    muganga
    galera....valeu...um problema ja esta solucionado, era mesmo a questao de espaço...desinstalei alguns pacotes e pronto ...quando dou service squid stop , o squid para beleza....e quando dou um service squid start ele tambem levanta beleza.....o problema agora é que depois de startado....o squid vem com dois PIDS.....e tambem mesmo eu deixando sem especificar a porta e o gw no Internet Explorer ...o pessoal consegue navegar....ou seja...tanto faz ter o squid rodando ou nao... vejam so os log do squid
    quero saber porque ainda consigo navegar mesmo sem especificar o gw e a porta 3128 no internet explorer?
    Oct 10 12:02:11 aurora squid[2781]: Squid Parent: child process 2783 started
    Out 10 12:02:13 aurora squid: Project-Id-Version: PO-Revision-Date: YYYY-MM-DD HH:MM TZO DST Last-Translator: Language-Team: <XX@li.org> MIME-Version: 1.0 Content-Type: text/plain; charset=ISO-8859-1 Content-Transfer-Encoding: 8-bit succeeded
    Out 10 12:04:08 aurora squid: Project-Id-Version: PO-Revision-Date: YYYY-MM-DD HH:MM TZO DST Last-Translator: Language-Team: <XX@li.org> MIME-Version: 1.0 Content-Type: text/plain; charset=ISO-8859-1 Content-Transfer-Encoding: 8-bit succeeded
    Oct 10 12:04:09 aurora squid[2781]: Squid Parent: child process 2783 exited with status 0
    Oct 10 12:04:16 aurora squid[2832]: Squid Parent: child process 2834 started
    Out 10 12:07:07 aurora squid: Project-Id-Version: PO-Revision-Date: YYYY-MM-DD HH:MM TZO DST Last-Translator: Language-Team: <XX@li.org> MIME-Version: 1.0 Content-Type: text/plain; charset=ISO-8859-1 Content-Transfer-Encoding: 8-bit succeeded
    Oct 10 12:07:07 aurora squid[2832]: Squid Parent: child process 2834 exited with status 0
    Out 10 12:07:09 aurora squid: Project-Id-Version: PO-Revision-Date: YYYY-MM-DD HH:MM TZO DST Last-Translator: Language-Team: <XX@li.org> MIME-Version: 1.0 Content-Type: text/plain; charset=ISO-8859-1 Content-Transfer-Encoding: 8-bit failed
    Oct 10 12:07:11 aurora squid[2924]: Squid Parent: child process 2926 started
    Out 10 12:07:13 aurora squid: Project-Id-Version: PO-Revision-Date: YYYY-MM-DD HH:MM TZO DST Last-Translator: Language-Team: <XX@li.org> MIME-Version: 1.0 Content-Type: text/plain; charset=ISO-8859-1 Content-Transfer-Encoding: 8-bit succeeded
    valeu
    Muganga
  2. vc precisa fechar a porta 80 para a rede interna ia o pessoal tera que usar o proxy senão não navega !!!!!!!!! valeu bom lamoço a todos .
    smvda......fiz o que voce falou fui la no squid.conf e comentei a linha da ACL porta 80....mas ai nao consigo navegar de maneira alguma.....o problema agora é o seguinte....
    veja meu squid
    http_port 3128
    hierarchy_stoplist cgi-bin ?
    no_cache deny QUERY
    cache_dir ufs /var/cache/squid 120 16 256
    cache_log none
    cache_store_log none
    acl redelocal src 10.1.1.0/255.255.255.0
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl CONNECT method CONNECT
    http_access deny manager
    http_access deny !Safe_ports
    http_access allow redelocal
    http_access deny all
    se no INTERNET EXPLORER eu nao especificar o gateway e a porta do squid 3128...o pessoal navega normalmente.....o que eu quero fazer é se a pessoa for no INTERNET EXPLORER e tirar o gw e a porta...essa pessoa nao consiga navegar na internet......COMO FAÇO ISSO?
    obrigado
    Muganga
  4. não a porta 80 do squid tenque ficar aberta o que vc precisa fechar é no firewall .......... entendeu .... vc deve ter um nat para que sua rede interna navegue certo ???
    este nat funciona para a porta 80 também certo ??
    então faça o nat de todas as portas que vc usa mesmos a 80 mas não esqueça de librerar a 3128 .............. entendeu ????
    smvda....por enquanto minhas regras de nat no rc.local sao as seguintes...
    iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
    iptables -t nat -A POSTROUTING -p tcp --dporte 80 -j DENY
    coloquei isso no /etc/rc.local so que ainda continuo com o problema.
    obrigado
    Muganga
  1. squid
    Por rosane no fórum Servidores de Rede
    Último Post: 26-05-2006, 18:11
  2. Bridge + Iptables + Squid Remoto
    Por Machado no fórum Servidores de Rede
    Último Post: 26-08-2003, 09:04
  3. Squid
    Por mauri no fórum Servidores de Rede
    Último Post: 03-06-2002, 20:43
  4. Bloquear sites no squid - urgente
    Por bauer no fórum Servidores de Rede
    Último Post: 21-05-2002, 22:53
  5. Squid
    Por luiz_nando no fórum Servidores de Rede
    Último Post: 10-05-2002, 19:05
