    guardian_metal
    Padrão Configurar rede (problemas na rota)
    [[email protected] lsts]# /sbin/route del default
    [[email protected] lsts]# /sbin/route add default eth1
    [[email protected] lsts]# /sbin/route add default gw 192.168.172.1
    [[email protected] lsts]# /etc/init.d/network restart
    Shutting down interface eth0: [ OK ]
    Shutting down interface eth1: [ OK ]
    Shutting down loopback interface: [ OK ]
    Disabling IPv4 packet forwarding: [ OK ]
    Setting network parameters: [ OK ]
    Bringing up loopback interface: [ OK ]
    Bringing up interface eth0: [ OK ]
    Bringing up interface eth1: [ OK ]
    Kernel IP routing table
    Destination Gateway Genmask Flags Metric Ref Use Iface
    192.168.172.0 * 255.255.255.0 U 0 0 0 eth0
    192.168.172.0 * 255.255.255.0 U 0 0 0 eth1
    169.254.0.0 * 255.255.0.0 U 0 0 0 eth1
    default 192.168.172.1 0.0.0.0 UG 0 0 0 eth0
    Pelo o que me parece é que ele usa o endereço 192.168.172.1 como gateway na eth0 mas eu adicionei o gateway 192.168.172.1 na eth1.
    O que há de errado?
    Agora vejam isso:
    [[email protected] network-scripts]# cat ifcfg-eth0
    BOOTPROTO=none
    PEERDNS=no
    IPV6INIT=no
    TYPE=Ethernet
    HWADDR=00:07:E9:19:EB:AA
    DEVICE=eth0
    MTU=""
    NETMASK=255.255.255.0
    BROADCAST=192.168.172.255
    IPADDR=192.168.172.4
    NETWORK=192.168.172.0
    USERCTL=no
    ONBOOT=yes
    You have new mail in /var/spool/mail/henrique
    [[email protected] network-scripts]# cat ifcfg-eth1
    GATEWAY=192.168.172.1
    BOOTPROTO=none
    PEERDNS=no
    HWADDR=00:0BB:8E:98:9B
    TYPE=Ethernet
    IPV6INIT=no
    DEVICE=eth1
    MTU=""
    IPADDR=192.168.172.2
    ONBOOT=yes
    USERCTL=no
    O gateway esta na interface eth1 mas o comando route me mostra na eth0. O que faço agora?
    Minhas linhas de nat.
    iptables=/sbin/iptables
    IF_EXTERNA=eth1
    IF_INTERNA=eth0
    #Habilita (NAT)
    $iptables -t nat -A POSTROUTING -o $IF_EXTERNA -j MASQUERADE
    #Redireciona Todas as portas para a 8080 (http) (Squid)
    $iptables -t nat -A PREROUTING -s 192.168.172.0/24 -p tcp --dport 80 -j REDIRECT --to 8080
    $iptables -t nat -A PREROUTING -s 192.168.172.0/24 -p udp --dport 80 -j REDIRECT --to 8080
    $iptables -t nat -A PREROUTING -s localhost -p tcp --dport 80 -j REDIRECT --to 8080
    $iptables -t nat -A PREROUTING -s localhost -p udp --dport 80 -j REDIRECT --to 8080
    abc
    Padrão Rotas
    Desabilita as interfaces, e levanta tudo na mao,:
    ifconfig e route
    E veja o que acontece
    Se der certo coloque no rc.local
    estanisgeyer
    Você fez uma pequena confusão. Seria assim:
    # route del default
    # route add default gw 192.168.172 eth1
    # service network restart
    Att.
    guardian_metal
    Reiniciei cada uma das interfaces na mão e continua igual e:
    [[email protected] lsts]# /sbin/route add default gw 192.168.172.1 eth1
    [[email protected]erv lsts]# /etc/init.d/network restart
    guardian_metal
    Pra quem acha maluko, veja só:
    1. Configurando o Gateway padrão e reiniciando a rede:
    Obs: Mesmo configurando o gateway na eth1, ele só funciona na eth0 quando reinicio a rede.
    2. Configurando o Gateway padrão e não reiniciando a rede:
    default 192.168.172.1 0.0.0.0 UG 0 0 0 eth1
    Obs: Mesmo configurando o gateway na eth1, ele só funciona na eth1 se o serviço rede não for reiniciado.
    Solução: Colocar o seguinte em rc.local;
    E pronto. Loko, né?
    felco
    Red Hat sux alot
    Rodrigo Ortiz
    Padrão ROTA
    Seguinte o redhat , fedora e similares, criam o gateway default apartir do arwuiov /etc/sysconfig/network
    Dentro deste arquivo tem a variável GATEWAYNA QUAL PODE SER SETADO TAMBÉM O GATEWAYDEV.....
    Veja o que diz esse arquivio para que seja utilizado o que está descxito no ifcfg-eth0 ou 1
    Rodrigo Ortiz
    guardian_metal
    esse arquivos estavam com o gateway na eth1 mas o comando route mostrava que o gateway tava na eth0.
    cleziano
    acho estranho esse detalhe:
    duas placas diferentes tem o mesmo destino?
    acho que ele tá pegando por default a primeira rota que vai para a eth0.
    guardian_metal
    Por motivos administrativos aqui, me pediram pra colocar o ip 192.168.172.10 na eth1 e 192.168.172.11 na eth0 e meu gateway é um D-Link 192.168.172.1.
    cleziano
    acho que se as duas placas de rede estão na mesma rede (192.168.172.0) então tanto faz o getway ser a eth0 como a eth1...
    tenho duas sugestões:
    1- colocar um ip da rede 169.254.0.0 netmask 255.255.0.0 na eth0 e deixar o ip da rede 192.168.172.0 netmask 255.255.255.0 na eth1 para que o getway seja a eth1 ou
    2- mudar o ip da eth1 para a rede 169.254.0.0 netmask 255.255.0.0 e deixar a tebela de rotas como está, tirando apenas a rota 192.168.172.0 * 255.255.255.0 U 0 0 0 eth1 que estará na eth0.
    aproveitando o embalo, tenho aqui 2 placas de rede iguais e o driver e o mesmo so que cada ves que eu reinicio a maquina ele muda o a eth0 de placa, tipo ele se atrapalha e horas pega a placa de cima e horas pega a placa de baixo, e ae qual e a solução?
    sigmanalo
    Padrão duas placas
    no debian ao menos existe como definir a placa de rede pelo mac address no arquivo de interfaces de rede, é só acrescentar a diretiva
    hwaddress ether XY:XY:XY:XY:XY:XY
    na respectiva placa.
