    Padrão erro ao tentar adicionar W2K em Dominio SAMBA com LDAP
    Respondendo a todos:
    Versao do SAMBA: 3.0.5
    Versao do LDAP: 2.1.22
    meu SMB.conf - GLOBAL Sector
    [global]
    workgroup = MYGROUP
    server string = Samba PDC-Ldap Server
    passdb backend = ldapsam:ldap://127.0.0.1/
    ldap admin dn = cn=Manager,dc=mydomain,dc=org
    ldap suffix = dc=mydomain,dc=org
    ldap group suffix = ou=Groups
    ldap user suffix = ou=Users
    ldap machine suffix = ou=Computers
    add machine script = /usr/local/sbin/smbldap-useradd -w "%u"
    add user script = /usr/local/sbin/smbldap-useradd -m "%u"
    ldap delete dn = Yes
    ldap passwd sync = yes
    ldap ssl = off
    username map = /etc/samba/smbusers
    delete user script = /usr/local/sbin/smbldap-userdel "%u"
    add group script = /usr/local/sbin/smbldap-groupadd -p "%g"
    delete group script = /usr/local/sbin/smbldap-groupdel "%g"
    add user to group script = /usr/local/sbin/smbldap-groupmod -m "%u" "%g"
    delete user from group script = /usr/local/sbin/smbldap-groupmod -x "%u" "%g"
    set primary group script = /usr/local/sbin/smbldap-usermod -g "%g" "%u"
    printcap name = /etc/printcap
    load printers = yes
    log file = /var/log/samba/%m.log
    max log size = 50
    security = user
    encrypt passwords = yes
    passwd program =/usr/local/sbin/smbldap-passwd %u
    passwd chat = *new*password* %n\n *new*password:* %n\ *successfully*
    socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
    os level = 35
    domain master = yes
    preferred master = yes
    domain logons = yes
    local master = yes
    logon script = %U.bat
    logon path = \\%L\Profiles\%U
    wins support = yes
    dns proxy = no
    search no ldap para o uid de um usuario:
    # extended LDIF
    # LDAPv3
    # base <dc=mydomain,dc=org> with scope sub
    # filter: uid=danilo
    # requesting: ALL
    # danilo, Users, mydomain.org
    dn: uid=danilo,ou=Users,dc=mydomain,dc=org
    objectClass: top
    objectClass: inetOrgPerson
    objectClass: posixAccount
    objectClass: shadowAccount
    objectClass: sambaSAMAccount
    cn: Danilo Montagna
    sn: danilo
    uid: danilo
    uidNumber: 1001
    gidNumber: 513
    homeDirectory: /home/danilo
    loginShell: /bin/bash
    gecos: Danilo Montagna
    description: Danilo Montagna
    sambaLogonTime: 0
    sambaLogoffTime: 2147483647
    sambaKickoffTime: 2147483647
    displayName: Danilo Montagna
    sambaSID: S-1-5-21-476519084-1075918099-3570581004-3002
    sambaPrimaryGroupSID: S-1-5-21-476519084-1075918099-3570581004-513
    sambaProfilePath: \\PDCSRV\profiles\danilo
    sambaHomePath: \\PDCSRV\home\danilo
    sambaHomeDrive: H:
    sambaPwdCanChange: 1093226803
    sambaAcctFlags: [U]
    sambaPwdLastSet: 1093486704
    sambaPwdMustChange: 1097374704
    # search result
    search: 2
    result: 0 Success
    # numResponses: 2
    # numEntries: 1
    alguma ideia.. ainda acho que o problema é so a autenticacao.. pois se eu vou no authconfig do redhat e seto para "USE LDAP Authentication" ninguem mais consegue logar na maquina.. inclusive o root.
    só para efeito de conhecimento..
    acabei de atualizar para o samba 3.0.6 e continua tudo na mesma..
    alguem aqui que tenha isso funcionando (SAMBA + LDAP) .. tem como me passar o how to que usou ?
    sim.. o backend é exatamente como essa linha ae que vc postou..
    quando eu executo o comando que vc passou.. aparece isso aqui..
    [[email protected] openldap]# smbclient -L pdcsrv -U danilo
    Password:
    session setup failed: NT_STATUS_LOGON_FAILURE
    e no /var/log/messahes.. isso aqui..
    [2004/08/22 22:54:17, 0] auth/auth_sam.c:check_sam_security(260)
    Aug 22 22:54:17 pdcsrv smbd[7828]: check_sam_security: make_server_info_sam() failed with 'NT_STATUS_NO_SUCH_USER'
    sim.. o backend éfdhdffdhdhf exatamente como essa linha ae que vc postou..
    Password:
