  1. Cara segue abaixo como bloquear sites e palavras de maneira simples e eficaz vale apena dar uma olhada!!!
    Esse e um exemplo de proxy controlado mas se vc usar transparente tambem nao tera que alterar muita coisa!!!
    http://www.linuxit.com.br/section-viewarticle-708.html
    Valeu mano qualquer coisa posta ai !!!
  2. Citação Postado originalmente por gatoseco
    Abençoado, eles sabem configurar o squid, a questão é usar URL's ao invés de palavras na blacklist.
  3. POem a blacklist e da uma testada ai !!!
  4. #14
    HunTer
    E ai feras.... olhai meu squid.conf
    http_port 10.0.0.1:3128
    hierarchy_stoplist cgi-bin ?
    no_cache deny QUERY
    cache_mem 16 MB
    cache_swap_low 90
    cache_swap_high 95
    # maximum_object_size 4096 KB
    maximum_object_size 512 KB
    cache_dir ufs /var/lib/squid/cache 100 16 256
    cache_access_log /var/lib/squid/logs/access.log
    cache_log /var/lib/squid/logs/cache.log
    cache_store_log /var/lib/squid/logs/store.log
    client_netmask 255.255.255.0
    auth_param basic children 5
    auth_param basic realm Squid proxy-caching web server
    auth_param basic credentialsttl 2 hours
    auth_param basic casesensitive off
    refresh_pattern . 0 20% 4320
    acl all src 0.0.0.0/0.0.0.0
    # BLOKEIA SITES
    acl blokeia url_regex -i "/etc/squid/lista/blokeia.txt"
    acl desblokeia url_regex -i "/etc/squid/lista/desblokeia.txt"
    acl hotmail dstdomain .hotmail.msn.com
    # REGRAS NORMAIS
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl CONNECT method CONNECT
    # REDE INTERNA
    acl rede_interna src 10.0.0.0/24
    http_access deny manager
    # Deny requests to unknown ports
    http_access deny !Safe_ports
    # Deny CONNECT to other than SSL ports
    http_access deny blokeia !desblokeia
    header_access Accept-Encoding deny hotmail
    http_access allow rede_interna
    http_access deny all
    http_reply_access allow all
    icp_access allow all
    visible_hostname xinxilla
    httpd_accel_host virtual
    httpd_accel_port 80
    httpd_accel_with_proxy on
    error_directory /usr/local/squid/share/errors/Portuguese
    coredump_dir /usr/local/squid/var/cache
    []´s ONDE SERÁ Q EU ERREI???.... rsssssssss
  5. tenta limpar tudo da tua lista "bloqueia" pra ver se adianta...
    Só uma pergunta... NENHUM site abre ou apenas os que tem linux no nome?
  1. Modulos Iptables nao carregam mais!
    Por ezaupc no fórum Servidores de Rede
    Último Post: 12-06-2006, 15:31
  2. Site não abre
    Por chicus no fórum Servidores de Rede
    Último Post: 13-09-2004, 10:33
  3. Alguns sites não entram...
    Por Mr. Porlock no fórum Servidores de Rede
    Último Post: 10-02-2004, 21:59
  4. Alguns sites não entram !!!
    Por Levix no fórum Servidores de Rede
    Respostas: 23
    Último Post: 20-10-2003, 18:13
  5. site nao é visualizado!!!
    Por pensador-ce no fórum Servidores de Rede
    Respostas: 11
    Último Post: 29-09-2003, 11:01
