando de ajuda com o Speedy(ADSL) de novo!!
    Por Sheep_NCG no fórum Servidores de Rede
    Respostas: 5
    Último Post: 31-01-2003, 00:16
  4. Eu pat de novo
    Último Post: 13-12-2002, 14:33
  5. De novo E-mail com Sub-Dominios !!
    Por rosauro no fórum Servidores de Rede
    Último Post: 02-11-2002, 14:49
