  1. olha o que acontece se eu rodo em modo debug
    $squid -d 3
    2005/03/15 17:02:07| Starting Squid Cache version 2.5.STABLE9 for i386-debian-linux-gnu...
    2005/03/15 17:02:07| Process ID 27836
    2005/03/15 17:02:07| With 1024 file descriptors available
    2005/03/15 17:02:07| Performing DNS Tests...
    2005/03/15 17:02:07| Successful DNS name lookup tests...
    2005/03/15 17:02:07| DNS Socket created at 0.0.0.0, port 32790, FD 5
    2005/03/15 17:02:07| Adding nameserver 200.215.1.44 from /etc/resolv.conf
    2005/03/15 17:02:07| User-Agent logging is disabled.
    2005/03/15 17:02:07| Referer logging is disabled.
    2005/03/15 17:02:07| ALERT: setgid: (1) Operation not permitted
    2005/03/15 17:02:07| Unlinkd pipe opened on FD 10
    2005/03/15 17:02:07| Swap maxSize 524288 KB, estimated 40329 objects
    2005/03/15 17:02:07| Target number of buckets: 2016
    2005/03/15 17:02:07| Using 8192 Store buckets
    2005/03/15 17:02:07| Max Mem size: 16384 KB
    2005/03/15 17:02:07| Max Swap size: 524288 KB
    2005/03/15 17:02:07| Local cache digest enabled; rebuild/rewrite every 3600/3600 sec
    2005/03/15 17:02:07| Rebuilding storage in /var/spool/squid (DIRTY)
    2005/03/15 17:02:07| Using Least Load store dir selection
    2005/03/15 17:02:07| Current Directory is /home/debian
    2005/03/15 17:02:07| Loaded Icons.
    2005/03/15 17:02:08| commBind: Cannot bind socket FD 11 to *:3128: (98) Address already in use
    2005/03/15 17:02:08| ALERT: setgid: (1) Operation not permitted
    FATAL: Cannot open HTTP Port
  2. #7
    buribai
    Citação Postado originalmente por 5hu7d0wn
    Pessoal, atualizei meu squid pelo apt-get no debian e o desgraçado parou de funcionar.. não bloqueava nada, aí me batí que nem louco e agora bloqueia tudo, não sei mais o que fazer.. Segue meu squid.conf
    http_port 3128
    hierarchy_stoplist cgi-bin ?
    no_cache deny QUERY
    cache_mem 16 MB
    maximum_object_size_in_memory 64 KB
    maximum_object_size 16 MB
    minimum_object_size 0 KB
    cache_swap_low 90
    cache_swap_high 95
    cache_dir ufs /var/spool/squid 512 16 256
    visible_hostname debian
    ftp_user debian-gobbi@gmail.com.br
    refresh_pattern . 15 20% 2280
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl purge method PURGE
    acl CONNECT method CONNECT
    http_access deny manager
    http_access deny purge
    http_access deny !Safe_ports
    http_access allow localhost
    acl proibidos dstdom_regex "/etc/squid/proibidos"
    http_access deny proibidos
    acl redelocal src 192.168.1.0/24
    http_access allow redelocal
    httpd_accel_host virtual
    httpd_accel_port 80
    httpd_accel_with_proxy on
    Faça isso :
    acl proibidos url_regex -i "/etc/squid/proibidos"
    http_access deny all
  3. Cara.. não deu certo.. Não sei mais o que fazer..
    Vou tentar começar do zero denovo, vou reinstalar o seridor...
  1. Squid não funciona com Firewall
    Por doliveira no fórum Servidores de Rede
    Respostas: 5
    Último Post: 01-03-2004, 17:39
  2. squid nao funciona
    Por pensador-ce no fórum Servidores de Rede
    Último Post: 19-10-2003, 18:48
  3. Squid não funciona
    Por APS no fórum Servidores de Rede
    Último Post: 10-10-2003, 10:32
  4. squid não funciona
    Por giggio no fórum Servidores de Rede
    Último Post: 19-06-2003, 17:14
  5. Respostas: 3
    Último Post: 25-11-2002, 18:22
