    felco
    Tem que ver... mas o FTP funciona assim qndo vc conecta no server vc faz o login pela porta 21, depois disso vc estando conectado a ele e autenticado, qualquer comando que vc envie ele ira te responder por duas portas a 21 ea 20
    olha o dump entre minha maquina eo server ftp do uol
    Conectando:
    Código :
    10:32:00.014177 IP 192.168.0.65.42282 > 200.221.10.4.21:
    10:32:00.111476 IP 200.221.10.4.21 > 192.168.0.65.42282:
    10:32:00.111580 IP 192.168.0.65.42282 > 200.221.10.4.21:
    10:32:00.173270 IP 200.221.10.4.21 > 192.168.0.65.42282:
    10:32:00.173489 IP 192.168.0.65.42282 > 200.221.10.4.21:
    Login:
    Código :
    10:33:43.342179 IP 192.168.0.65.42282 > 200.221.10.4.21:
    10:33:43.350469 IP 200.221.10.4.21 > 192.168.0.65.42282:
    10:33:43.352254 IP 200.221.10.4.21 > 192.168.0.65.42282:
    10:33:43.355444 IP 192.168.0.65.42282 > 200.221.10.4.21:
    10:33:43.360352 IP 192.168.0.65.42282 > 200.221.10.4.21:
    10:33:43.374115 IP 200.221.10.4.21 > 192.168.0.65.42282:
    10:33:43.415273 IP 192.168.0.65.42282 > 200.221.10.4.21:
    10:33:49.015783 IP 192.168.0.65.42282 > 200.221.10.4.21:
    10:33:49.030894 IP 200.221.10.4.21 > 192.168.0.65.42282:
    10:33:49.033356 IP 192.168.0.65.42282 > 200.221.10.4.21:
    10:33:49.033794 IP 200.221.10.4.21 > 192.168.0.65.42282:
    10:33:49.033825 IP 192.168.0.65.42282 > 200.221.10.4.21:
    10:33:49.046161 IP 200.221.10.4.21 > 192.168.0.65.42282:
    10:33:49.052554 IP 192.168.0.65.42282 > 200.221.10.4.21:
    10:33:49.058511 IP 192.168.0.65.42282 > 200.221.10.4.21:
    10:33:49.067440 IP 200.221.10.4.21 > 192.168.0.65.42282:
    10:33:49.108407 IP 192.168.0.65.42282 > 200.221.10.4.21:
    Mandando um ls:
    Código :
    10:35:00.817010 IP 192.168.0.65.42282 > 200.221.10.4.21:
    10:35:00.888963 IP 200.221.10.4.21 > 192.168.0.65.42282:
    10:35:00.889167 IP 192.168.0.65.42282 > 200.221.10.4.21:
    10:35:00.889256 IP 192.168.0.65.42282 > 200.221.10.4.21:
    10:35:00.959287 IP 200.221.10.4.20 > 192.168.0.65.42283:
    10:35:00.959409 IP 192.168.0.65.42283 > 200.221.10.4.20:
    10:35:00.960352 IP 200.221.10.4.21 > 192.168.0.65.42282:
    10:35:00.991793 IP 200.221.10.4.20 > 192.168.0.65.42283:
    10:35:00.993375 IP 200.221.10.4.21 > 192.168.0.65.42282:
    10:35:01.010669 IP 200.221.10.4.20 > 192.168.0.65.42283:
    10:35:01.011226 IP 192.168.0.65.42283 > 200.221.10.4.20:
    10:35:01.011544 IP 200.221.10.4.20 > 192.168.0.65.42283:
    10:35:01.011807 IP 192.168.0.65.42283 > 200.221.10.4.20:
    10:35:01.027365 IP 200.221.10.4.20 > 192.168.0.65.42283:
    10:35:01.029139 IP 200.221.10.4.21 > 192.168.0.65.42282:
    10:35:01.029220 IP 192.168.0.65.42282 > 200.221.10.4.21:
    Código :
    Logoff:
    10:35:20.353840 IP 192.168.0.65.42282 > 200.221.10.4.21:
    10:35:20.427282 IP 200.221.10.4.21 > 192.168.0.65.42282:
    10:35:20.428449 IP 200.221.10.4.21 > 192.168.0.65.42282:
    10:35:20.428590 IP 192.168.0.65.42282 > 200.221.10.4.21:
    10:35:20.429537 IP 200.221.10.4.21 > 192.168.0.65.42282:
    10:35:20.429605 IP 192.168.0.65.42282 > 200.221.10.4.21:
    10:35:20.506013 IP 200.221.10.4.21 > 192.168.0.65.42282:
  2. #7
    Alkaponi
    Pois Bem colega eu setei as postar 20 e 21 no /etc/services e mudei o proftpd
    para 2222 e em alguns sistema ele abre e lista normal, tipo se uso o linux em outra conexao
    ele abre e lista, mas se uso o windows nesta mesma rede ele nao abre, e se pesso para
    algum amigo meu conectar ele consegue ver. que p... , a gente reclama do windows, mas caras fiz o teste
    com o rwindows2000 server e tudo funfou perfeitamente, qual sera a solucao
    migrar para windows....? ou persistir no linux. bom estava tentando o RH9 agora vou tentar
    com o debian e vamos la ver o que da depois posto ae flw galera.
    detalhe meu speedy e home
    Citação Postado originalmente por felco
    Conectando:
    Código :
    Login:
    Código :
    Mandando um ls:
    Código :
    Código :
    Logoff:
  3. #8
    charadaa
    pode ser com as suas portas, vc colocou a 2222 no lugar da 21 que é ftp-session, e no lugar da 20 que é ftp-dados como esta???? no caso da adsl home o bloqueio é em cima da porta 21 por isso se vc esta usando a porta 2222 ele não deveria estar filtrando mesmo vc tendo adsl home
  1. Respostas: 0
    Último Post: 26-08-2002, 17:42
  2. mais uma vez o qmail
    Por SnifferSp no fórum Servidores de Rede
    Último Post: 13-08-2002, 09:14
  3. DNS é uma dor de cabeça!!
    Por Jhones no fórum Servidores de Rede
    Último Post: 27-07-2002, 19:10
  4. Virtual Host - IP´s diferentes e somente uma placa de
    Por APeixoto no fórum Servidores de Rede
    Último Post: 08-07-2002, 12:49
  5. Passos para conf de uma estacao linux ..
    Por MarcelScan no fórum Servidores de Rede
    Último Post: 04-04-2002, 22:40
