    fpmazzi
    e aki esta a config. do meu sarg.conf
    language Portuguese
    #access_log /usr/local/squid/var/logs/access.log
    access_log /var/log/squid/access.log
    title "RELATORIO DE ACESSO A INTERNET PELO PROXY SQUID"
    temporary_dir /tmp
    output_dir /var/www/sarg
    resolve_ip yes
    user_ip no
    topuser_sort_field BYTES reverse
    date_format u
    remove_temp_files yes
    index yes
    overwrite_report yes
    topsites_num 100
    topsites_sort_order CONNECT D
    index_sort_order D
    # 8 Hours
    max_elapsed 28800000
    report_type topsites sites_users users_sites date_time denied auth_failures site_user_time_date
    long_url yes
    date_time_by bytes
    show_successful_message yes
    topuser_fields NUM DATE_TIME USERID CONNECT BYTES %BYTES IN-CACHE-OUT USED_TIME MILISEC %TIME TOTAL AVERAGE
    user_report_fields CONNECT BYTES %BYTES IN-CACHE-OUT USED_TIME MILISEC %TIME TOTAL AVERAGE
  2. Eai blz
    Teu Sarg ta legal.
    AGora post seu conf do squid para ver pq ele ta gerando u ip rede!!
    Qual sua distro?
    Citação Postado originalmente por fpmazzi
    como vc pediu aqui esta o inicio do meu access.log:
    1107781579.535 68 192.168.100.0 TCP_MISS/200 434
    GET
    http://de.uol.com.br/js.ng/site=uolb...=0&ord=160958?
    - DIRECT/200.221.6.52 application/x-javascript
    1107781579.818 73 192.168.100.0 TCP_MISS/200 1842
    GET
    - DIRECT/200.221.6.48 application/x-javascript
    1107781579.884 97 192.168.100.0 TCP_MISS/200 1811
    GET
    - DIRECT/200.221.6.47 application/x-javascript
    1107781585.368 154 192.168.100.0 TCP_MISS/200 15350
    GET
    http://de.i.uol.com.br/americanas/uo...vdtocatudo.gif
    - DIRECT/200.221.7.38 image/gif
    1107781585.466 60 192.168.100.0 TCP_HIT/200 4386
    GET
    http://de.i.uol.com.br/folha/uol/041...ater_folha.gif
    - NONE/- image/gif
    1107781592.413 66 192.168.100.0 TCP_MISS/302 306
    GET
    http://de.uol.com.br/event.ng/Type=c...l%3Forig%3Duo3
    - DIRECT/200.221.6.54 text/html
    1107781593.809 1122 192.168.100.0 TCP_MISS/200 10511
    GET http://www.pontofrio.com.br/cgi-bin/loja.pl? -
  3. #43
    fpmazzi
    eis aki o meu squid.conf
    http_port 192.168.100.1:3128
    hierarchy_stoplist cgi-bin ?
    acl QUERY urlpath_regex cgi-bin
    no_cache deny QUERY
    cache_mem 300 MB
    cache_swap_low 900
    cache_swap_high 950
    cache_replacement_policy lru
    memory_replacement_policy lru
    ipcache_size 1024
    ipcache_low 90
    ipcache_high 93
    cache_log /var/log/squid/cache.log
    cache_store_log /var/log/squid/store.log
    cache_dir diskd /var/spool/squid 350 16 256
    mime_table /etc/squid/mime.conf
    refresh_pattern . 15 20% 2280
    refresh_pattern . 0 20% 4320
    cache_effective_user squid
    cache_effective_group squid
    # ACLS
    acl all src 0.0.0.0/0.0.0.0
    acl localnet src 192.168.100.0/255.255.255.0
    acl cache_user src 192.168.100.0/255.255.255.0
    client_netmask 255.255.255.0
    # Configuracao do Hotmail para funcionar #
    acl hotmail_domains dstdomain .hotmail.msn.com
    header_access Accept-Encoding deny hotmail_domains
    # Adicione essas linhas no Iptables
    # iptables -t nat -A PREROUTING -s 0/0 -d 65.4.0.0/16 -p tcp --dport 80 -j ACCEPT
    # iptables -t nat -A PREROUTING -s 0/0 -d 64.4.0.0/16 -p tcp --dport 80 -j ACCEPT
    # Configuracao para Yahoo #
    acl yahoo_domains dstdomain .yahoo.com .yahoo.com.br
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl purge method PURGE
    acl CONNECT method CONNECT
    acl proibidas url_regex -i "/etc/squid/regras/proibidas"
    acl liberadas url_regex -i "/etc/squid/regras/liberadas"
    acl ipsliberados src "/etc/squid/regras/ipsliberados"
    #acl ipsbloqueados src "etc/squid/regras/ipsbloqueados"
    http_access deny manager
    http_access deny !Safe_ports
    http_access deny SSL_ports
    http_access allow ipsliberados
    #http_access deny ipsbloqueados
    http_access allow liberadas
    http_access deny proibidas
    http_access allow localnet
    http_access deny all
    icp_access allow all
    visible_hostname on
    visible_hostname Servidor
    httpd_accel_host virtual
    httpd_accel_port 80
    httpd_accel_with_proxy on
  4. Bom dia!
    Você tem dua regras de cache para o access.log! tire uma apague seus log rode o squid e tente novamente olhar os logs! veja ce ainda continua gerando o ip da rede!
  5. #45
    fpmazzi
    Cara limpei os arquivos cache.log, store.log e o access.log, e comentei a primeira linha das duas que indica o access.log, mas sem sucesso, depois fui la no squid, reabilitei a primeira linhda onde continha o access.log e desabilitei a segunda e nada tbm...
    oq sera ke ta acontecendo .... ops:
  6. #46
    Flavio-RJ
    fpmazzi,
    no teu squid.conf, modifica a linha, de:
    para:
    client_netmask 255.255.255.255
    Aí com certeza vai mostrar o log de cada ip.
  7. #47
    Flavio-RJ
    Claro,
    depois de modificado, restarte o squid :roll:
    Citação Postado originalmente por Flavio-RJ
    fpmazzi,
    para:
  8. manda para mim seu squid.conf e o access.log por email pode ser no hotmail mesmo!
  9. #49
    fpmazzi
    valew mocada, segui as dicas de voces e funcionou, primeiro era a dica do spectrum das linhas duplicadas, retireii uma e melhoro o desempenho qdo digitava o comando sarg, e dps a do vitor, de tirar o client_netmask, era ele mesmo o prob.
    so pra ir no embalo alguem poderia me explicar o pq esta linha do client_netmask, so me trazia a rede e nao os ips???
    Valew...
    fica ae minha pergunta....
  1. Problemas na configuração do monitor no CL9
    Por vonlinkerstain no fórum Servidores de Rede
    Respostas: 12
    Último Post: 07-11-2004, 08:51
  2. Problema de configuração do postfix
    Por anmendes no fórum Servidores de Rede
    Último Post: 26-07-2004, 11:23
  3. problema na configuração do vsftpd
    Por roggy no fórum Servidores de Rede
    Último Post: 03-05-2004, 13:54
  4. Respostas: 0
    Último Post: 12-11-2003, 10:05
  5. problemas de configuração do cups
    Por Wronieri no fórum Servidores de Rede
    Último Post: 10-02-2003, 12:56
