    Mano valeu funncionou aplicando apenas o comando xhost +local:root
    Vakeu mesmo
  2. #7
    devlinmaxx
    <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    Vakeu mesmo
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
    UNDER!!!!
    Boa, precisando dabe onde encontrar bro!!!
    [&acute;s]
  3. #8
    jamba
    XXXIIIIIII
    ainda continua dando problemas, alem de ter q dar o comando xhost +local:root denovo pra rodar o programa ele acusa um erro tb:
    ** WARNING **: The X-CD-Roast wrapper seems not to have the correct
    permissions set
    ** WARNING **: So do as root something like that:
    chown root:cdwrite /usr/lib/xcdroast-0.98/bin/xcdrwrap;
    chmod 2755 /usr/lib/xcdroast-0.98/bin/xcdrwrap
    ** WARNING **: For more information read
    /usr/share/doc/xcdroast-0.98a9/README.nonroot
    *** NOTE ***:
    This permission warning and the following set-uid bit warnings
    can be safely ignored, if you want to run X-CD-Roast as root only.
    to correndo atras mas ate agora nao consegui, me ajuda ai de novo por favor!!!]
    obs: a mensagens antes postadas seo minhas eh q esqueci de logar
  1. Xcdroast!
    Por PiTsA no fórum Servidores de Rede
    Respostas: 10
    Último Post: 30-06-2003, 01:02
