    Daniels
    Padrão Verificacao de listas RBls n esta funcionando.
    Ai galera, estou filtrando envios pra meu serv de email usando listas rbls.
    Meu main.cf ta assim:
    maps_rbl_domains = relays.orbd.org,
    list.dsbl.org,
    dun.dnsrbl.net,
    spam.dnsrbl.net,
    bl.spamcop.net,
    cbl.abuseat.org
    smtpd_recipient_restrictions= permit_mynetworks,
    reject_non_fqdn_recipient,
    check_client_access hash:/etc/postfix/pop-before-smtp,
    reject_unauth_destination,
    reject_rbl_client maps_rbl_domains
    O problema eh q hj recebi um email de um ip q esta listado na CBL:
    No site da CBL
    IP Address 70.59.195.111 was found in the CBL.
    It was detected at 2005-03-26 03:00 GMT (+/- 30 minutes).
    If this address is listed incorrectly, you may request its removal.
    Esse email chegou sem nenhum aviso de spam, e sem nenhuma notificacao de lista. No maillog:
    conect from 70-59-195-111.clsp.qwest.net[70.59.195.111]
    8FB2852105: client=70-59-195-111.clsp.qwest.net[70.59.195.111]
    8FB2852105: message-id=<um numero mto [email protected]>
    8FB2852105: from=<[email protected]>
    8FB2852105: to=<[email protected]>, status=sent
    Achei estranho o id da messagem. A maq mail.openconect.com.br existe e eh um outro servidor de email q eu tenho, cujo ip esta listado no mynetworks. Serah q eh isso? Como a messagem veio com o id dessa maq?
    Minha outra duvida eh o seguinte: qnd for rejeitada alguma msg pelo fato de estar listada numa rbl q estou usando, como vai me aparecer no log?
    Valeu a atencao.
    Padrão PROBLEMA RESOLVIDO
    Problema resolvido. Me main.cf:
    smtpd_helo_restrictions = reject_invalid_hostname,
    check_helo_access regexp:/etc/postfix/helo_invalido
    smtpd_sender_restrictions = reject_non_fqdn_sender,
    reject_unknown_sender_domain
    smtpd_recipient_restrictions = permit_mynetworks,
    check_client_access hash:/etc/postfix/client_access
    smtpd_client_restrictions = permit_mynetworks,
    reject_rbl_client cbl.abuseat.org,
    reject_rbl_client bl.spamcop.net,
    reject_rbl_client t1.dnsbl.net.au,
    reject_rbl_client relays.ordb.org,
    reject_rbl_client dun.dnsrbl.net,
    reject_rbl_client spam.dnsrbl.net,
    reject_rbl_client bl.csma.bi
    To querendo habilitar verificacao a listas rhsbl. Se alguem puder me ajudar, eu serei grato. Se alguem souber outras listas rbls q eu possa usar para a minha verificacao, podem postar tb.
    Falou.
    Daniels
    Sou eu ai em cima! :good:
    whinston
    Padrão pergunta idiota
    la vai a pergunta cretina: este main.cf é do spamassassin ou oq ? se for "oq", me da um toc doq seja, rs. valeu!
    Daniels
    Ae whinston... esse eh o meu main.cf do postfix. Ae vai ele atualizado:
    #===========RESTRICOES=============
    smtpd_helo_restrictions = permit_mynetworks,
    reject_unknown_sender_domain,
    reject_rhsbl_sender dsn.rfc-ignorant.org,
    reject_rhsbl_sender bogusmx.rfc-ignorant.org
    reject_rhsbl_sender blackhole.securitysage.com,
    reject_rhsbl_sender rhsbl.ahbl.org,
    reject_rhsbl_sender rhsbl.sorbs.org,
    reject_rhsbl_sender block.rhs.mailpolice.com
    reject_unknown_recipient_domain,
    reject_rbl_client spam.dnsbl.sorbs.net,
    reject_rbl_client misc.dnsbl.sorbs.net,
    reject_rbl_client smtp.dnsbl.sorbs.net,
    reject_rbl_client block.dnsbl.sorbs.net,
    reject_rbl_client zombie.dnsbl.sorbs.net,
    reject_rbl_client bl.csma.biz,
    reject_rbl_client t2.dnsbl.net.au,
    reject_rbl_client multihop.dsbl.org,
    reject_rhsbl_client dsn.rfc-ignorant.org,
    reject_rhsbl_client bogusmx.rfc-ignorant.org,
    reject_rhsbl_client blackhole.securitysage.com,
    reject_rhsbl_client rhsbl.ahbl.org,
    reject_rhsbl_client rhsbl.sorbs.org,
    reject_rhsbl_client block.rhs.mailpolice.com
    #=============OBS============
    # Foi retirada a lista list.dsbl.org, por estar barrando ips do velox.
    # Foi retirada a lista t1.dnsbl.net.au, por estar barrando ips da net.
    # Foi retirada a lista dul.dnsbl.sorbs.net, por barrar ips dinamicos.
    # Foi retirada a lista unconfirmed.dsbl.org, por barrar ips velox
    # Foi retirada a lista dnsbl.njabl.org, por barrar ips velox
    # Foi retirada a lista http.dnsbl.sorbs.net, por barrar ips velox
    # Foi retirada a lista web.dnsbl.sorbs.net, por barrar ips velox
    # Foi retirada a lista rmst.dnsbl.net.au, por barrar ips velox
    # Foi retirada a lista socks.dnsbl.sorbs.net, por barrar ips velox
    _______________________________________________________
    Essas sao listas Rbls e Rhsbl.
    Velho, sobre a personificacao das regras por usuario no SpamAssassin, vc conseguiu resolver? Aquele link q vc passou no outro topico eu ja tinha lido. Vc pode ve-lo com perldoc Mail::SpamAssassin::Conf no serv.
    Olha, la diz, q qnd esta utilizando o daemon spamd, eh preciso esta habilitada a opcao "allow_user_rules". Para isso, no local.cf: allow_user_rules 1
    Apartir disso, vc pode criar as regras no arquivo "user_prefs".
    Entretanto, ele diz tb, q isso n eh seguro se o spamd estiver rodando como root. Que eh meu caso. O meu spamd esta rodando como root.
    Vc sabe como faco pra mudar o usuario q roda o spamd?!?!?!
    Flw.
    whinston
    Padrão valeu
    Citação Postado originalmente por Daniels
    Flw.
    ah kra, valeu! mas eu uso sendmail, rs.. obrigado mesmo assim
    whinston
    Padrão spamassassin rodando como outro usuario
    qto ao spamassassin cara, nao sei na. valeu
    whinston
    Padrão ativei no sendmail
    Flw.
    cara, ativei no sendmail o suporte a spamcop
    sera q eh soh eu copiar as linhas la e mudar ao inves do spamcop procurar nestas suas listas ?
    Daniels
    Acho q eh sim, velho... entretanto vc tem que ficar esperto pq varias listas barram ips do Brasil. E muitos desses ips sao dinamicos, gerando assim um problema. Alem das que ja tinha retirado qnd fiz esse post, retirei a multihop.dsbl.org.
    Flw
