    vivaldorf
    Apr 28 23:48:54 microservice postfix/smtpd[5046]: disconnect from unknown[200.179.65.2]
    Apr 28 23:48:54 microservice postfix/cleanup[5036]: warning: mail_queue_enter: rename incoming/362419.5036 to incoming/6/8/6835F3909F: No space left on device
    Apr 28 23:48:57 microservice last message repeated 344 times
    Apr 28 23:48:57 microservice postfix/cleanup[5036]: fatal: mail_queue_enter: rename incoming/362419.5036 to incoming/6/8/6835F3909F: giving up
    Apr 28 23:48:58 microservice postfix/smtpd[4873]: warning: premature end-of-input from public/cleanup socket while reading input attribute name
    Apr 28 23:48:58 microservice postfix/smtpd[4873]: fatal: unable to connect to the public cleanup service
    Apr 28 23:48:58 microservice postfix/master[2662]: warning: process /usr/lib/postfix/cleanup pid 5036 exit status 1
    Apr 28 23:48:58 microservice postfix/master[2662]: warning: /usr/lib/postfix/cleanup: bad command startup -- throttling
    Apr 28 23:48:59 microservice postfix/master[2662]: warning: process /usr/lib/postfix/smtpd pid 4873 exit status 1
    Apr 28 23:49:46 microservice postfix/smtpd[5046]: connect from unknown[200.179.65.2]
    Apr 28 23:49:46 microservice postfix/smtpd[5046]: disconnect from unknown[200.179.65.2]
    Apr 28 23:50:33 microservice postfix/smtpd[5046]: connect from unknown[200.179.65.2]
    Apr 28 23:50:34 microservice postfix/smtpd[5046]: disconnect from unknown[200.179.65.2]
    Apr 28 23:52:13 microservice postfix/smtpd[5046]: connect from unknown[200.179.65.2]
    Apr 28 23:52:13 microservice postfix/smtpd[5046]: disconnect from unknown[200.179.65.2]
    Apr 28 23:52:31 microservice postfix/postfix-script: stopping the Postfix mail system
    Apr 28 23:52:31 microservice postfix/master[2662]: terminating on signal 15
    Apr 28 23:52:38 microservice postfix/postfix-script: starting the Postfix mail system
    Apr 28 23:52:38 microservice postfix/master[5251]: daemon started
    Apr 28 23:52:57 microservice postfix/smtpd[5263]: connect from bay8-f31.bay8.hotmail.com[64.4.27.31]
    Apr 28 23:52:59 microservice postfix/cleanup[5264]: warning: mail_queue_enter: rename incoming/917281.5264 to incoming/5/F/5F24A390A0: No space left on device
    Apr 28 23:53:05 microservice last message repeated 1001 times
    Apr 28 23:53:05 microservice postfix/cleanup[5264]: fatal: mail_queue_enter: rename incoming/917281.5264 to incoming/5/F/5F24A390A0: giving up
    Apr 28 23:53:06 microservice postfix/smtpd[5263]: warning: premature end-of-input from public/cleanup socket while reading input attribute name
    Apr 28 23:53:06 microservice postfix/smtpd[5263]: fatal: unable to connect to the public cleanup service
    Apr 28 23:53:06 microservice postfix/master[5251]: warning: process /usr/lib/postfix/cleanup pid 5264 exit status 1
    Apr 28 23:53:06 microservice postfix/master[5251]: warning: /usr/lib/postfix/cleanup: bad command startup -- throttling
    Apr 28 23:53:07 microservice postfix/master[5251]: warning: process /usr/lib/postfix/smtpd pid 5263 exit status 1
    Apr 28 23:53:07 microservice postfix/master[5251]: warning: /usr/lib/postfix/smtpd: bad command startup -- throttling
  2. cara vc ta com seu disco lotado!!!!!!!!!!!
    da um df -kah e posta aki tb
    talvez mudando os diretorios do postfix resolva, pq pelo log ele inicia mas depois ele morre pq num tem espaco pra gravar as informacoes necessarias
  3. #13
    vivaldorf
    eh amigao parece esta sem espaço mesmo , da uma olhado
    Filesystem Size Used Avail Use% Mounted on
    /dev/hda1 1.9G 1.8G 0 100% /
    proc 0 0 0 - /proc
    devpts 0 0 0 - /dev/pts
    /dev/hdc1 1.4G 473M 0 33% /mnt/hdb
    Vivaldo R. Felipe
  4. eh vc realmente ta com o disco cheio............
    o jeito eh vc criar as pastas pro postfix fix na sua outra particao no caso hdc
    q esta montada em /mnt/hdb
    e alterar as configuracoes pra usarem as pastas desse disco
  5. #15
    vivaldorf
    proc 0 0 0 - /proc
    /dev/hdc1 1.4G 473M 900M 33% /mnt/hdb
    Vivaldo R. Felipe
  1. Shorewall não libera MSN
    Por PcGuy no fórum Servidores de Rede
    Último Post: 03-10-2006, 07:41
  2. Somente uma conta não autentica no pop.
    Por juniovitorino no fórum Servidores de Rede
    Respostas: 5
    Último Post: 24-08-2006, 11:20
  3. Proxy Transparente : Nao consigo acessar pop, smtp e nem dar ping
    Por master_foca no fórum Servidores de Rede
    Respostas: 7
    Último Post: 09-05-2006, 17:32
  4. Squid nao libera FTP
    Por slackrio no fórum Servidores de Rede
    Respostas: 12
    Último Post: 21-04-2006, 17:27
  5. Proxy Transparente nao libera nada
    Por mastellaro no fórum Servidores de Rede
    Último Post: 10-02-2006, 18:20
