  1. selecionar pra gravar em 4x , mas ele mostro q iria gravar em 8X...
    e um arquivo WAV de mais de 500MB... no final gravo em 999x e em menos
    de 1 segundo..... puts...perdia a midia....
    que será q aconteceu?! tentei gravar em DAO e falo q o gravador num aceita...
    depois tentei gravar em TAO e deu na mesma......
    meu gravador é um LG 52x24x52 ...
    olha os logs:
    Calling: /usr/lib/xcdroast-0.98/bin/xcdrwrap CDRECORD dev=ATAPI:0,0,0 gracetime=2 fs=2048k driveropts=burnfree -v -useinfo sp
    eed=4 defpregap=0 -eject -pad -audio "/tmp/andyc.wav" ...
    scsidev: ´ATAPI:0,0,0´
    pregap1: -1
    devname: ´ATAPI´
    Cdrecord 2.0 (i686-pc-linux-gnu) Copyright (C) 1995-2002 Jörg Schilling
    scsibus: 0 target: 0 lun: 0
    TOC Type: 0 = CD-DA
    Warning: Using ATA Packet interface.
    Using libscg version ´schily-0.7´
    Warning: The related libscg interface code is in pre alpha.
    Driveropts: ´burnfree´
    Warning: There may be fatal problems.
    atapi: 1
    Device type : Removable CD-ROM
    Version : 0
    Response Format: 2
    Capabilities :
    Vendor_info : ´HL-DT-ST´
    Identifikation : ´CD-RW GCE-8520B ´
    Revision : ´1.00´
    Device seems to be: Generic mmc CD-RW.
    Using generic SCSI-3/mmc CD-R driver (mmc_cdr).
    Driver flags : MMC-2 SWABAUDIO BURNFREE
    Supported modes: TAO PACKET SAO SAO/R96P SAO/R96R RAW/R16 RAW/R96P RAW/R96R
    Drive buf size : 1467136 = 1432 KB
    FIFO size : 2097152 = 2048 KB
    cdrecord: Drive needs to reload the media to return to proper status.
    Track 01: audio 518 MB (51:19.62) no preemp pad
    Total size: 518 MB (51:19.64) = 230973 sectors
    Lout start: 518 MB (51:21/4<IMG SRC="images/forum/icons/icon_cool.gif"> = 230973 sectors
    Current Secsize: 2048
    ATIP info from disk:
    Indicated writing power: 6
    Is not unrestricted
    Is not erasable
    Disk sub type: Medium Type C, low Beta category (C-) (6)
    ATIP start of lead in: -11619 (97:27/06)
    ATIP start of lead out: 359848 (79:59/73)
    Disk type: Short strategy type (Phthalocyanine or similar)
    Manuf. index: 34
    Manufacturer: DIGITAL STORAGE TECHNOLOGY CO.,LTD
    Trying to clear drive status.
    Starting to write CD/DVD at speed 8 in real TAO mode for single session.
    Waiting for reader process to fill input buffer ...
    input buffer ready.
    BURN-Free is ON.
    Performing OPC...
    Writing time: 0.060s
    cdrecord: Input/output error. read track info: scsi sendcmd: no error
    Average write speed 999.0x.
    CDB: 52 01 00 00 00 FF 00 00 1C 00
    Fixating...
    status: 0x2 (CHECK CONDITION)
    Fixating time: 0.002s
    Sense Bytes: 70 00 05 00 00 00 00 0A 00 00 00 00 30 06 00 00 00 00
    Sense Key: 0x5 Illegal Request, Segment 0
    Sense Code: 0x30 Qual 0x06 (cannot format medium - incompatible medium) Fru 0x0
    Sense flags: Blk 0 (not valid)
    cmd finished after 0.000s timeout 240s
    BURN-Free was never needed.
    cdrecord: fifo had 32 puts and 0 gets.
    cdrecord: fifo was 0 times empty and 0 times full, min fill was 100%.
    [ Esta mensagem foi editada por: PiTsA em 25-06-2003 08:39 ]
  2. Eita, ja aconteceu isso comigo, mudei de midia e funcionou, mas creio nao ter algo a ver com a midia nao, *eu nao uso o XCDRoast*... =)
  3. ta bom.... mas explique entaum como gravar um cd decentemente a uma velocidade de 4x?!
    mas tipo....num da pra ter idéia do q é o erro acima?!
  4. Voce ta usando CD-RW ai?
  5. era CD-R normal.....
    ainda naum usei CD-RW aqui.....
    mas como eu configuro pra gravar no minimo um CD simples?!
  1. xcdroast
    Respostas: 7
    Último Post: 22-05-2003, 09:09
