    Felipe_
    Padrão Problemas com regras de Firewall
    eae pessoal....
    é o seguinte...
    estou com as seguintes regras do firewall de meu pc particular..
    iptables -F
    iptables -A INPUT -i eth0 -p tcp -s 0.0.0.0/0 -limit 3/min
    iptables -A INPUT -i eth0 -p tcp -s 0.0.0.0/0 -limit-burst 3 -j LOG
    iptables -A INPUT -i eth0 -p tcp -s 0.0.0.0/0 -syn -j LOG
    iptables -A INPUT -s 0/0 -d 0/0 -p icmp -j DROP
    iptables -A INPUT -s 0/0 -d 0/0 -p icmp -j LOG
    iptables -A INPUT -s 0/0 -d 0/0 -p tcp -dport 20 -j DROP
    iptables -A INPUT -s 0/0 -d 0/0 -p tcp -dport 21 -j DROP
    iptables -A INPUT -s 0/0 -d 0/0 -p tcp -dport 25 -j DROP
    iptables -A INPUT -p tcp --dport 22 -j DROP
    iptables -A INPUT -p tcp --dport 22 -j LOG
    iptables -A INPUT -p tcp --dport 1024 -j ACCEPT
    iptables -A INPUT -p tcp --dport 1024 -j LOG
    mas quando dou o comando ./rc.local para carregar esse arquivo que contem as regras aparece isso :
    [[email protected] rc.d]# ./rc.local
    iptables v1.2.9: multiple -i flags not allowed
    Try `iptables -h' or 'iptables --help' for more information.
    iptables v1.2.9: multiple -s flags not allowed
    iptables v1.2.9: multiple -d flags not allowed
    pq aparece "flags not allowed" ?????
    e quando dou o comando iptables -L -v para ver as regras vejo que estao faltando 2 regras .....
    [[email protected] rc.d]# iptables -L -v
    Chain INPUT (policy ACCEPT 16308 packets, 5242K bytes)
    pkts bytes target prot opt in out source destination
    0 0 DROP icmp -- any any anywhere anywhere
    0 0 LOG icmp -- any any anywhere anywhere LOG level warning
    0 0 DROP tcp -- any any anywhere anywhere tcp dpt:ssh
    0 0 LOG tcp -- any any anywhere anywhere tcp dpt:ssh LOG level warning
    0 0 ACCEPT tcp -- any any anywhere anywhere tcp dpt:1024
    0 0 LOG tcp -- any any anywhere anywhere tcp dpt:1024 LOG level warning
    Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
    Chain OUTPUT (policy ACCEPT 17042 packets, 1567K bytes)
    pq as primeiras nao entraram ???
    alguem poderia me ajudar ???
    Obrigado. :wink:
    coloque --limit ao inves de -limit
    Felipe_
    e no caso pq aparece esse "flags not allowed" ? e a letra antes.
    ops num tinha visto essa
    eh --syn e nao -syn
    Felipe_
    agora ta aparecendo isso:
    iptables v1.2.9: Unknown arg `--limit'
    iptables v1.2.9: Unknown arg `--limit-burst'
    bom sao varias regras com problema....
    vai executadando uma por uma pra achar o erro
    Felipe_
    [email protected] rc.d]# iptables -A INPUT -i eth0 -p tcp -s 0.0.0.0/0 --limit 3/min
    [[email protected] rc.d]# iptables -A INPUT -i eth0 -p tcp -s 0.0.0.0/0 -limit 3/min
    [[email protected] rc.d]# iptables -A INPUT -i eth0 -p tcp -s 0.0.0.0/0 --limit-burst 3 -j LOG
    [[email protected] rc.d]# iptables -A INPUT -i eth0 -p tcp -s 0.0.0.0/0 -limit-burst 3 -j LOG
    [[email protected] rc.d]# iptables -A INPUT -i eth0 -p tcp -s 0.0.0.0/0 --syn -j LOG
    [[email protected] rc.d]# iptables -A INPUT -s 0/0 -d 0/0 -p icmp -j DROP
    [[email protected] rc.d]# iptables -A INPUT -s 0/0 -d 0/0 -p icmp -j LOG
    [[email protected] rc.d]# iptables -A INPUT -s 0/0 -d 0/0 -p tcp -dport 20 -j DROP
    [[email protected] rc.d]# iptables -A INPUT -s 0/0 -d 0/0 -p tcp -dport 21 -j DROP
    [[email protected] rc.d]# iptables -A INPUT -s 0/0 -d 0/0 -p tcp -dport 25 -j DROP
    [[email protected] rc.d]# iptables -A INPUT -p tcp --dport 22 -j LOG
    [[email protected] rc.d]# iptables -A INPUT -p tcp --dport 22 -j DROP
    [[email protected] rc.d]# iptables -A INPUT -p tcp --dport 1024 -j ACCEPT
    [[email protected] rc.d]# iptables -A INPUT -p tcp --dport 1024 -j LOG
    eh tudo --dport ai em cima e nao -dport
    Felipe_
    obrigado ic3_m4n
    agora só mais uma coisa.....
    adicionei mais alguns comandos...
    quando dou o comando ./rc.local aparece isso
    iptables v1.2.9: Couldn't load match `ultiport':/lib/iptables/libipt_ultiport.so: cannot open shared object file: No such file or directory
    mas quando entro no /lib/iptables/
    esse arquivo libipt_ultiport.so esta como libipt_multiport.so
    pq ele esta lendo o nome errado ?? e ai nao consegue executar o comando....
    tem como fazer ele ler o nome certo ?
    Obrigado.
    Felipe_
    estou usando este comando que da aquele erro...
    iptables -A INPUT -p tcp --multiport --destination-port 135,137,138,139 -j LOG
    iptables -A INPUT -p udp --multiport --destination-port 137,138,139 -j LOG
    Existe algum outro comando alem desse para registrar as tentativas de análise nas portas padrão em redes Microsoft ??
    Obrigado. ops:
