    karfax
    Entendí mesmo ( não sei como...) ops:
    Acrescente a diretiva:
    valid users = @grupoespecifico, eu, tu
    read list = eu, tu, @grupo
    write list = eu, tu, @grupo
    ... no compartilhamento.
    Pode resolver.
    Sds,
    8)
  2. #7
    nooby
    o problema persiste...
  3. #8
    karfax
    Coloque aí seu smb.conf
    Sds,
  4. #9
    nooby
    global]
    workgroup = nuvital
    server string = Conectiva Linux SMB Server
    printcap name = cups
    load printers = yes
    printing = cups
    log file = /var/log/samba/%m.log
    max log size = 50
    debug level = 1
    security = server
    encrypt passwords = yes
    smb passwd file = /etc/samba/smbpasswd
    username map = /etc/samba/smbusers
    socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
    add machine script = /usr/sbin/adduser -n -r -g machines -c "Samba machine" -d /dev/null -s /bin/false %u
    # see the smb.conf(5) manpage for other important backends, such as tdbsam and ldap
    passdb backend = smbpasswd
    password server = servidor
    #============================ Share Definitions ==============================
    idmap uid = 16777216-33554431
    idmap gid = 16777216-33554431
    template shell = /bin/false
    winbind use default domain = no
    [homes]
    comment = Home Directories
    browseable = no
    writable = yes
    ;[Usuarios]
    ; comment = arquivos
    ; path = /arquivos
    ; guest ok = yes
    ; writable = yes
    ; read only = no
    [Acesso Livre]
    comment = Acesso Livre
    path = /mnt/sda1/Acesso.Livre
    guest ok = yes
    writable = yes
    read only = no
    # Un-comment the following and create the netlogon directory for Domain Logons
    ; [netlogon]
    ; comment = Network Logon Service
    ; path = /home/netlogon
    ; guest ok = yes
    ; writable = no
    ; share modes = no
    # Un-comment the following to provide a specific roving profile share
    # the default is to use the user's home directory
    ;[Profiles]
    ; path = /home/profiles
    ; browseable = no
    ; guest ok = yes
    # automatic printer driver download support
    [print$]
    path = /var/lib/samba/drivers
    guest ok = yes
    browseable = yes
    read only = yes
    ; since this share is configured as read only, then we need
    ; a 'write list'. Check the file system permissions to make
    ; sure this account can copy files to the share. If this
    ; is setup to a non-root account, then it should also exist
    ; as a 'printer admin'
    write list = root
    [printers]
    comment = All Printers
    path = /var/spool/samba
    browseable = no
    # Set public = yes to allow user 'guest account' to print
    guest ok = no
    writable = no
    printable = yes
    printer admin = root
  5. #10
    karfax
    Ficou lindo.
    Cadê o share que vc quer compartilhar com um grupo ou usuários definidos?
    Sds,
  1. Win98 não acessa compartilhamento do Samba
    Por scratch no fórum Servidores de Rede
    Último Post: 19-05-2009, 11:42
  2. Compartilhamento
    Por hyperblade no fórum Servidores de Rede
    Respostas: 5
    Último Post: 09-05-2002, 17:32
  3. diretivas de compartilhamento
    Por vandemberg no fórum Servidores de Rede
    Último Post: 21-04-2002, 18:43
  4. Performance de Sistemas com WIN98/LINUX-SAMBA
    Por soyeu no fórum Servidores de Rede
    Último Post: 28-03-2002, 21:55
  5. Compartilhamento
    Por kecal2002 no fórum Servidores de Rede
    Último Post: 28-03-2002, 21:50
