MAC
  1. não precisa não, cara não consigo imaginar o que pode ser o problema ... sei que eu uso tres linhas de comando e tudo funciona perfeitamente se erro algum .
  2. #52
    serhumano
    quais linhas... tu num sabe oq pode estar acontecendo pra num subir?
  3. #53
    gmlinux
    ifconfig eth0 down
    derruba o módulo: rmmod sis900
    sobe o módulo: modprobe sis900
    verifique o log do kernel: dmesg
    observe se ha erros nas últimas linhas, relacionadas a placa
  4. #54
    serhumano
    tão aí as linhas de comando q vc pediu pra dar.. e as respectivas mensagens...
    root@cable:~# ifconfig eth0 down
    root@cable:~# rmmod sis900
    root@cable:~# modprobe sis900
    root@cable:~# dmesg
    Linux version 2.4.26 (root@tree) (gcc version 3.3.4) #6 Mon Jun 14 19:07:27 PDT 2004
    BIOS-provided physical RAM map:
    BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
    BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
    BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
    BIOS-e820: 0000000000100000 - 000000001fffc000 (usable)
    BIOS-e820: 000000001fffc000 - 000000001ffff000 (ACPI data)
    BIOS-e820: 000000001ffff000 - 0000000020000000 (ACPI NVS)
    BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
    BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
    BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
    511MB LOWMEM available.
    On node 0 totalpages: 131068
    zone(0): 4096 pages.
    zone(1): 126972 pages.
    zone(2): 0 pages.
    Kernel command line: BOOT_IMAGE=Linux ro root=303
    Initializing CPU#0
    Detected 2800.142 MHz processor.
    Console: colour VGA+ 80x25
    Calibrating delay loop... 5583.66 BogoMIPS
    Memory: 515368k/524272k available (1844k kernel code, 8516k reserved, 618k data, 120k init, 0k highmem)
    Dentry cache hash table entries: 65536 (order: 7, 524288 bytes)
    Inode cache hash table entries: 32768 (order: 6, 262144 bytes)
    Mount cache hash table entries: 512 (order: 0, 4096 bytes)
    Buffer cache hash table entries: 32768 (order: 5, 131072 bytes)
    Page-cache hash table entries: 131072 (order: 7, 524288 bytes)
    CPU: Trace cache: 12K uops, L1 D cache: 8K
    CPU: L2 cache: 512K
    CPU: After generic, caps: bfebfbff 00000000 00000000 00000000
    CPU: Common caps: bfebfbff 00000000 00000000 00000000
    CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz stepping 09
    Enabling fast FPU save and restore... done.
    Enabling unmasked SIMD FPU exception support... done.
    Checking 'hlt' instruction... OK.
    POSIX conformance testing by UNIFIX
    mtrr: v1.40 (20010327) Richard Gooch (rgooch@atnf.csiro.au)
    mtrr: detected mtrr type: Intel
    PCI: PCI BIOS revision 2.10 entry at 0xf10f0, last bus=1
    PCI: Using configuration type 1
    PCI: Probing PCI hardware
    PCI: Probing PCI hardware (bus 00)
    PCI: Using IRQ router default [1039/0963] at 00:02.0
    Linux NET4.0 for Linux 2.4
    Based upon Swansea University Computer Society NET3.039
    Initializing RT netlink socket
    Starting kswapd
    VFS: Disk quotas vdquot_6.5.1
    Journalled Block Device driver loaded
    pty: 512 Unix98 ptys configured
    Serial driver version 5.05c (2001-07-08) with HUB-6 MANY_PORTS MULTIPORT SHARE_IRQ SERIAL_PCI enabled
    ttyS00 at 0x03f8 (irq = 4) is a 16550A
    Real Time Clock Driver v1.10f
    Floppy drive(s): fd0 is 1.44M
    FDC 0 is a post-1991 82077
    RAMDISK driver initialized: 16 RAM disks of 7777K size 1024 blocksize
    loop: loaded (max 8 devices)
    Uniform Multi-Platform E-IDE driver Revision: 7.00beta4-2.4
    ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
    SIS5513: IDE controller at PCI slot 00:02.5
    SIS5513: chipset revision 0
    SIS5513: not 100% native mode: will probe irqs later
    SIS5513: SiS 962/963 MuTIOL IDE UDMA133 controller
    ide0: BM-DMA at 0xb400-0xb407, BIOS settings: hdaMA, hdbio
    ide1: BM-DMA at 0xb408-0xb40f, BIOS settings: hdcMA, hddio
    hda: Maxtor 2F040L0, ATA DISK drive
    blk: queue c03b3360, I/O limit 4095Mb (mask 0xffffffff)
    hdc: HL-DT-ST RW/DVD GCC-4521B, ATAPI CD/DVD-ROM drive
    ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
    ide1 at 0x170-0x177,0x376 on irq 15
    hda: attached ide-disk driver.
    hda: host protected area => 1
    hda: 80293248 sectors (41110 MB) w/2048KiB Cache, CHS=4998/255/63, UDMA(133)
    hdc: attached ide-cdrom driver.
    hdc: ATAPI 52X DVD-ROM CD-R/RW drive, 2048kB Cache, UDMA(33)
    Uniform CD-ROM driver Revision: 3.12
    Partition check:
    hda: hda1 hda2 hda3
    SCSI subsystem driver Revision: 1.00
    kmod: failed to exec /sbin/modprobe -s -k scsi_hostadapter, errno = 2
    md: linear personality registered as nr 1
    md: raid0 personality registered as nr 2
    md: raid1 personality registered as nr 3
    md: raid5 personality registered as nr 4
    raid5: measuring checksumming speed
    8regs : 3211.200 MB/sec
    32regs : 2106.400 MB/sec
    pIII_sse : 3609.600 MB/sec
    pII_mmx : 3300.800 MB/sec
    p5_mmx : 3215.600 MB/sec
    raid5: using function: pIII_sse (3609.600 MB/sec)
    md: md driver 0.90.0 MAX_MD_DEVS=256, MD_SB_DISKS=27
    md: Autodetecting RAID arrays.
    md: autorun ...
    md: ... autorun DONE.
    LVM version 1.0.8(17/11/2003)
    Initializing Cryptographic API
    NET4: Linux TCP/IP 1.0 for NET4.0
    IP Protocols: ICMP, UDP, TCP, IGMP
    IP: routing cache hash table of 4096 buckets, 32Kbytes
    TCP: Hash tables configured (established 32768 bind 65536)
    Linux IP multicast router 0.06 plus PIM-SM
    NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
    FAT: bogus logical sector size 0
    UMSDOS: msdos_read_super failed, mount aborted.
    reiserfs: found format "3.6" with standard journal
    reiserfs: checking transaction log (device ide0(3,3)) ...
    for (ide0(3,3))
    ide0(3,3):Using r5 hash to sort names
    VFS: Mounted root (reiserfs filesystem) readonly.
    Freeing unused kernel memory: 120k freed
    Linux agpgart interface v0.99 (c) Jeff Hartmann
    agpgart: Maximum main memory to use for agp memory: 439M
    agpgart: Detected SiS 648 chipset
    agpgart: AGP aperture is 64M @ 0xe8000000
    scsi0 : SCSI host adapter emulation for IDE ATAPI devices
    Linux Kernel Card Services 3.1.22
    options: [pci] [cardbus] [pm]
    isapnp: Scanning for PnP cards...
    isapnp: No Plug & Play device found
    Intel ISA PCIC probe: not found.
    Databook TCIC-2 PCMCIA probe: not found.
    ds: no socket drivers loaded!
    NVRM: loading NVIDIA Linux x86 NVIDIA Kernel Module 1.0-6111 Tue Jul 27 07:55:38 PDT 2004
    sis900.c: v1.08.06 9/24/2002
    PCI: Enabling device 00:04.0 (0004 -> 0007)
    PCI: No IRQ known for interrupt pin A of device 00:04.0. Please try using pci=biosirq.
    eth0: Realtek RTL8201 PHY transceiver found at address 1.
    eth0: Using transceiver found at address 1 as default
    eth0: SiS 900 PCI Fast Ethernet at 0x9800, IRQ 0, 00:0e:a6:00:bb:c4.
    usb.c: registered new driver usbdevfs
    usb.c: registered new driver hub
    PCI: Enabling device 00:03.2 (0004 -> 0006)
    PCI: No IRQ known for interrupt pin D of device 00:03.2. Please try using pci=biosirq.
    hcd.c: Found HC with no IRQ. Check BIOS/PCI 00:03.2 setup!
    usb.c: deregistering driver usbdevfs
    usb.c: deregistering driver hub
    usb-ohci.c: USB OHCI at membase 0xe0d6e000, IRQ 5
    usb-ohci.c: usb-00:03.0, Silicon Integrated Systems [SiS] USB 1.0 Controller
    usb.c: new USB bus registered, assigned bus number 1
    hub.c: USB hub found
    hub.c: 3 ports detected
    usb-ohci.c: USB OHCI at membase 0xe0d70000, IRQ 9
    usb-ohci.c: usb-00:03.1, Silicon Integrated Systems [SiS] USB 1.0 Controller (#2)
    usb.c: new USB bus registered, assigned bus number 2
    PCI: Enabling device 00:02.7 (0004 -> 0005)
    PCI: No IRQ known for interrupt pin C of device 00:02.7. Please try using pci=biosirq.
    ALSA intel8x0.c:2518: unable to grab IRQ 0
    hub.c: new USB device 00:03.0-2, assigned address 2
    usb.c: USB device 2 (vend/prod 0x4fc/0x5) is not claimed by any active driver.
    uhci.c: USB Universal Host Controller Interface driver v1.1
    usb-uhci.c: $Revision: 1.275 $ time 17:55:05 Jun 13 2004
    usb-uhci.c: High bandwidth mode enabled
    usb-uhci.c: v1.275:USB Universal Host Controller Interface driver
    usb.c: registered new driver usbmouse
    input0: USB Wheel Mouse on usb1:2.0
    usbmouse.c: v1.6:USB HID Boot Protocol mouse driver
    usb.c: registered new driver hiddev
    hid-core.c: v1.8.1 Andreas Gal, Vojtech Pavlik <vojtech@suse.cz>
    hid-core.c: USB HID support drivers
    mice: PS/2 mouse device common for all mice
    isso é tudo
  5. #55
    gmlinux
    Não tenho certeza se isto aqui abaixo seja própriamente um erro, mais eu tentaria resolver:
    Reboot a máquina e configure no setup que seu sistema operacional NÃO é plug and play. Se isto não resolver, informe a opção pci=biosirq para o boot do kernel.
  1. ip pelo mac da placa
    Por pensador-ce no fórum Servidores de Rede
    Respostas: 12
    Último Post: 28-04-2003, 09:49
  2. Mac OS 9 Logar no Linux
    Último Post: 09-04-2003, 10:26
  3. Interface Mac
    Último Post: 02-04-2003, 10:12
  4. MAC Power PC
    Por marcfee no fórum Servidores de Rede
    Último Post: 26-03-2003, 11:19
  5. Bloquear internet através do Squid/MAC Address
    Último Post: 06-02-2003, 13:46
