    Carlos_Radlink
    Padrão Cartao Avaya no linux
    orinoco_cs 4968 0 (unused)
    orinoco 33312 0 [orinoco_cs]
    hermes 5280 0 [orinoco_cs orinoco]
    ds 6976 1 [orinoco_cs]
    i82365 27408 1
    pcmcia_core 51104 0 [orinoco_cs ds i82365]
    iptable_filter 1728 0 (autoclean) (unused)
    cls_u32 4964 0 (unused)
    sch_prio 2720 0 (unused)
    sch_sfq 3552 0 (unused)
    sch_tbf 2592 0 (unused)
    sch_cbq 12544 0 (unused)
    ipt_ULOG 3968 0 (unused)
    ipt_TOS 1056 0 (unused)
    ipt_tos 448 0 (unused)
    ipt_TCPMSS 2368 0 (unused)
    ipt_tcpmss 992 0 (unused)
    ipt_state 576 0 (unused)
    ipt_unclean 6752 0 (unused)
    ipt_ttl 608 0 (unused)
    ipt_REJECT 2816 0 (unused)
    ipt_REDIRECT 800 0 (unused)
    ipt_owner 1632 0 (unused)
    ipt_multiport 608 0 (unused)
    ipt_MIRROR 1184 0 (unused)
    ipt_MASQUERADE 1920 0 (unused)
    ipt_MARK 800 0 (unused)
    ipt_mark 448 0 (unused)
    ipt_mac 640 0 (unused)
    ipt_LOG 3264 0 (unused)
    ipt_limit 1056 0 (unused)
    ipt_length 480 0 (unused)
    ipt_conntrack 1088 0 (unused)
    iptable_mangle 2176 0 (unused)
    ip_queue 5808 0 (unused)
    ip_nat_snmp_basic 7872 0 (unused)
    ip_nat_irc 2784 0 (unused)
    ip_nat_ftp 3712 0 (unused)
    iptable_nat 21492 4 [ipt_REDIRECT ipt_MASQUERADE ip_nat_snmp_basic ip_nat_irc ip_nat_ftp]
    ip_conntrack_irc 3264 1 [ip_nat_irc]
    ip_conntrack_ftp 4224 1 [ip_nat_ftp]
    arptable_filter 1536 0 (unused)
    arp_tables 10528 1 [arptable_filter]
    8139too 17120 1
  2. #8
    Jan 2004
    Capital do Triângulo
    pelo que vi ae vc tah usando o i82365 isso normalmente eh pra ISA e sua adaptadora eh PCI certo? a unica coisa que tah diferente do meu eh isso.... muda o rc.pcmcia e dah uma checada no /etc/pcmcia/config.opts
  3. #9
    Carlos_Radlink
    Isso minha adaptadora é PCI mas o cartao orinoco funciona se eu trocar. vou te colcar o conteudo do config.opts
    # Local PCMCIA Configuration File
    # System resources available for PCMCIA devices
    include port 0x100-0x4ff, port 0x800-0x8ff, port 0xc00-0xcff
    include memory 0xc0000-0xfffff
    include memory 0xa0000000-0xa0ffffff, memory 0x60000000-0x60ffffff
    # High port numbers do not always work...
    # include port 0x1000-0x17ff
    # Extra port range for IBM Token Ring
    include port 0xa00-0xaff
    # Resources we should not use, even if they appear to be available
    # First built-in serial port
    exclude irq 4
    # Second built-in serial port
    #exclude irq 3
    # First built-in parallel port
    exclude irq 7
    module "wvlan_cs" opts "port_type=3 channel=10"
    module "wavelan2_cs" opts "port_type=3 channel=10"
  4. #10
    Carlos_Radlink
    Padrão Minha inicializacao
    8139too Fast Ethernet driver 0.9.26
    eth0: RealTek RTL8139 Fast Ethernet at 0xec00, 00:08:54:1d:57:dc, IRQ 10
    eth0: Identified 8139 chip type 'RTL-8139C'
    eth0: Setting 100mbps full-duplex based on auto-negotiated partner ability 45e1.
    Linux PCMCIA Card Services 3.2.4
    kernel build: 2.4.20 unknown
    options: [pci] [cardbus] [apm] [pnp]
    PnP: PNP BIOS installation structure at 0xc00f8470
    PnP: PNP BIOS version 1.0, entry at f0000:7d8e, dseg at f0000
    Intel ISA/PCI/CardBus PCIC probe:
    PCI: Enabling device 00:06.0 (0000 -> 0002)
    PCI: No IRQ known for interrupt pin A of device 00:06.0. Please try using pci=biosirq.
    TI 1410 rev 01 PCI-to-CardBus at slot 00:06, mem 0x10000000
    host opts [0]: [pci only] [no pci irq] [lat 168/176] [bus 1/4]
    *NO* card interrupts, polling interval = 1000 ms
    cs: memory probe 0xa0000000-0xa0ffffff: clean.
    hermes.c: 4 Dec 2002 David Gibson <[email protected]>
    orinoco.c 0.13b (David Gibson <[email protected]> and others)
    orinoco_cs.c 0.13b (David Gibson <[email protected]> and others)
    cs: IO port probe 0x0100-0x04ff: excluding 0x220-0x22f 0x388-0x38f 0x3c0-0x3df 0x408-0x40f 0x480-0x48f
    cs: IO port probe 0x0230-0x0387: clean.
    cs: IO port probe 0x0390-0x03bf: clean.
    cs: IO port probe 0x03e0-0x0407: clean.
    cs: IO port probe 0x0410-0x047f: clean.
    cs: IO port probe 0x0490-0x04ff: clean.
    cs: IO port probe 0x0800-0x08ff: clean.
    cs: IO port probe 0x0a00-0x0aff: clean.
    cs: IO port probe 0x0c00-0x0cff: clean.
    orinoco_cs: RequestIRQ: Resource in use
  5. #11
    imagina um sujeito que nao entendia nada de linux e tinha que instalar uma placa Avaya hehehe o sujeito sou eu levei 2 semanas heheh o O era o Kurumin que e o knopix a base de debian, vai la no site do avaya e baixa o driver deles e depois baixa o driver que o avaya pede de pcmcia, descompacte o pcmcia num diretorio qualquer descompacte o driver do avaya no mesmo diretorio e instala ele, depois vai la no etc e configura seus parametros e ja era
  6. #12
    Jan 2004
    a encrenca tah no IRQ... agora vai saber como eh que muda isso... eh tudo em hexadecimal.... experimenta comentar essas linhas ae do config.opts e sae testando... uma outra opcao seria vc desabilitar na BIOS td q pega IRQ e nao tah usando... tipo usb, som, IDE secundaria, paralela, serial...
