    Padrão Pq autenticacao do hotmail nao passa pelo squid? sem regra
    eu uso um red hat 9
    como eu vejo minha versão de squid?
    como faço para atualizá-la
    ela fica no /etc/squid
    onde ponho essas regras?
    olha meu conf:
    http_port 3128
    hierarchy_stoplist cgi-bin ?
    cache_mem 100 MB
    cache_swap_low 90
    cache_swap_high 95
    maximum_object_size 307200 KB
    cache_dir ufs /squid 20480 64 256
    #cache_access_log /var/log/squid/access.log
    #ftp_user [email protected]
    # ACLS
    acl all src 0.0.0.0/0.0.0.0
    acl vzone src 192.168.0.0/255.255.255.0
    acl pc01 src 192.168.0.201
    acl proibir_palavras url_regex -i "/etc/squid/proibidas"
    acl SSL_ports port 443 563
    acl Safe_ports port 80| | | | | | | | | # http
    acl Safe_ports port 21| | | | | | | | | # ftp
    acl Safe_ports port 443 563| | | | # https, snews
    acl Safe_ports port 70| | | | | | | | | # gopher
    acl Safe_ports port 210| | | | | | | | # wais
    acl Safe_ports port 1025-65535| # unregistered ports
    acl Safe_ports port 280| | | | | | | | # http-mgmt
    acl Safe_ports port 488| | | | | | | | # gss-http
    acl Safe_ports port 591| | | | | | | | # filemaker
    acl Safe_ports port 777| | | | | | | | # multiling http
    acl CONNECT method CONNECT
    http_access deny proibir_palavras
    http_access allow pc01
    icp_access allow all
    http_access deny manager
    http_access deny !Safe_ports
    http_access allow !Safe_ports
    http_access deny all
    visible_hostname on
    httpd_accel_host virtual
    httpd_accel_port 80
    httpd_accel_with_proxy on
  2. #62
    Fala Munch,
    Para ver a versão de seu Squid, digite: squid -v
    Seguindo a ordem das Tags do Squid, coloquei as regras assim:
    acl localhost src 127.0.0.1/32
    acl libera_ips src 192.xxx.xxx.xxx 192.xxx.xxx.xxx
    acl redes src 192.xxx.xxx.xxx/24 192.xxx.xxx.xxx/24
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl hotmail_domains dstdomain .hotmail.msn.com
    acl liberado url_regex -i "/usr/local/squid/etc/whitelist/liberado"
    acl hacking url_regex -i "/usr/local/squid/etc/blacklist/hacking"
    acl outros url_regex -i "/usr/local/squid/etc/blacklist/outros"
    acl porno url_regex -i "/usr/local/squid/etc/blacklist/porno"
    http_access allow localhost
    http_access allow liberado
    http_access allow libera_ips
    http_access allow redes !hacking !outros !porno
    header_access Accept-Encoding deny hotmail_domains
  3. #63
    Aproveitando o embalo do problema do hotmail com o Squid, os usuários da rede aqui acessam normalmente, porém eles tem reclamado de que não conseguem abrir os anexos.
    Sendo assim, observando a mensagem da url de download dos anexos, conta o IP 65.54.246.250. Resolvendo este apareceu o domínio .bay2.hotmail.com.
    Sendo assim, resolvi testar no Squid a implementação de nosso colega TheHawk, porém com estas regras:
    acl hotmail_domains2 dstdomain .bay2.hotmail.com
    header_access Accept-Encoding deny hotmail_domains2
    Façam os testes, pois aqui funcionou perfeitamente e os usuários agora fazem downloads de seus anexos.
    Valeu moçada.
  4. #64
    Citação Postado originalmente por Garcia
    Valeu moçada.
    Realmente garcia ta dando bronca para baixar os anexo, botei as acl que vc citou mais nda. o problema continua aqui. eu uso proxy transparente.
    Valeu.
  5. #65
    Estranho. Aqui depois que apliquei estas regras, os anexos estão passando.
    Vou pesquisar se há outra solução. Caso encontre, postarei para todos aqui no fórum.
    Abraços.
  6. #66
    Bem eu não tinha recebido nenhum anexo pra poder testar, mas depois vou dar uma olhada nisso ai e vou testar as regras que o garcia passou tambem, mas vale enfatizar o depois né, eu vou é curtir um feriadozinho de natal, até depois vcs.
  7. #67
    taiokada
    Padrão Squid + Hotmail
    e ai pessoal e so mudar algumas linhas no squid.conf. O problema na minha rede foi resolvido..
    Segue alteraçoes no squid.conf
    - para squid 2.5
    incluir na parte de header_access, no final:
    header_access Accept-Encoding deny all
    - para squid 2.4
    incluir na devida seção:
    anonymize_headers deny Accept-Encoding
    Abraso
  8. #68
    taiokada
    Boi dia.
    Esse Problema do hotmail e devido problemas com o proxy em paginas seguras, para fo problema ser resolvido basta alterar algumas linhas no squid.conf...
    - para squid 2.5
    - para squid 2.4
    depois de mudar as linhas de um reboot para reiniciar o squid e as regras dele e pronto..
    Falw ate mais....
  9. #69
    Gabriel Goes
    Padrão Nao use o modo transparente.
    Para o HOTMAIL funcionar perfeitamente usando o Squid e MS IE, basta configurar manualmente o IE para usar um servidor proxy Ferramentas => opcoes de internet => conexoes => utilizar um servidor proxy.
    Citação Postado originalmente por MAJOR
    Garcia você tem razão!!!!!!!!!
    meus clientes com explorer não estão mais conseguindo logar no hotmail.
    apenas firefox está autenticando no hotmail.
    isso está acontecendo des de sexta feira quando saiu a versão nova do messenger 6.2.
    ai pessoal, venho apelar junto ao meu amigo Garcia...
    alguem está conseguindo ver seus email no hotmail atravez do explorer, passando pelo proxy squid??????
    quem tiver a oportunidade teste.
    aguardo respostas....
    :wink:
  10. #70
    Já fiz este teste, porém meu Proxy/Squid é transparente. Neste caso, não uso estas configurações.
    Outro lance de funcionou, porém em alguns micros, foi desmarcar a opção "Usar HTTP 1.1" na guia "Avançadas" nas opções de Internet do IE6.
    Abraços e um Feliz Natal a todos.
  11. #71
    Padrão Re: Squid + Hotmail
    Citação Postado originalmente por Taiokada
    - para squid 2.5
    - para squid 2.4
    Abraso
    Pela sintaxe do comando ela acessa todas as paginas seguras diretamente sem proxy, resolveu aqui. retirei inclusive a acl que restringe apenas ao dominio do hotmail e coloquei todas. Pena que perde performance na rede pois todas paginas segura serão acessadas diretametente.
  12. #72
    João Paulo
    Padrão Hotmail não abre
    Meu msn roda, mas não consigo ler e-mails, mas tchan tchan tchan tachannnnnnn!!!, descobri um jeito de ler os mails....
    kkkkkkk adivinhem?!?!?!?
    É SÓ ABRIR O HOTMAIL NAVEGANDO PELO KAZAA, UAUAUAUA O IE QUE É UMA BOSTA MESMO... TENTEM LER O MAIL DO HOTMAIL PELO NAVEGADOR DO KAZAA!!! FLW!
  13. #73
    mmagomes
    Padrão Hotmail X squid transparente
    Caros amigos,
    Para solucionar o novo problema do squid com o hotmail adicionem a linha abaixo ao seu squid.conf
    mmagomes
    Padrão Tentem essa
    Adicionem a linha abaixo ao squid.conf, comigo funcionou.
    Boa sorte
    Marcelo
  15. #75
    Citação Postado originalmente por oyama
    Valeu moçada.
    Valeu.
    O problema dos anexos é pq são varios servidores, bay1, bay2, bay3 e etc, tem que se liberar todos, com a linha "header_access Accept-Encoding deny all " resolve mas a queda de desempenho é perceptivel, pois vão ser acessos diretos a todos os sites seguros, estou procurando outra forma de fazer isso, flw.
  16. #76
    Seguinte andei fazendo uns testes aqui e consegui liberar os anexos do hotmail sem ter que liberar geral as paginas seguras, eu tive que liberar dois ranges de ips, um do hotmail brasileiro e outros do hotmail americano, agora eu consigo baixar os anexos normalmente, ficou da seguinte forma:
    Código :
    acl hotmail_domains2 dst 64.0.0.0/255.0.0.0
    acl hotmail_domains3 dst 65.0.0.0/255.0.0.0
    header_access Accept-Encoding deny hotmail_domains3
    Com isso ai eu consegui baixar anexos de varios e-mails de usuarios diferentes, tanto de hotmail em português quanto em inglês, com essas regras libera-se todos os bayXX.hotmail.com e com isso o download funciona, estou testando aqui, alguem por favor teste e poste algo no forum ok, aguardo respostas, flw.
  17. #77
    keduardo
    Padrão regra
    Gente.
    estava com este problema na minha empresa e me passaram esta regra de acl.
    Implantei no squid e deu certo
    testem ai
  18. #78
    keduardo
    coloquem esta regra e ve se da certo
  19. #79
    railton
    # Problema do Squid com o Hotmail
    acl hotmail_domains url_regex hotmail
    eu to usando essas linhas , uma adaptacao da resolucao do TheHawk e resolveu aqui o problema
    []s
  20. #80
    Railton,
    Sua dica também funciona. Sua vantagem é vista devido à quantidade de linhas inseridas no arquivo de configuração do Squid, ou não faz diferença na hora da leitura do mesmo?
    Agora é fazer os testes com os domínios do hotmail e aguardar.
