    chroot
    Padrão DNS Interno + Debian + Postfix ! HELP
    Ae galera
    to tentando configura o bind9 aqui pra responder por um dominio INTERNO mra.br mas nao consigo pingar
    ping mail.mra.br
    nao responde
    cat /etc/bind/named.conf
    // prime the server with knowledge of the root servers
    zone "." {
    type hint;
    file "/etc/bind/db.root";
    // be authoritative for the localhost forward and reverse zones, and for
    // broadcast zones as per RFC 1912
    zone "localhost" {
    type master;
    file "/etc/bind/db.local";
    zone "127.in-addr.arpa" {
    type master;
    file "/etc/bind/db.127";
    zone "0.in-addr.arpa" {
    type master;
    file "/etc/bind/db.0";
    zone "255.in-addr.arpa" {
    type master;
    file "/etc/bind/db.255";
    zone "com" { type delegation-only; };
    zone "net" { type delegation-only; };
    // From the release notes:
    // Because many of our users are uncomfortable receiving undelegated answers
    // from root or top level domains, other than a few for whom that behaviour
    // has been trusted and expected for quite some length of time, we have now
    // introduced the "root-delegations-only" feature which applies delegation-only
    // logic to all top level domains, and to the root domain. An exception list
    // should be specified, including "MUSEUM" and "DE", and any other top level
    // domains from whom undelegated responses are expected and trusted.
    // root-delegation-only exclude { "DE"; "MUSEUM"; };
    #include "/etc/bind/named.conf.local";
    include "/etc/bind/rndc.key";
    include "/var/named/primary/mra.conf";
    cat /var/named/primary/mra.conf
    zone "mra.br" {
    type master;
    file "zone/db.mra";
    zone "1.0.168.192.in-addr.arpa" {
    type master;
    file "zone/rev.mra";
    cat /var/named/zone/db.mra
    $TTL 86400
    @ IN SOA mra.br. postmaster.mra.br. (
    2004090200 ; Serial
    28800 ; Refresh
    14400 ; Retry
    3600000 ; Expire
    86400 ) ; Minimum
    @ IN NS mra.br.
    @ IN NS ns.mra.br.
    mra.br. IN A 192.168.0.1
    ns.mra.br. IN A 192.168.0.1
    ftp IN A 192.168.0.1
    www IN CNAME mra.br.
    mail IN A 192.168.0.1
    @ IN MX 5 mail.mra.br.
    pop IN CNAME mail.mra.br.
    smtp IN CNAME mail.mra.br.
    dig servidor.mra.br
    ; <<>> DiG 9.2.3 <<>> servidor.mra.br
    ;; global options: printcmd
    ;; Got answer:
    ;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 54416
    ;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 0
    ;; QUESTION SECTION:
    ;servidor.mra.br. IN A
    ;; Query time: 2 msec
    ;; SERVER: 192.168.0.1#53(192.168.0.1)
    ;; WHEN: Sun Dec 23 16:17:21 2001
    ;; MSG SIZE rcvd: 33
    Não esta funcionando..alguem pode me ajudar ??
    violinista
    vc consegue pingar pop.mra.br ???
    chroot
    também não =(
    Você apenas restartou o named, ou o server inteiro?
    É comum acontecer de qdo vc restartar o named o processo não parar e iniciar novamente, é como se nem parasse...
    tente ps aux, verifique o numero do processo.
    mate ele com kill -9 numero_do_processo
    Ininie o named novamente...
    violinista
    Quando você reinicia o serviço, aparece alguma msg de erro no log ?????
    Vc criou o arquivo
    em
    root`#cd /var/named
    com o nome
    domino
    e dentro dele com as devidas configurações???
    Fallow
    tenta pingar nomedamaquina.seudominio.com
    Voce criou o alias mail?
    arachnius
    Apenas uma dica, use o djbdns muito simples, rápido e seguro de usar, acessa meu howto que tem passo a passo como configurar e pra vc que só precisa de dns interno faça só até a parte "6. Configurando o dnscache:" da 7 em diante não precisa.
    http://www.openbsd.adm.br/txt/djb.htm
    []'s
    arachnius
    Ops, pode fazer o howto inteiro, vc vai ter que cadastrar um dominio interno tb.
    dctalk
    o Bind é bem simple para o que ele quer , alías eu tenho um server interno rodando postfix no slack muito bem.
    vc precisa realmente disso ?:
    eu deixe somente :
    IN MX 5 meuhost.dominio.com.br
    meuhost IN A 10.3.1.10
    www IN CNAME meuhost.dominio.com.br
    mail IN CNAME meuhost.dominio.com.br
    cuidado com espaços em excesso.
    só isso na minha zona local ele funfa. quanto ao reverso eu não o tenho em vista.
    então :
    ping www
    ping mail
    não se esqueça de colocar no /etc/resolv.conf
    search dominio.com.br
    nameserver <seu IP_DNS>
