  1. cara... verifica as permissões do diretório no qual os arquivos estão...
  2. #7
    evandro_mr
    to achando que pode ser alguma permissao do dominio ou dos usuarios, alguem pode me dizer o que acham?????
    sds
    Evandro Ribeiro
  3. #8
    evandro_mr
    ja dei um chmod 777 em todos os diretorios e nada....
    sds
    Evandro Ribeiro
  4. Posta o seu smb.conf para gente dar uma olhada
  5. #10
    evandro_mr
    # This is the main Samba configuration file. You should read the
    # smb.conf(5) manual page in order to understand the options listed
    # here. Samba has a huge number of configurable options (perhaps too
    # many!) most of which are not shown in this example
    # Any line which starts with a ; (semi-colon) or a # (hash)
    # is a comment and is ignored. In this example we will use a #
    # for commentry and a ; for parts of the config file that you
    # may wish to enable
    # NOTE: Whenever you modify this file you should run the command "testparm"
    # to check that you have not made any basic syntactic errors.
    #======================= Global Settings =====================================
    [global]
    # workgroup = NT-Domain-Name or Workgroup-Name
    workgroup = ISPDOMAIN
    netbios name = servidor
    # server string is the equivalent of the NT Description field
    server string = Servidor de Arquivos - Linux
    # This option is important for security. It allows you to restrict
    # connections to machines which are on your local network. The
    # following example restricts access to two C class networks and
    # the "loopback" interface. For more examples of the syntax see
    # the smb.conf man page
    ; hosts allow = 192.168.1. 192.168.2. 127.
    # if you want to automatically load your printer list rather
    # than setting them up individually then you'll need this
    # printcap name = /etc/printcap
    # load printers = yes
    # It should not be necessary to spell out the print system type unless
    # yours is non-standard. Currently supported print systems include:
    # bsd, sysv, plp, lprng, aix, hpux, qnx, cups
    # printing = cups
    # Uncomment this if you want a guest account, you must add this to /etc/passwd
    # otherwise the user "nobody" is used
    ; guest account = pcguest
    # this tells Samba to use a separate log file for each machine
    # that connects
    log file = /var/log/samba/%m.log
    # Put a capping on the size of the log files (in Kb).
    max log size = 0
    # Security mode. Most people will want user level security. See
    # security_level.txt for details.
    security = user
    # Use password server option only with security = server
    # The argument list may include:
    # password server = My_PDC_Name [My_BDC_Name] [My_Next_BDC_Name]
    # or to auto-locate the domain controller/s
    # password server = *
    ; password server = <NT-Server-Name>
    # Password Level allows matching of _n_ characters of the password for
    # all combinations of upper and lower case.
    ; password level = 8
    ; username level = 8
    # You may wish to use password encryption. Please read
    # ENCRYPTION.txt, Win95.txt and WinNT.txt in the Samba documentation.
    # Do not enable this option unless you have read those documents
    encrypt passwords = yes
    smb passwd file = /etc/samba/smbpasswd
    # The following is needed to keep smbclient from spouting spurious errors
    # when Samba is built with support for SSL.
    ; ssl CA certFile = /usr/share/ssl/certs/ca-bundle.crt
    # The following are needed to allow password changing from Windows to
    # update the Linux system password also.
    # NOTE: Use these with 'encrypt passwords' and 'smb passwd file' above.
    # NOTE2: You do NOT need these to allow workstations to change only
    # the encrypted SMB passwords. They allow the Unix password
    # to be kept in sync with the SMB password.
    unix password sync = Yes
    passwd program = /usr/bin/passwd %u
    passwd chat = *New*password* %n\n *Retype*new*password* %n\n *passwd:*all*authentication*tokens*updated*successfully*
    # You can use PAM's password change control flag for Samba. If
    # enabled, then PAM will be used for password changes when requested
    # by an SMB client instead of the program listed in passwd program.
    # It should be possible to enable this without changing your passwd
    # chat parameter for most setups.
    pam password change = yes
    # Unix users can map to different SMB User names
    ; username map = /etc/samba/smbusers
    # Using the following line enables you to customise your configuration
    # on a per machine basis. The %m gets replaced with the netbios name
    # of the machine that is connecting
    ; include = /etc/samba/smb.conf.%m
    # This parameter will control whether or not Samba should obey PAM's
    # account and session management directives. The default behavior is
    # to use PAM for clear text authentication only and to ignore any
    # account or session management. Note that Samba always ignores PAM
    # for authentication in the case of encrypt passwords = yes
    obey pam restrictions = yes
    # Most people will find that this option gives better performance.
    # See speed.txt and the manual pages for details
    socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
    # Configure Samba to use multiple interfaces
    # If you have multiple network interfaces then you must list them
    # here. See the man page for details.
    ; interfaces = 192.168.12.2/24 192.168.13.2/24
    # Configure remote browse list synchronisation here
    # request announcement to, or browse list sync from:
    # a specific host or from / to a whole subnet (see below)
    ; remote browse sync = 192.168.3.25 192.168.5.255
    # Cause this host to announce itself to local subnets here
    ; remote announce = 192.168.1.255 192.168.2.44
    # Browser Control Options:
    # set local master to no if you don't want Samba to become a master
    # browser on your network. Otherwise the normal election rules apply
    local master = yes
    # OS Level determines the precedence of this server in master browser
    # elections. The default value should be reasonable
    os level = 34
    # Domain Master specifies Samba to be the Domain Master Browser. This
    # allows Samba to collate browse lists between subnets. Don't use this
    # if you already have a Windows NT domain controller doing this job
    domain master = yes
    # Preferred Master causes Samba to force a local browser election on startup
    # and gives it a slightly higher chance of winning the election
    preferred master = yes
    # Enable this if you want Samba to be a domain logon server for
    # Windows95 workstations.
    domain logons = yes
    # if you enable domain logons then you may want a per-machine or
    # per user logon script
    # run a specific logon batch file per workstation (machine)
    ; logon script = %m.bat
    # run a specific logon batch file per username
    logon script = %U.bat
    # Where to store roving profiles (only for Win95 and WinNT)
    # %L substitutes for this servers netbios name, %U is username
    # You must uncomment the [Profiles] share below
    ; logon path = \\%L\Profiles\%U
    # Windows Internet Name Serving Support Section:
    # WINS Support - Tells the NMBD component of Samba to enable it's WINS Server
    ; wins support = yes
    # WINS Server - Tells the NMBD components of Samba to be a WINS Client
    # Note: Samba can be either a WINS Server, or a WINS Client, but NOT both
    ; wins server = w.x.y.z
    # WINS Proxy - Tells Samba to answer name resolution queries on
    # behalf of a non WINS capable client, for this to work there must be
    # at least one WINS Server on the network. The default is NO.
    ; wins proxy = yes
    # DNS Proxy - tells Samba whether or not to try to resolve NetBIOS names
    # via DNS nslookups. The built-in default for versions 1.9.17 is yes,
    # this has been changed in version 1.9.18 to no.
    dns proxy = no
    # Case Preservation can be handy - system default is _no_
    # NOTE: These can be set on a per share basis
    ; preserve case = no
    ; short preserve case = no
    # Default case is normally upper case for all DOS files
    ; default case = lower
    # Be very careful with case sensitivity - it can break things!
    ; case sensitive = no
    #============================ Share Definitions ==============================
    # If you want users samba doesn't recognize to be mapped to a guest user
    ; map to guest = bad user
    [homes]
    comment = Diretorio do Usuario
    browseable = no
    writable = yes
    valid users = %S
    create mode = 0664
    directory mode = 0775
    # Un-comment the following and create the netlogon directory for Domain Logons
    [netlogon]
    comment = Network Logon Service
    path = /home/netlogon
    guest ok = yes
    writable = no
    share modes = no
    printable = no
    browseable = no
    # Un-comment the following to provide a specific roving profile share
    # the default is to use the user's home directory
    ;[Profiles]
    ; path = /usr/local/samba/profiles
    ; browseable = no
    ; guest ok = yes
    # NOTE: If you have a BSD-style print system there is no need to
    # specifically define each individual printer
    #[printers]
    # comment = All Printers
    # path = /var/spool/samba
    # browseable = no
    # Set public = yes to allow user 'guest account' to print
    # guest ok = no
    # writable = no
    # printable = yes
    # This one is useful for people to share files
    [cdrom]
    comment = CDROM do Servidor Linux
    path = /mnt/cdrom
    read only = no
    public = yes
    writable = yes
    create mode = 0777
    [c]
    comment = Repositorio Geral
    public = yes
    path = /dados/repositorio/
    writable = yes
    force directory mode = 0777
    force create mode = 0777
    create mask = 0777
    directory mask = 0777
    share modes = yes
    locking = no
    [dados]
    public = yes
    writeable = yes
    path = /dados/repositorio/Dados
    comment = Repositorio Geral - Dados
    create mask = 0777
    share modes = yes
    locking = no
    # A publicly accessible directory, but read only, except for people in
    # the "staff" group
    ;[public]
    ; comment = Public Stuff
    ; path = /home/samba
    ; public = yes
    ; writable = yes
    ; printable = no
    ; write list = @staff
    # Other examples.
    # A private printer, usable only by fred. Spool data will be placed in fred's
    # home directory. Note that fred must have write access to the spool directory,
    # wherever it is.
    ;[fredsprn]
    ; comment = Fred's Printer
    ; valid users = fred
    ; path = /home/fred
    ; printer = freds_printer
    ; public = no
    ; writable = no
    ; printable = yes
    # A private directory, usable only by fred. Note that fred requires write
    # access to the directory.
    ;[fredsdir]
    ; comment = Fred's Service
    ; path = /usr/somewhere/private
    ; public = no
    ; writable = yes
    ; printable = no
    # a service which has a different directory for each machine that connects
    # this allows you to tailor configurations to incoming machines. You could
    # also use the %U option to tailor it by user name.
    # The %m gets replaced with the machine name that is connecting.
    ;[pchome]
    ; comment = PC Directories
    ; path = /usr/local/pc/%m
    ; public = no
    ; writable = yes
    # A publicly accessible directory, read/write to all users. Note that all files
    # created in the directory by users will be owned by the default user, so
    # any user with access can delete any other user's files. Obviously this
    # directory must be writable by the default user. Another user could of course
    # be specified, in which case all files would be owned by that user instead.
    ;[public]
    ; path = /usr/somewhere/else/public
    ; public = yes
    ; only guest = yes
    ; writable = yes
    ; printable = no
    # The following two entries demonstrate how to share a directory so that two
    # users can place files there that will be owned by the specific users. In this
    # setup, the directory should be writable by both users and should have the
    # sticky bit set on it to prevent abuse. Obviously this could be extended to
    # as many users as required.
    ;[myshare]
    ; comment = Mary's and Fred's stuff
    ; path = /usr/somewhere/shared
    ; valid users = mary fred
    ; public = no
    ; writable = yes
    ; printable = no
    ; create mask = 0765
  1. configurar permissões no samba
    Por alexlabtec no fórum Servidores de Rede
    Respostas: 20
    Último Post: 20-11-2006, 16:45
  2. permissoes no samba ....
    Por fpmazzi no fórum Servidores de Rede
    Último Post: 20-09-2005, 16:25
  3. permissoes no samba
    Por helinho no fórum Servidores de Rede
    Último Post: 03-08-2005, 07:32
  4. Permissoes no samba !!!! Socorro
    Por STEEV no fórum Servidores de Rede
    Respostas: 9
    Último Post: 06-01-2004, 18:24
  5. Permissoes no samba 3
    Por imax no fórum Servidores de Rede
    Último Post: 27-12-2003, 15:13
