    Educpd
    Amigo,
    o que vai nesse paramentro local_recipient_maps =
    Segue meu master.cf
    smtp inet n - n - - smtpd
    #submission inet n - n - - smtpd
    # -o smtpd_etrn_restrictions=reject
    #628 inet n - n - - qmqpd
    pickup fifo n - n 60 1 pickup
    cleanup unix n - n - 0 cleanup
    qmgr fifo n - n 300 1 qmgr
    #qmgr fifo n - n 300 1 oqmgr
    rewrite unix - - n - - trivial-rewrite
    bounce unix - - n - 0 bounce
    defer unix - - n - 0 bounce
    trace unix - - n - 0 bounce
    verify unix - - n - 1 verify
    flush unix n - n 1000? 0 flush
    proxymap unix - - n - - proxymap
    smtp unix - - n - - smtp
    relay unix - - n - - smtp
    # -o smtp_helo_timeout=5 -o smtp_connect_timeout=5
    showq unix n - n - - showq
    error unix - - n - - error
    local unix - n n - - local
    virtual unix - n n - - virtual
    lmtp unix - - n - - lmtp
    anvil unix - - n - 1 anvil
    maildrop unix - n n - - pipe
    flags=DRhu user=maildrop argv=/usr/bin/maildrop -w 50 -d ${recipient}
    # Interfaces to non-Postfix software. Be sure to examine the manual
    # pages of the non-Postfix software to find out what options it wants.
    # maildrop. See the Postfix MAILDROP_README file for details.
    #maildrop unix - n n - - pipe
    # flags=DRhu user=vmail argv=/usr/local/bin/maildrop -d ${recipient}
    # The Cyrus deliver program has changed incompatib
    ly, multiple times.
    old-cyrus unix - n n - - pipe
    flags=R user=cyrus argv=/cyrus/bin/deliver -e -m ${extension} ${user}
    # Cyrus 2.1.5 (Amos Gouaux)
    # Also specify in main.cf: cyrus_destination_recipient_limit=1
    user=cyrus argv=/cyrus/bin/deliver -e -r ${sender} -m ${extension} ${user}
    uucp unix - n n - - pipe
    flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
    flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
    bsmtp unix - n n - - pipe
    flags=Fq. user=foo argv=/usr/local/sbin/bsmtp -f $sender $nexthop $recipient
    filter unix - n n - - pipe
  2. #12
    karfax
    No teu caso, com cyrus-imapd nada. Deve estar comentado.
    mas unknown_local_recipient_reject_code = 550
    irá recusar mensagens quando o usuário da conta local não for encontrado.
    O melhor é voce ativar a flag debug, incluir seu host na lista e mandar o log de uma remessa considerada inválida.
    Remova seu hsot de debug_peer_list depois de capturar o log - para não encher demias o arquivo.
    Sds,
  3. #13
    Educpd
    Isso de recusar quando não houver o usuario da conta ja estava funcionado porque o default ja era 550.
    O problema é rejeitar o envio se o remetente for invalido !!!! E outra ele tb rejeitar mesmo no cliente de email não estando o flag exigindo autenticação
    Gostaria que fosse obrigatório colocar a flag la no Outlook e ele autenticasse pela configuração da conta de entrada!!!! Igual o Terra faz.
    Hoje esta enviando mesmo com remetentes invalidos tipo merda@qualquercoisa.com.br !!! Ele aceita o envio.
    Mesmo essse dominio não estando cadastrado no mysql e nem no dominio local !!!
    Qualquer ajuda , por favor !!!
    Edu
  4. #14
    karfax
    Depois de check_relay_domains
    coloque:
    reject
    E tente novamente.
    ps: eu pedi o log do smtp traceando a conexão e vc não mandou. Quero ver exatamente em qual a diretiva ele está dando relay, e sem os logs não dá...
    Sds
  5. #15
    Educpd
    Cara,
    Desculpe, só me fala onde e como eu ativo o debug !!!???
    Onde ele gera o arquivo ???
    Edu
  1. novo problema - Postfix MySQL SASL
    Por nilsonjr no fórum Servidores de Rede
    Último Post: 26-07-2006, 09:13
  2. relay no postfix com sasl
    Por rodriguesoline no fórum Servidores de Rede
    Respostas: 13
    Último Post: 26-04-2005, 13:39
  3. Postfix Mysql Sasl
    Por gerusso no fórum Servidores de Rede
    Último Post: 27-12-2004, 08:51
  4. postfix+cyrus-sasl+cyrus-imapd+popa3d
    Por andfgon no fórum Servidores de Rede
    Último Post: 20-09-2004, 18:34
  5. Postfix com Sasl
    Por mariborghi no fórum Servidores de Rede
    Último Post: 30-06-2004, 21:15
