    Alexandre_Catanduva
    Tá começando a melhorar... hehehehe...
    [root@kardecbooks root]# nmap 200.x.x.x
    Starting nmap 3.50 ( http://www.insecure.org/nmap/ ) at 2005-03-03 21:03 BRT
    Interesting ports on desenv.kardecbooks.com.br (200.x.x.x):
    (The 1656 ports scanned but not shown below are in state: closed)
    PORT STATE SERVICE
    53/tcp open domain
    111/tcp open rpcbind
    631/tcp open ipp
    Nmap run completed -- 1 IP address (1 host up) scanned in 1.171 seconds
    ---------------------------------- named.conf --------------------------------
    // generated by named-bootconf.pl
    options {
    directory "/var/named";
    * If there is a firewall between you and nameservers you want
    * to talk to, you might need to uncomment the query-source
    * directive below. Previous versions of BIND always asked
    * questions using port 53, but BIND 8.1 uses an unprivileged
    * port by default.
    //query-source address * port 53;
    dump-file "/var/named/dump/named_dump.db";
    statistics-file "/var/named/dump/named.stats";
    memstatistics-file "/var/named/dump/named.memstats";
    // remove this next line if you want named to listen on
    // all available interfaces, or adjust add new ones as
    // you see fit
    //listen-on { 127.0.0.1/32; };
    // a caching only nameserver config
    zone "." {
    type hint;
    file "named.ca";
    zone "0.0.127.in-addr.arpa" {
    type master;
    file "named.local";
    zone "localhost" IN {
    type master;
    file "localhost.zone";
    zone "x.x.200.in-addr.arpa" IN {
    type master;
    file "dominio.rev";
    zone "kardecbooks.com.br" IN {
    type master;
    file "kardecbooks.zone";
    zone "espiritanet.com.br" IN {
    type master;
    file "espiritanet.zone";
    ------------------------------ kardecbooks.zone ----------------------------
    $TTL 86400
    @ IN SOA desenv. desenv.kardecbooks.com.br. (
    2005030301 ;serial (aaaammddxx)
    10800 ;refresh 3 horas
    1800 ;retry 30 minutos
    36000 ;expiry 10 horas
    86400) ;minimum 24 horas
    IN NS desenv.kardecbooks.com.br.
    kardecbooks.com.br. IN MX 0 mx
    kardecbooks.com.br. IN MX 10 mx
    localhost IN A 127.0.0.1
    www IN A 200.x.x.x
    ns1 IN A 200.x.x.x
    ------------------------------ espiritanet.zone ---------------------------------
    $TTL 86400
    IN NS desenv.espiritanet.com.br.
    espiritanet.com.br. IN MX 0 mx
    espiritanet.com.br. IN MX 10 mx
    www IN A 200.x.x.x
    ns1 IN A 200.x.x.x
    ---------------------------- dominio.rev --------------------------------------
    x.x.200.in-addr.arpa. IN SOA desenv.kardecbooks.com.br. root.kardecbooks.com.br.(
    2005030301 ; Serial number (increase it after edit)
    10800 ; Refresh after 3 hours (3 x 3600 sec)
    3600 ; Retry after 1 hour (1 x 3600 sec)
    604800 ; Expire after 1 week (7 x 24 x 3600 sec)
    86400 ) ; Minimum TTL of 1 day (24 x 3600 sec)
    ; Name servers
    x.x.200.in-addr.arpa. IN NS desenv.kardecbooks.com.br.
    ; Addresses point to canonical name
    x.x.x.200.in-addr.arpa. IN PTR desenv.kardecbooks.com.br.
    ---------------------------------- localhost.zone ------------------------------
    $TTL 86400
    @ 1D IN SOA @ root (
    1D IN NS @
    1D IN A 127.0.0.1
    -------------------------------------- named.local ------------------------------
    @ IN SOA localhost. root.localhost. (
    1997022700 ; Serial
    28800 ; Refresh
    14400 ; Retry
    3600000 ; Expire
    86400 ) ; Minimum
    IN NS localhost.
    1 IN PTR localhost.
  2. Seguitne ainda da timeout na fapesp? seguinte vai em uma maquina fora da sua rede, edita o resolve.conf pra so apontar pro seu servidor e roa um nslookup e tenta verificar se ele resolve seus dominios.
    falows
  3. #18
    karfax
    netstat -an | grep 53 | less
    listen-on { any; };
    :lol:
  4. #19
    Alexandre_Catanduva
    Karfax:
    tcp 0 0 200.x.x.x:53 0.0.0.0:* OUÇA
    tcp 0 0 127.0.0.1:53 0.0.0.0:* OUÇA
    tcp 0 0 127.0.0.1:953 0.0.0.0:* OUÇA
    udp 0 0 200.x.x.x:53 0.0.0.0:*
    udp 0 0 127.0.0.1:53 0.0.0.0:*
    unix 3 [ ] STREAM CONECTADO 3853
    unix 3 [ ] STREAM CONECTADO 3253 /tmp/.ICE-unix/2013
    Alterei o listen-on para any, mas mesmo assim ainda ta dando timeout
    Ruy: Não tenho como testar de outra máquina, só tenho um ponto de acesso a internet.
  5. #20
    buribai
    Afinal, vc usa firewall ou naum ???
    Se usar, desabilite ele enquanto vc testa !!!
    iptables -F
    iptables -P INPUT ACCEPT
    iptables -P OUTPUT ACCEPT
    iptables -P FORWARD ACCEPT
    coloque o ip da maquina DNS no listen
    falowww
  1. Servidor Radius não está respondendo
    Por Hamsururu no fórum Redes
    Último Post: 20-06-2012, 07:05
  2. (Bind) DNS interno e externo respondendo diferente
    Por osni_passos no fórum Servidores de Rede
    Último Post: 05-02-2008, 14:08
  3. Apache ou BIND onde está o problema?
    Por nilsonfsilva no fórum Servidores de Rede
    Último Post: 01-09-2007, 21:36
  4. Roteamento com Debian não está respondendo!
    Último Post: 23-12-2003, 10:46
  5. Como eu sei se o bind/dns esta funcionando?
    Por guardian_metal no fórum Servidores de Rede
    Respostas: 6
    Último Post: 14-10-2003, 16:52
