    Padrão Erro na instalação do modem!
    Ola, estive tentando instalar meu modem hsp56 da pctel e ocorreu um erro durante a instalação abaixo esta descrita a saida do terminal.
    [[email protected] pctel-0.9.6]# ./configure --with-hal=cm8738 --with-kernel-includes=/usr/src/linux/include
    make
    configure: WARNING: you should use --build, --host, --target
    checking for a BSD-compatible install... /usr/bin/install -c
    checking whether build environment is sane... yes
    checking for gawk... gawk
    checking whether make sets ${MAKE}... yes
    checking build driver for... HAL_CM8738
    checking for make-gcc... no
    checking for gcc... gcc
    checking for C compiler default output... a.out
    checking whether the C compiler works... yes
    checking whether we are cross compiling... no
    checking for suffix of executables...
    checking for suffix of object files... o
    checking whether we are using the GNU C compiler... yes
    checking whether gcc accepts -g... yes
    checking for style of include used by make... GNU
    checking dependency style of gcc... none
    checking whether make sets ${MAKE}... (cached) yes
    checking whether ln -s works... yes
    checking for gawk... (cached) gawk
    checking how to run the C preprocessor... gcc -E
    checking for ANSI C header files... yes
    checking for sys/types.h... yes
    checking for sys/stat.h... yes
    checking for stdlib.h... yes
    checking for string.h... yes
    checking for memory.h... yes
    checking for strings.h... yes
    checking for inttypes.h... yes
    checking for stdint.h... yes
    checking for unistd.h... yes
    checking /usr/src/linux/include/linux/modversions.h usability... no
    checking /usr/src/linux/include/linux/modversions.h presence... no
    checking for /usr/src/linux/include/linux/modversions.h... no
    configure: error: modversions.h is missing - you should configure your kernel first!
    Se alguem puder me ajudar com isso agradeço.
    Ps: A distro que estou utilizando é a Red Hat 9. Por favor alguem me ajude!!!!!!
    Ola anonimo , entao ja houviu falar em recompilar o kernel?
    hiihhihiohohoohhohohohuhuhuhuhuhu
    entao , modversions.h isso que seu log esta soltando de erro , entao trata de compilar o kernel com ele =]
    sabe recompilar?
    abracos
    Rooter
    Me corrijam se eu estiver errado, mas isso não seria a falta do kernel-headers ?
    Cara não faço ideia de como compilar o kernel??
    Não sei se percebeu sou iniciante...hehhe
    Valhalla
    Se não me falhe a memória o comando p/ recompilar é algo como makemenuconfig <IMG SRC="images/forum/icons/icon_eek.gif">
    Pessoal por favor me ajudem como faço para recompilar esse kernel????
    Caro amigo para recompilar o seu kernel vc precisa do fonte dele e depois usar os seguinter procedimentos
    make menuconfig -> configure e kernel.
    make clean
    make dep -> dependencias
    make bzlilo -> gera imagem lilo
    make modules -> compila os módulos
    make modules_install -> instala os módulos
    <IMG SRC="images/forum/icons/icon24.gif">
    Colega o que é esse tal de "fonte" onde baixo isso e qual a função dele???
    Cara "fonte" é o código do kernel .... quando vc compila vc trabnsforma código em linguagem de maquina gera o executavel ...... acho que vc precisa melhorar seus conhecimentos en informatica, pois a compilação do kernel é um processo avançado dentro do linux !!!!!!!!!!!! <IMG SRC="images/forum/icons/icon_eek.gif">
    Valeu pela dica cara...vou ter que melhorar os meus conhecimentos.. pelo jeito esse modem vai ficar sem funcionar!!!!! terei que comprar outro!!!
    Fazer o q!!!!
    Ps: Q modem chato!!! vou tirar ele da máquina e pisar nele até ficar em pedacinhos!!!!
    Realmente estes winmodens merecem varios pisões ...... pega um hardmodem que vc não vai se arrepender !!!!!!!!!
