  1. bem pessoal para ver se esta certo vou colocar meu scripts aqui para ver o que acham ok
    #!/bin/bash
    #link1
    ip route flush table link1
    ip route add default via 192.168.15.2 table link1
    ip route add 127.0.0.0/8 dev lo table link1
    ip route add 192.168.15.0/24 dev eth0 table link1
    ip route add 192.168.18.0/24 dev eth1 table link1
    ip route add 192.168.20.0/24 dev eth1 table link1
    ip route add 192.168.21.0/24 dev eth1 table link1
    ip route add 192.168.55.0/24 dev eth2 table link1
    ip route add 192.168.22.0/24 dev eth1 table link1
    #link2
    ip route flush table link2
    ip route add default via 192.168.15.10 table link2
    ip route add 127.0.0.0/8 dev lo table link2
    ip route add 192.168.15.0/24 dev eth0 table link2
    ip route add 192.168.18.0/24 dev eth1 table link2
    ip route add 192.168.20.0/24 dev eth1 table link2
    ip route add 192.168.21.0/24 dev eth1 table link2
    ip route add 192.168.55.0/24 dev eth2 table link2
    ip route add 192.168.22.0/24 dev eth1 table link2
    #link3
    ip route flush table link3
    ip route add default via 192.168.15.6 table link3
    ip route add 127.0.0.0/8 dev lo table link3
    ip route add 192.168.15.0/24 dev eth0 table link3
    ip route add 192.168.18.0/24 dev eth1 table link3
    ip route add 192.168.20.0/24 dev eth1 table link3
    ip route add 192.168.21.0/24 dev eth1 table link3
    ip route add 192.168.55.0/24 dev eth2 table link3
    ip route add 192.168.22.0/24 dev eth1 table link3
    #distribuicao do trafego
    ip rule del from 192.168.20.0/25
    ip rule del from 192.168.20.128/25
    ip rule del from 192.168.21.0/26
    ip rule del from 192.168.21.64/26
    ip rule del from 192.168.21.128/25
    ip rule del from 192.168.22.0/26
    ip rule del from 192.168.22.64/26
    ip rule del from 192.168.128/25
    ip rule add from 192.168.20.0/25 lookup link1
    ip rule add from 192.168.21.64/26 lookup link1
    ip rule add from 192.168.20.128/25 lookup link2
    ip rule add from 192.168.21.0/26 lookup link2
    ip rule add from 192.168.21.128/25 lookup link3
    ip rule add from 192.168.55.2 lookup link3
    ip rule add from 192.168.22.0/25 lookup link1
    ip rule add from 192.168.22.64/26 lookup link2
    ip rule add from 192.168.22.128/26 lookup link3
    ip route del default
    ip route flush cache
    Os link 15.2, 15.10 e 15.6 sao os modens adsl em modo router
  2.    Publicidade
  3. essa foi a configuração que herdei do ex-administrador daqui, deem uma olhada e vejam o que tem de errado por favor
  4. Ola.
    Vou colocar aqui os scripts que tenho funcionando aqui 2 links utilizando iproute2. Basta alterar conforme suas necessidades
    Primeiro crie as tabelas em:
    joe /etc/iproute2/rt_tables
    200 link
    201 adsl
    Depois so executar os scripts:
    ---- adsl.sh ---- no caso usuarios que sairão pela ADSL...
    echo "--- Setando trafego pela ADSL ---"
    iptables -t nat -F
    iptables -t nat -P PREROUTING ACCEPT
    iptables -t nat -P POSTROUTING ACCEPT
    iptables -t nat -P OUTPUT ACCEPT
    insmod ip_conntrack_ftp
    insmod ip_nat_ftp
    ip route add default table adsl via 10.42.42.1 dev eth2
    #### EVANDRO #####
    iptables -t nat -A POSTROUTING -s 192.168.1.43 -j MASQUERADE -o eth2
    ip rule add from 192.168.1.43 table adsl
    #### TECNICA #####
    iptables -t nat -A POSTROUTING -s 192.168.1.44 -j MASQUERADE -o eth2
    ip rule add from 192.168.1.44 table adsl
    ... entre outros ....
    ---- link.sh ---- no caso usuarios que sairão pelo LINK...
    echo "--- Setando trafego pelo LINK ---"
    ip route add default table link via 200.XXX.XXX.XXX dev eth0
    #### PAPITO #####
    iptables -t nat -A POSTROUTING -s 192.168.1.40 -j MASQUERADE -o eth0
    ip rule add from 192.168.1.40 table link
    #### MICHELE #####
    iptables -t nat -A POSTROUTING -s 192.168.1.41 -j MASQUERADE -o eth0
    ip rule add from 192.168.1.41 table link
    ..entre outros usuarios....
    Batata.. ta funcionando legal... com 3 ou mais links e na mesma lógica...
    Espero ter ajudado
    t+
  5. sim quanto a isso tudo bem, ajuda, mas o meu problema e como setar todo um range de usuario tipo dividir um subnet em 3 ranges diferentes
    1 de 192.168.22.0 a 192.168.22.64 - link1
    2 de 192.168.22.65 a 192.168.22.128 - link2
    3 de 192.168.22.129 a 192.168.22.250 - link3
  6. Ola.
    Meu, ou vc "subneta" a rede em redes menores ou entaum faz um, por um..
    t+
  7.    Publicidade
