    philosophus
    Sugiro que vc liste os módulos carregados
    #lsmod
    Posso estar equivocado mas o módulo da Realtek não é o 8139too?
    #insmod 8139too
    #lsmod
    Se o módulo aparecer então tente configurar a rede.
    #ifconfig eth0 seu_ip broadcast seu_broadcast netmask sua_netmask up
    Acho que é isso. Se isso não funcionar ... compile um novo kernel. Mas a última versão já é a 2.6.9 ...
    Boa sorte
  2. #7
    grilo
    Bom galera eu baixei o debian 3.0r3 dai eu instalei ele com o boot:bf24
    bom oks.. bom ele nao tem o modulo para rtl8139too.o, dai eu baixei do site da realtek e acontece o seguinte:
    contem o arquivo Makefile e 8139too.c
    #./Makefile o bash retorna o erro:
    ./Makefile: line 13: NEW_INCLUDE_PATH: command not found
    ./Makefile: line 19: MODCFLAGS: command not found
    ./Makefile: line 23: all:: command not found
    ./Makefile: line 25: 8139too:: command not found
    ./Makefile: line 1: CC: command not found
    ./Makefile: line 1: MODCFLAGS: command not found
    ./Makefile: line 1: NEW_INCLUDE_PATH: command not found
    ./Makefile: line 26: -I: command not found
    ./Makefile: line 28: .: filename argument required
    .: usage: . filename
    abaixo esta o readme que veio com o arquivo
    8139too.c release note
    2001/10/31 by ShuChen Shao
    1.This driver was originally based on 8139too.c version "0.9.15".
    2.It has been enhanced to support RTL8139C+ PCI ethernet controller.
    3.RTL8139C+ PCI ethernet chips is set to support C+ mode by default.
    If FORCE_C_Mode below is enabled, the RTL8139C+ chip will be forced to support C mode
    after reboot.
    4.This program can be compiled using the attached Makefile.
    Please remember to SPECIFY "NEW_INCLUDE_PATH" in Makefile according to your linux environment.
    The object file named 8139too.o should be moved to the directory
    /lib/modules/<linux-version>/kernel/drivers/net/
    The driver could be brought up by the following steps:
    'insmod 8139too'
    'ifconfig eth0 up'
    5.It can support Auto-Negotiation ability,that is
    10-half 0x01
    10-full 0x02
    100-half 0x04
    100-full 0x08
    If 10-half mode is expected, it can be achieved by the following steps:
    #ifconfig eth0 down
    #rmmod 8139too
    #insmod 8139too media=0x01
    6.If the "Install Type", selected during the Linux install procedure, is "laptop",
    this driver can work normally for CardBus application without any modification.
    Otherwise, reinstall Linux and select "Install Type" as "laptop".
    Then this driver can also work.
    bom se alguem poder me da uma ajuda pra configurar esta plca eu agradeço
    valeus....
  3. #8
    nesse dir digite
    # make
    # mv 8139too.o /lib/modules/<linux-version>/kernel/drivers/net/
    # modprobe 8139too
  4. #9
    grilo
    nesse dir digite
    # make
    # modprobe 8139too
    fiz o q me disse:
    net254:/home/net254# make
    Makefile:28: *** missing separator. Stop.
    deu isto...
    meu arquivo ta defeituoso?
    ou o q?
    valeus
  5. Realtek 8139 já vem compilada junto com o Kernel bf24. Nunca tive problema ALGUM configurando essa placa. Para certificar-se que sua placa foi reconhecida, rode um:
    Código :
    # dmesg |grep eth
    Também nunca tive zica com sis900...
  1. IFconfig
    Por Jeff no fórum Servidores de Rede
    Último Post: 07-01-2005, 11:42
  2. mac da sis900 esta zerado no ifconfig..
    Por quecosuix no fórum Sistemas Operacionais
    Último Post: 22-08-2004, 06:33
  3. DUVIDA NO IFCONFIG
    Respostas: 5
    Último Post: 06-07-2004, 21:30
  4. Liberar IP pelo ifconfig
    Por giuliano no fórum Servidores de Rede
    Último Post: 05-06-2004, 08:39
  5. ifconfig + erro
    Último Post: 08-06-2003, 14:24
