  1. - tem como vc postar auqi o seu /etc/modprobe.conf?
    - que erro que da quando vc digita o comando "modprobe bttv card=37 tuner=17 radio=0 " ?
    - digite: "lsmod" e poste aqui o resultado...
  2. #7
    Quanto a modprobe bttv card=37 tuner=17 radio=0 não deu erro algum ...
    O meu /etc/modprobe.conf
    # Copyright (c) 1996-2002 SuSE Linux AG Nuernberg, Germany.
    # All rights reserved.
    # Author: Hubert Mantel <mantel@suse.de>, 1996-2002
    # Configuration file for loadable modules; used by modprobe
    # Please don't edit this file. Place your settings into
    # /etc/modprobe.conf.local instead.
    # Aliases - specify your hardware
    alias char-major-89 i2c-dev
    alias char-major-81 videodev
    alias char-major-81-0 bttv
    options i2c-core i2c_debug=1
    options i2c-algo-bit bit_test=1
    options bttv card=70 radio=0 tuner=2
    install eth0 /bin/true
    install eth1 /bin/true
    install tr0 /bin/true
    install scsi_hostadapter /bin/true
    install fb0 /bin/true
    # only used for Mylex or Compaq Raid as module
    install block-major-48 /bin/true
    install block-major-49 /bin/true
    install block-major-72 /bin/true
    install block-major-73 /bin/true
    # only needed for fifth and sixth IDE adaptor
    install block-major-56 /bin/true
    install block-major-57 /bin/true
    # mouse (for older busmice)
    install char-major-10 /bin/true
    # If you want to use the new autofs4
    # alias autofs autofs4
    # For parallel port devices, uncomment the following two lines and
    # change "frpw" to the protocol type you use
    # install paride /sbin/modprobe --ignore-install paride && { /sbin/modprobe --ignore-install frpw; }
    # remove paride { /sbin/modprobe -r --ignore-remove frpw; } ; /sbin/modprobe -r --ignore-remove paride
    # Options; these are examples; uncomment and modify the lines you need
    # options cdu31a cdu31a_port=0x340 cdu31a_irq=0
    # options sbpcd sbpcd=0x230,1
    # options aztcd aztcd=0x320
    # options cm206 cm206=0x340,11
    # options gscd gscd=0x340
    # options mcd mcd=0x300,11
    # options mcdx mcdx=0x300,11
    # options optcd optcd=0x340
    # options sjcd sjcd_base=0x340
    # options sonycd535 sonycd535=0x340
    # options isp16 isp16_cdrom_base=0x340 isp16_cdrom_irq=0 isp16_cdrom_dma=0 isp16_cdrom_type=Sanyo
    # options ne io=0x300 irq=5
    # Use this if you have two cards:
    # options ne io=0x300,0x320 irq=5,7
    # options tulip options=0
    # options 3c59x options=0
    # options 3c501 io=0x280 irq=5
    # options 3c503 io=0x280 irq=5 xcvr=0
    # options 3c505 io=0x300 irq=10
    # options 3c507 io=0x300 irq=10
    # options 3c509 irq=10
    # options at1700 io=0x260 irq=10
    # options smc-ultra io=0x200 irq=10
    # options wd io=0x300 irq=10
    # options smc9194 io=0x200 irq=10 ifport=0
    # options e2100 io=0x300 irq=10 mem=0xd0000 xcvr=0
    # options depca io=0x200 irq=7
    # options ewrk3 io=0x300 irq=10
    # options eexpress io=0x300 irq=10
    # options hp-plus io=0x300 irq=10
    # options hp io=0x300 irq=10
    # options hp100 hp100_port=0x380
    # options apricot io=0x300 irq=10
    # options ac3200 io=0x300 irq=10 mem=0xd0000
    # options de620 io=0x378 irq=7 bnc=1
    # options ibmtr io=0xa20
    # options arcnet io=0x300 irq=10 shmem=0xd0000
    # options plip io=0x378 irq=7
    # options eepro io=0x260 irq=10 mem=0x6000
    # options eth16i io=0x2a0 irq=10
    # options fmv18x io=0x220 irq=10
    # options ni52 io=0x360 irq=9 memstart=0xd0000 memend=0xd4000
    # options bttv pll=1 radio=0 card=0
    # options tuner type=0
    # options msp3400 once=1 simple=1
    # install bttv /sbin/modprobe --ignore-install bttv && { /sbin/modprobe -k tuner; /sbin/modprobe -k msp3400; }
    install dummy0 /sbin/modprobe -o dummy0 --ignore-install dummy
    install dummy1 /sbin/modprobe -o dummy1 --ignore-install dummy
    remove dummy0 /sbin/modprobe -r -o dummy0 --ignore-remove dummy
    remove dummy1 /sbin/modprobe -r -o dummy1 --ignore-remove dummy
    # cipe section
    alias cipcb0 cipcb
    alias cipcb1 cipcb
    options cipcb cipe_debug=0
    # block dev aliases
    install block-major-3 /bin/true
    alias block-major-7 loop
    alias block-major-8 sd_mod
    alias block-major-11 sr_mod
    alias block-major-13 xd
    alias block-major-15 cdu31a
    alias block-major-16 gscd
    alias block-major-17 optcd
    alias block-major-18 sjcd
    alias block-major-20 mcdx
    install block-major-22 /bin/true
    alias block-major-23 mcd
    alias block-major-24 sonycd535
    alias block-major-25 sbpcd
    alias block-major-26 sbpcd
    alias block-major-27 sbpcd
    alias block-major-28 sbpcd
    alias block-major-29 aztcd
    alias block-major-32 cm206
    install block-major-33 /bin/true
    install block-major-34 /bin/true
    # network block device
    install block-major-43 /bin/true
    alias block-major-45 pd
    alias block-major-46 pcd
    alias block-major-47 pf
    alias block-major-117 evms
    # char dev aliases
    alias char-major-6 lp
    alias char-major-9 st
    alias char-major-10-130 softdog
    install char-major-10-134 /bin/true
    install char-major-10-135 /bin/true
    alias char-major-10-175 agpgart
    alias char-major-10-181 toshiba
    alias char-major-10-250 sonypi
    options sonypi minor=250
    install char-major-15 /bin/true
    alias char-major-19 cyclades
    alias char-major-20 cyclades
    alias char-major-21 sg
    alias char-major-27 ftape
    install char-major-29 /bin/true
    alias char-major-36 netlink_dev
    # alias char-major-43 hisax
    # alias char-major-44 hisax
    # alias char-major-45 hisax
    install char-major-43 /bin/true
    install char-major-44 /bin/true
    install char-major-45 /bin/true
    alias char-major-48 riscom8
    alias char-major-49 riscom8
    alias char-major-67 coda
    alias char-major-75 specialix
    alias char-major-76 specialix
    install char-major-81-0 /bin/true
    install char-major-81-1 /bin/true
    install char-major-81-2 /bin/true
    install char-major-81-3 /bin/true
    alias char-major-83 vtx
    options vtx quiet=1
    alias char-major-96 pt
    alias char-major-97 pg
    alias char-major-107 3dfx
    alias char-major-109 lvm-mod
    # remove this if sound is configured
    install char-major-116 /bin/true
    # ppp over ethernet
    # the kernel 2.2 uses pppox
    # the kernel 2.4 uses pppoe
    alias char-major-108 ppp_generic
    alias char-major-144 pppoe
    alias net-pf-24 pppoe
    # IrDA
    alias char-major-161 ircomm-tty
    alias char-major-162 raw
    # USB
    install char-major-166 /bin/true
    # Moxa Multiport Serial Boards
    alias char-major-172 moxa
    alias char-major-173 moxa
    # options moxa type=2,,, baseaddr=0xdc000,,, numports=8,,,
    alias char-major-174 mxser
    alias char-major-175 mxser
    # options mxser ioaddr=0x180
    #alias char-major-180 usbcore
    alias InterMezzo intermezzo
    alias char-major-185 intermezzo
    alias char-major-188 usbserial
    alias char-major-195* nvidia
    alias char-major-206 osst
    alias char-major-212 /bin/true
    alias binfmt-204 binfmt_aout
    alias binfmt-263 binfmt_aout
    alias binfmt-264 binfmt_aout
    alias binfmt-267 binfmt_aout
    alias binfmt-0064 binfmt_aout
    alias binfmt-0008 binfmt_aout
    alias iso9660 isofs
    alias tty-ldisc-1 slip
    alias tty-ldisc-2 serio
    alias tty-ldisc-5 mkiss
    # alias tty-ldisc-7 6pack
    install tty-ldisc-7 /bin/true
    # IrDA
    alias tty-ldisc-11 irtty-sir
    # alias ax0 mkiss
    install ax0 /bin/true
    # alias sp0 6pack
    install sp0 /bin/true
    alias slip0 slip
    alias sl0 slip
    alias slip1 slip
    alias sl1 slip
    # the kernel 2.2 uses ppp.o as ppp driver,
    # the kernel 2.4 uses ppp_generic.o
    alias ppp0 ppp_generic
    alias ppp1 ppp_generic
    alias tty-ldisc-3 ppp_async
    alias plip0 plip
    alias plip1 plip
    # Tunnel interfaces
    alias sit0 ipv6
    alias gre0 ip_gre
    alias ipip0 ipip
    alias ppp-compress-18 ppp_mppe
    alias ppp-compress-21 bsd_comp
    alias ppp-compress-24 ppp_deflate
    alias ppp-compress-26 ppp_deflate
    alias net-pf-1 unix
    alias net-pf-3 ax25
    # install net-pf-3 /bin/true
    alias net-pf-4 ipx
    # install net-pf-4 /bin/true
    alias net-pf-5 appletalk
    # install net-pf-5 /bin/true
    alias net-pf-6 netrom
    # install net-pf-6 /bin/true
    alias net-pf-10 ipv6
    # install net-pf-10 /bin/true
    alias net-pf-11 rose
    # install net-pf-11 /bin/true
    alias net-pf-15 af_key
    alias net-pf-17 af_packet
    alias net-pf-31 bluetooth
    alias bt-proto-0 l2cap
    alias bt-proto-2 sco
    alias bt-proto-3 rfcomm
    alias bt-proto-4 bnep
    alias md-personality-1 linear
    alias md-personality-2 raid0
    alias md-personality-3 raid1
    alias md-personality-4 raid5
    alias md-personality-7 multipath
    alias tap0 ethertap
    alias tap1 ethertap
    alias tap2 ethertap
    alias tap3 ethertap
    alias tap4 ethertap
    alias tap5 ethertap
    alias tap6 ethertap
    alias tap7 ethertap
    alias tap8 ethertap
    alias tap9 ethertap
    alias tap10 ethertap
    alias tap11 ethertap
    alias tap12 ethertap
    alias tap13 ethertap
    alias tap14 ethertap
    alias tap15 ethertap
    alias xfrm-type-2-50 esp4
    alias xfrm-type-2-51 ah4
    alias xfrm-type-2-108 ipcomp
    alias xfrm-type-10-50 esp6
    alias xfrm-type-10-51 ah6
    alias xfrm-type-10-108 ipcomp6
    # don't try to reset isa-pnp cards on startup
    options isa-pnp isapnp_reset=0
    # Linux-ABI
    install binfmt_misc /sbin/modprobe --ignore-install binfmt_misc && { mount -t binfmt_misc none /proc/sys/fs/binfmt_misc; }
    remove binfmt_misc { umount /proc/sys/fs/binfmt_misc; } ; /sbin/modprobe -r --ignore-remove binfmt_misc
    # Bluetooth
    alias bt-proto-5 cmtp
    alias bt-proto-6 hidp
    # end of common part for modprobe.conf
    # begin of i386 part for modprobe.conf
    alias char-major-4 serial
    alias char-major-5 serial
    alias parport_lowlevel parport_pc
    # options parport_pc io=0x378 irq=none,none
    # If you have multiple parallel ports, specify them this way:
    # options parport_pc io=0x378,0x278 irq=none,none
    # Linux ACP modem (Mwave)
    alias char-major-10-219 mwave
    # options mwave dspirq=10 dspio=0x130 uartirq=3 uartio=0x2f8
    # nVidia nforce chipset (network + audio)
    #alias eth0 nvnet
    #alias sound-slot-1 nvaudio
    #alias usb-interface usb-ohci
    # IBM thinkpad tpctl
    # see /usr/share/doc/packages/tpctl/
    alias char-major-10-170 thinkpad
    # options thinkpad enable_smapi=0
    # Linux-ABI
    alias char-major-30 abi-ibcs
    alias binfmt-0004 binfmt_coff
    alias binfmt-332 abi-ibcs
    alias binfmt-518 abi-ibcs
    alias binfmt-002c abi-ibcs
    alias personality-1 abi-ibcs
    alias personality-2 abi-ibcs
    alias personality-3 abi-sco
    alias personality-4 abi-wyse
    alias personality-5 abi-ibcs
    alias personality-7 abi-ibcs
    alias personality-13 abi-solaris
    alias personality-14 abi-uw7
    # required for DRI support on SiS chips
    options sisfb mode=none mem=12288
    # end of i386 part for modprobe.conf
    # please keep this at the end and add local modifications to modules.conf.local
    include /etc/modprobe.d
    include /etc/modprobe.conf.local
    LSMOD
    Module Size Used by
    tuner 19236 0
    cx8800 26636 0
    cx88xx 43536 1 cx8800
    i2c_algo_bit 8584 1 cx88xx
    video_buf 18820 2 cx8800,cx88xx
    i2c_core 21520 3 tuner,cx88xx,i2c_algo_bit
    v4l1_compat 12164 1 cx8800
    v4l2_common 6016 1 cx8800
    btcx_risc 4360 2 cx8800,cx88xx
    videodev 7936 2 cx8800,cx88xx
    usbserial 24680 0
    parport_pc 35520 1
    lp 9128 0
    parport 36168 2 parport_pc,lp
    nvram 7688 0
    edd 8860 0
    speedstep_lib 3844 0
    freq_table 4100 0
    thermal 15368 0
    processor 22312 1 thermal
    fan 4100 0
    button 6416 0
    battery 9604 0
    ac 4740 0
    ipv6 217856 15
    snd_pcm_oss 56616 0
    snd_mixer_oss 18432 1 snd_pcm_oss
    snd_cmipci 27940 1
    snd_pcm 94600 3 snd_pcm_oss,snd_cmipci
    snd_page_alloc 8456 1 snd_pcm
    snd_opl3_lib 9856 1 snd_cmipci
    snd_timer 22916 2 snd_pcm,snd_opl3_lib
    snd_hwdep 8324 1 snd_opl3_lib
    gameport 4352 1 snd_cmipci
    snd_mpu401_uart 6784 1 snd_cmipci
    snd_rawmidi 22948 1 snd_mpu401_uart
    snd_seq_device 8460 2 snd_opl3_lib,snd_rawmidi
    snd 56836 11 snd_pcm_oss,snd_mixer_oss,snd_cmipci, snd_pcm,snd_opl3_lib, snd_timer,snd_hwdep, snd_mpu401_uart, snd_rawmidi,snd_seq_device
    soundcore 7776 1 snd
    evdev 7168 0
    joydev 8000 0
    sg 32032 0
    st 34204 0
    sd_mod 15120 0
    sr_mod 14756 0
    scsi_mod 103500 4 sg,st,sd_mod,sr_mod
    usbhid 38212 0
    ide_cd 35232 0
    cdrom 34972 2 sr_mod,ide_cd
    ehci_hcd 27012 0
    ohci_hcd 18308 0
    sis_agp 7300 1
    agpgart 29608 1 sis_agp
    dm_mod 48764 0
    usbcore 98404 6 usbserial,usbhid,ehci_hcd,ohci_hcd
    dmfe 17564 0
    reiserfs 242000 1
  3. #8
    whinston
    nossa, nunca vi um modprobe tao grande!!
    viu, to pra comprar outra placa pra fz captura no estilo tiVo dos EUa.. esta mpeg2 eh boa?
  4. Bom cara, a PlayTV Mpeg2 é uma placa com custo/beneficio muito bom!
    é barata, e tem boa qualidade...faz captura na resolução mpeg2 (720x576) ....
    A PlayTV Pro Ultra e Pro 2 são melhores ainda...mas o que mais faz a diferença são os softwares que vem acompanhados com a Placa...que no caso eu não uso, pois são para win 32.... e o software de captura pra windows são horriveis...bugados d+....
    no linux é meio chato de configurar, mas depois de feito uma vez, sempre que precisar será fácil....
  5. #10
    whinston
    e vc consegue agendar pra ele gravar os programas e tal?
    kale o formato de saida e qual o tamanho medio por minuto gravado?
  1. Placa de TV no suse
    Por dennisrosa no fórum Sistemas Operacionais
    Último Post: 16-06-2004, 07:36
  2. Placa de TV
    Por no fórum Sistemas Operacionais
    Último Post: 04-02-2004, 14:32
  3. Placa de TV
    Por juniox no fórum Servidores de Rede
    Último Post: 19-02-2003, 01:11
  4. Placa de TV
    Último Post: 17-02-2003, 20:49
  5. Placa de TV
    Último Post: 16-01-2003, 03:31
