  1. Este é um dos que tentei
    #Recommended minimum configuration:
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl CONNECT method CONNECT
    acl bad_sites dstdom_regex "/etc/squid/bad_sites"
    acl bad_palavras dstdom_regex "/etc/squid/bad_palavras"
    acl password proxy_auth REQUIRED
    #Default:
    # http_access deny all
    http_access deny bad_sites
    http_access deny bad_palavras
    http_access allow password
    # Only allow cachemgr access from localhost
    http_access deny manager
    # Deny requests to unknown ports
    http_access deny !Safe_ports
    # Deny CONNECT to other than SSL ports
    # INSERT YOUR OWN RULE(S) HERE TO ALLOW ACCESS FROM YOUR CLIENTS
    # And finally deny all other access to this proxy
    http_access allow localhost
  2. #7
    Futuremax
    A acl autenticate_program tá como???
    Parece que o problema tá nela....
  3. Esta assim...
    # TAG: authenticate_program
    # Specify the command for the external authenticator. Such a
    # program reads a line containing "username password" and replies
    # "OK" or "ERR" in an endless loop. If you use an authenticator,
    # make sure you have 1 acl of type proxy_auth. By default, the
    # authenticator_program is not used.
    # If you want to use the traditional proxy authentication,
    # jump over to the ../auth_modules/NCSA directory and
    # type:
    # % make
    # % make install
    # Then, set this line to something like
    # authenticate_program /usr/bin/ncsa_auth /usr/etc/passwd
    #Default:
    # none
    authenticate_program /usr/bin/ncsa_auth /usr/etc/squid_passwd
    # TAG: authenticate_children
  4. #9
    Futuremax
    E na hora de cirar o passwd que comando vc usou??
  5. #10
    Passei pelo mesmo problema, configurava o squid certinho no Conectiva e não funcionava. Resolvi então instalar o Red Hat 7.3 com squid 4.0. Instalei configurei igualzinho o do conectiva e para minha felicidade funcionou na primeira.
  1. proxy transparente Squid desta vez não está funcionando
    Por RenatoRS no fórum Servidores de Rede
    Último Post: 26-06-2010, 17:16
  2. Dúvida SQUID -> bloqueio de palavras não está funcionando
    Por dpcl no fórum Servidores de Rede
    Respostas: 8
    Último Post: 04-01-2010, 16:46
  3. Autenticaçao NCSA do squid não está funcionando
    Por slacklex no fórum Servidores de Rede
    Último Post: 06-05-2006, 11:54
  4. autenticação squid nao esta funcionando
    Por muganga no fórum Servidores de Rede
    Respostas: 6
    Último Post: 18-02-2004, 12:50
  5. acl no squid não está funcionando. O que fazer ?
    Último Post: 20-12-2002, 16:01
