    Educpd
    Padrão SARG com IP´s estranho !!
    Olá galera,
    Estão aparecendo uns IP´s estranhos nos meus relatórios Exemplo:
    201.0.242.26 tentando acessar o endereço error:request-too-large
    218.17.231.96 tentando acessar o endereço mx1.mail.tw.yahoo.com:25
    200.216.14.165 tentando acessar o endereço www.google.com
    Alguem saberia me dizer a origem desses Ip´s??? Porque acontece isso?/
    Aguardo a ajuda dos amigos;....
    Edu
    Hehehehe, porque estão utilizando o seu proxy... =)
    Educpd
    Amigos, Segue meu squid.conf
    # --- Configuracao do Squid --- #
    http_port 8080
    icp_port 3130
    ftp_passive off
    #dns_nameservers
    #--- inicio Conf.Proxy transparente---#
    httpd_accel_host virtual
    httpd_accel_port 80
    #httpd_accel_single_host on
    httpd_accel_with_proxy on
    #--- fim---#
    #htcp_port 4827
    icp_query_timeout 2000
    maximum_icp_query_timeout 2000
    no_cache deny QUERY
    cache_mem 256 MB
    cache_swap_low 90
    cache_swap_high 95
    maximum_object_size 512 MB
    minimum_object_size 0 KB
    maximum_object_size_in_memory 64 KB
    cache_dir ufs /var/spool/squid 300 16 256
    cache_log /var/log/squid/cache.log
    cache_store_log /var/log/squid/store.log
    mime_table /etc/squid/mime.conf
    auth_param basic program /usr/lib/squid/smb_auth -W EMPRESA -U 10.0.0.7
    auth_param basic children 5
    auth_param basic realm *** Web ***
    authenticate_ttl on 1000
    auth_param basic credentialsttl 2 hours
    acl conexoes maxconn 1
    acl controle proxy_auth REQUIRED
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443 563
    acl Safe_ports port 80
    acl Safe_ports port 20
    acl Safe_ports port 21
    acl Safe_ports port 443 563
    acl Safe_ports port 70
    acl Safe_ports port 210
    acl Safe_ports port 1025-65535
    acl Safe_ports port 777 # multilink http
    acl CONNECT method CONNECT
    #---ACL's do Usuario---#
    acl manha time MTWHF 7:00-13:00
    acl tarde time MTWHF 14:00-18:30
    acl usuario src "/etc/squid/usuarios"
    #acl ips_bloqueados src "/etc/squid/ips_bloqueados"
    acl redeSP src 10.0.0.0/255.255.255.0
    acl redeAM src 10.0.5.0/255.255.255.0
    acl redeMG src 10.0.4.0/255.255.255.0
    acl redeLAB src 10.0.3.0/255.255.255.0
    acl ips_liberados src "/etc/squid/ips_liberados"
    acl palavra_libera url_regex -i "/etc/squid/palavra_libera"
    acl palavra_quente url_regex -i "/etc/squid/palavraquente"
    #acl controle_banda url_regex -i .exe$ .jpg$
    acl download url_regex -i .mpeg$ .mp3$ .avi$ .mpg$ .wav$ .wmv$ .iso$ .rar$
    # ---Acessos--- #
    http_access deny manager
    #http_access deny ips_bloqueados
    http_access allow ips_liberados
    http_access allow palavra_libera
    http_access deny palavra_quente
    http_access deny download
    http_access allow users
    http_access allow usuario controle
    http_access allow redeSP
    http_access allow redeMG
    http_access allow redeAM
    http_access allow redeLAB
    http_access deny all
    cache_mgr [email protected]
    ie_refresh on
    Tem algo errado ????
    Edu
    Troca o:
    Código :
    http_port 8080
    por
    Código :
    http_port 192.168.0.1:8080
    Educpd
    Stéfano
    Qual a diferença de 8080 para 192.168.0.1:8080
    Isso impede que alguem de fora usar meu proxy ????
    Edu
    epf
    exatamente..limitara a utilizacao do proxy somente para a rede local.
    Educpd
    Sempre ouvi falar, em diversos tutoriais que só tendo a opção
    as acls de sua rede local definida e tendo a opção deny all no final do arquivo squid.conf ja estaria protegido desses problemas.
    Mas valeu !!!
    É, mas no seu squid.conf você determinou "all" como sendo todos os IP's...
    Educpd
    Vc diz o deny all ???
    Isso esta errado ou certo ???
    Edu
    rafaelpazcolles
    Cara, derrepenter seria bom tu dar um "drop" por iptables nas requisicoes da tua porta do proxy.
    Educpd
    Verdade vou reavaliar isso !!!!
    Valeu galera !!!
    Edu
    gmlinux
    Citação Postado originalmente por Educpd
    Mas valeu !!!
    O que o nosso competente amigo xstefanox sugeriu evita que o squid faça listen em uma interface para o qual não se tenha necessidade.
    As ACLs permite que o squid controle o uso, mais se ele não faz listen em uma interface desnecessaria, evita-se que ele tenha que processar requisições provenientes dela, liberando recursos da sua máquina.
    gmlinux, assim eu fico acanhado :roll: :roll: :roll: . Hehehhe.
