  1. a brasiltelecom aceita pppoe o modem ta pra pptp
    configurei o ppoe e olha só o q deu
    [root@skynet sbin]# ./adsl-setup
    Welcome to the Roaring Penguin ADSL client setup. First, I will run
    some checks on your system to make sure the PPPoE client is installed
    properly...
    Looks good! Now, please enter some information:
    USER NAME
    >>> Enter your PPPoE user name (default di_vera@brturbo.com):
    INTERFACE
    >>> Enter the Ethernet interface connected to the ADSL modem
    For Solaris, this is likely to be something like /dev/hme0.
    For Linux, it will be ethn, where ´n´ is a number.
    (default eth0):
    Do you want the link to come up on demand, or stay up continuously?
    If you want it to come up on demand, enter the idle time in seconds
    after which the link should be dropped. If you want the link to
    stay up permanently, enter ´no´ (two letters, lower-case.)
    NOTE: Demand-activated links do not interact well with dynamic IP
    addresses. You may have some problems with demand-activated links.
    >>> Enter the demand value (default no): no
    DNS
    Please enter the IP address of your ISP´s primary DNS server.
    If your ISP claims that ´the server will provide DNS addresses´,
    enter ´server´ (all lower-case) here.
    If you just press enter, I will assume you know what you are
    doing and not modify your DNS setup.
    >>> Enter the DNS information here: 200.199.241.38
    Please enter the IP address of your ISP´s secondary DNS server.
    If you just press enter, I will assume there is only one DNS server.
    >>> Enter the secondary DNS server address here: 200.199.241.17
    PASSWORD
    >>> Please enter your PPPoE password:
    >>> Please re-enter your PPPoE password:
    FIREWALLING
    Please choose the firewall rules to use. Note that these rules are
    very basic. You are strongly encouraged to use a more sophisticated
    firewall setup; however, these will provide basic security. If you
    are running any servers on your machine, you must choose ´NONE´ and
    set up firewalling yourself. Otherwise, the firewall rules will deny
    access to all standard servers like Web, e-mail, ftp, etc. If you
    are using SSH, the rules will block outgoing SSH connections which
    allocate a privileged source port.
    The firewall choices are:
    0 - NONE: This script will not set any firewall rules. You are responsible
    for ensuring the security of your machine. You are STRONGLY
    recommended to use some kind of firewall rules.
    1 - STANDALONE: Appropriate for a basic stand-alone web-surfing workstation
    2 - MASQUERADE: Appropriate for a machine acting as an Internet gateway
    for a LAN
    >>> Choose a type of firewall (0-2): NONE
    Please enter a number from 0 to 2
    for a LAN
    >>> Choose a type of firewall (0-2): 0
    ** Summary of what you entered **
    Ethernet Interface: eth0
    User name: di_vera@brturbo.com
    Activate-on-demand: No
    Primary DNS: 200.199.241.38
    Secondary DNS: 200.199.241.17
    Firewalling: NONE
    >>> Accept these settings and adjust configuration files (y/n)? y
    Adjusting /etc/ppp/pppoe.conf
    Adjusting /etc/resolv.conf
    (But first backing it up to /etc/resolv.conf-bak)
    Adjusting /etc/ppp/pap-secrets and /etc/ppp/chap-secrets
    (But first backing it up to /etc/ppp/pap-secrets-bak)
    (But first backing it up to /etc/ppp/chap-secrets-bak)
    Congratulations, it should be all set up!
    Type ´adsl-start´ to bring up your ADSL link and ´adsl-stop´ to bring
    it down. Type ´adsl-status´ to see the link status.
    [root@skynet sbin]# ./adsl-start
    ................TIMED OUT
    ./adsl-start: line 192: 1214 Terminado $CONNECT "$@" >/dev/null 2>&1
    [root@skynet sbin]#
  2. #7
    estanisgeyer
    O alcatel Speed Toch Pro, pelo que sei, ele não tem suporte a PPoE. A Brasil Telecom Trabalha com PPoE para o plano Residencial e PPoA para o Plano empresarial. Tenho um modem destes instalado em meu cliente, porém para funcionar, tive que configurar em modo bridge o modem. Depois rodei o rp-ppoe.
    A configuração do seu rp-ppoe está correta, seu problema é com o modem. Tenta colocar em modo bridge.
    Ahhh... Se for um modem roteador (que com certeza não é...) ppoe, vc não usa o rp-ppoe, e sim configura tudo no modem....
    []´s
    Marcelo Estanislau.
  3. Kra uso speedy... com esse mesmo modem... e pppoe...
    funcionou perfeitamente com o adsl-start....
    ah só tem q tomar cuidado com uma coisinha.... a eth0 (ou interface q esteja o modem) tem q estar DOWN..... se naum dá problema nas rotas.....
    mas esse naum é o seu caso... pq nem conecta ele conecta..!!!!
  4. estanisgeyer
    tipo eu to usando pptp, porque minha adsl é do tipo home e as portas ficam bloqueadas e dai o pptp libera elas, no modo bridge eu tenho elas liberadas tb?
    como eu configuro o bridge no modem / e no linux tem q fazer algo?
    valew!!
  5. #10
    estanisgeyer
    Cara, colocando pptp, bridge, ou qualquer outro coisa que for, ele terá as portas bloqueadas. Isso é bloqueado lá nos equipamentos da BrasilTelecom. Vc não tem o manual do Modem? Verifique se ele possui etiqueta em baixo dele e veja o data de fabricação, release ou alguma informação para se fazer uma pesquisa com o fabricante, das especificações técnicas.
    Para colocar ele em modo bridge, há uma opção para ativá-lo no navegador (10.0.0.254, se não me engano, esse é o ip do modem). Se vc ativar o bridge, vc não terá mais acesso ao modem, vai precisar reiniciar ele.
    Vc não encontrou nada referente a PPoE nas configurações dele?
    Nosso amigo postou que o Speed Touch Pro tem suporte, pode ser um modelo mais novo que tenho do meu cliente, não sei....
    Vc precisa dar uma verificada nesse ponto...
    Posta aí que ajudo...
    Marcelo Estanislau.
  1. Quero usar o sudo para adsl-start más não funciona direito?
    Por cROMADO no fórum Servidores de Rede
    Respostas: 7
    Último Post: 25-04-2006, 20:43
  2. Radius + ADSL + Simultaneous-Login nao funciona
    Por nod3vic3 no fórum Servidores de Rede
    Último Post: 17-10-2005, 19:00
  3. ADSL - Internet não funciona
    Por micaias no fórum Servidores de Rede
    Último Post: 06-02-2005, 09:45
  4. Bloqueio SSH nao funciona! me ajudem!
    Por Felipe_ no fórum Servidores de Rede
    Respostas: 8
    Último Post: 29-08-2004, 10:39
  5. E a ADSL no Conectiva 8 não funciona ....
    Por pssgyn no fórum Servidores de Rede
    Respostas: 6
    Último Post: 03-12-2003, 13:24
