    Pedrinha
    Desculpe a demorá amigo estava muito ocupado mas aqui está amigo eu não sei no que está errado já mexi um monte de coisas copiei o snort.conf para o root .snortrc num foi tb depois coloquei o reference dentro do root ai mudou o erro mas o que significa esse reference ? pretendo mais tarde atualizar ele mais quero fazer funcionar esse primeiro ok, o erro que dá agora é esse ex:
    var HOME_NET $ppp0_ADDRESS
    May 11 02:55:32 snort: PID stat checked out ok, PID set to /var/run/
    May 11 02:55:32 snort: Writing PID file to "/var/run/"
    May 11 02:55:32 snort: Initializing daemon mode
    May 11 02:55:32 snort: FATAL ERROR: Error: Unknown config: reference
    Mai 11 02:55:32 snort: snort startup succeeded
    o meu snort.conf
    var EXTERNAL_NET any 200.xxx.xxx
    var DNS_SERVERS $HOME_NET
    var SMTP_SERVERS $HOME_NET
    var HTTP_SERVERS $HOME_NET
    var SQL_SERVERS $HOME_NET
    var TELNET_SERVERS $HOME_NET
    var HTTP_PORTS 80
    var SHELLCODE_PORTS !80
    var ORACLE_PORTS 1521
    var AIM_SERVERS [64.12.24.0/24,64.12.25.0/24,64.12.26.14/24,64.12.28.0/24,64.12.29.0/24,64.12.161.0/24,64.12.163.0/24,205.188.5.0/24,205.188.9.0/24]
    var RULE_PATH /etc/snort
    preprocessor frag2
    preprocessor stream4: detect_scans, disable_evasion_alerts
    preprocessor stream4_reassemble
    preprocessor http_decode: 80 -unicode -cginull
    preprocessor rpc_decode: 111
    preprocessor bo: -nobrute
    preprocessor telnet_dec
    include classification.configode
    include reference.config
    include $RULE_PATH/bad-traffic.rules
    include $RULE_PATH/exploit.rules
    include $RULE_PATH/scan.rules
    include $RULE_PATH/finger.rules
    include $RULE_PATH/ftp.rules
    include $RULE_PATH/telnet.rules
    include $RULE_PATH/rpc.rules
    include $RULE_PATH/rservices.rules
    include $RULE_PATH/dos.rules
    include $RULE_PATH/ddos.rules
    include $RULE_PATH/dns.rules
    include $RULE_PATH/tftp.rules
    include $RULE_PATH/web-cgi.rules
    include $RULE_PATH/web-coldfusion.rules
    include $RULE_PATH/web-iis.rules
    include $RULE_PATH/web-frontpage.rules
    include $RULE_PATH/web-misc.rules
    include $RULE_PATH/web-client.rules
    include $RULE_PATH/web-php.rules
    include $RULE_PATH/sql.rules
    include $RULE_PATH/x11.rules
    include $RULE_PATH/icmp.rules
    include $RULE_PATH/netbios.rules
    include $RULE_PATH/misc.rules
    include $RULE_PATH/attack-responses.rules
    include $RULE_PATH/oracle.rules
    #include $RULE_PATH/mysql.rules
    include $RULE_PATH/snmp.rules
    include $RULE_PATH/smtp.rules
    include $RULE_PATH/imap.rules
    include $RULE_PATH/pop3.rules
    include $RULE_PATH/pop2.rules
    include $RULE_PATH/nntp.rules
    include $RULE_PATH/other-ids.rules
    include $RULE_PATH/web-attacks.rules
    # include $RULE_PATH/backdoor.rules
    # include $RULE_PATH/shellcode.rules
    # include $RULE_PATH/policy.rules
    # include $RULE_PATH/porn.rules
    include $RULE_PATH/info.rules
    include $RULE_PATH/icmp-info.rules
    include $RULE_PATH/virus.rules
    include $RULE_PATH/chat.rules
    include $RULE_PATH/multimedia.rules
    include $RULE_PATH/p2p.rules
    include $RULE_PATH/experimental.rules
    include $RULE_PATH/local.rules
    include $RULE_PATH/vision.rules
    Valeu a força
  2. #7
    No seu arquivo /etc/snort deve ter os arquivos
    classification.config e reference.config
    tem eles la ?
    <IMG SRC="images/forum/icons/icon_smile.gif">
    []`s
    Daniel B. Cid (insonia) hehe
    daniel@under-linux.org
  3. #8
    Pedrinha
    sim tem eles sim mas num consegui entender ele ainda funcionamento...
    flw valeu..
  4. sua external net esta errada... voce nao pode dar espaco tem que usar [iprange,iprange]
    um bom comeco seria
    e nao defineir um ip no external. senao ele so ira ler alertas daquele ip que voce botou (e mais any jah que voce deixou any, mas trabalho para o cpu)
    ele reclama de um unknown config reference ... verifique a linha do classification e do reference se elas estao digitadas corretamente.
    qual a linha que voce esta usando para iniciar o snort? (por acaso voce jah atualizou ela para 2.0?) eu acredito que voce baixou o rules-stable.tar.gz ou o current, bom baixe o stable e use com o snort 2.0 se voce esta com o rules atual e tentando rodar no 2.0 eu nao sei nem o q pode dar, mas simplesmente nao va funcionar.
    faca o q eu disse, atualize o snort 2.0 crie o /etc/snort copie todos os etc do snort para la. e tambem o rules. edite o snort.conf para atender suas necessidades e rode ele.. o basico eh snort -c config.file para ele ler o /etc/snort.conf. tente isso e veja no que da.
  1. Plugin no Nagios - Num vai
    Por spyderlinux no fórum Servidores de Rede
    Último Post: 25-07-2006, 10:35
  2. Instalação e Configuração do Snort
    Por no fórum Segurança
    Último Post: 05-12-2002, 23:23
  3. Vai e naum vai!!!!!
    Último Post: 05-12-2002, 11:19
  4. SNORT
    Por 1c3m4n no fórum Segurança
    Último Post: 02-12-2002, 08:51
  5. Wireless não vai nem a pau ...
    Respostas: 5
    Último Post: 12-11-2002, 17:24
